I am trying to get all of the settings in the BQ4050 hammered out for proper operation. Is there a guide that explains what settings are imperative for operation?
My current issue is a persistent cell under-voltage alarm (CUV). I have 2 cells (configured in DA Config), both are above the CUV Recovery voltage, and CUV_RECOV_CHG is not set, but the CUV alarm will not disable. I have also tried switching the CUV_RECOV_CHG bit and applying the charger to no avail.
Do you have any suggestions and is there a document with a setup procedure that I have missed?
Thank you,
Aaron
