Other Parts Discussed in Thread: TPS7A4501-SP, TPS7H1101A-SP
Hello TI,
In the process of testing the RHFL7913 device (FP16 package), I would like to program the current limit for the device. Though datasheet says device is internally programmed to 4A. I would to reduce the current capability to 2A by placing the resistor ( in between 10K to 200K as per datasheet suggestion) between Isc and Vi pins.
Is there any calculation to program the current limit?
Instead doing trail and run.
Thanks in advance.
Swamy M.
