Hello All,
In order to better understand the UCC28740 functionalities, this presentation ( Here ) was provided to me.
I started by deriving the open loop transfer function for all 4 modulation regions. but I still have some points that need clarification:
- Slide 11 : For the modulator + Plant Transfer function . The Ip/Ipmax ratio is clear for the FM control mode, but not so much for the AM region. and the Vcs_max should be the image of Ipmax on the CS pin?
- Slide 12 : is neglecting the ESR value of the output capacitance could influence the results.
thank you for the support
