TPS22953: TPS22953 Reverse Current
Part Number: TPS22953
I'm looking at using the TPS22953 for it's low leakage performance to isolate a rechargeable battery from my system during certain states.  While ON, I need to be able to send both charging and discharging currents to the battery through this switch.  I'm looking for clarification: does the TPS22953 support this type of bi-directional current flow in the ON state?
Thanks!
  • Hi Lawrence,
    Thanks for reaching out on E2E.
    Since the TPS22953 doesn't have always-on reverse current blocking, it can act like a bi-directional switch and charge / discharge the battery. When the device is off, it will block current from entering the device in both directions.
    Arthur Huang
  • Thanks for the clarification Arthur, we'll look into getting a demo board and try it out.
