I have the following problem:
after a reset of the bq78350r1 the IC shows the SOC based on the programmed ChemID. Unfortunately the customers criteria is a voltage range from 3.3V to 4.2V per cell, causing a mismatch between ChemID-SOC and real-SOC.
Can you please create an updated ChemID, showing the correct SOC after reset?old_chemID.zip
Thank you,
Simon
