My input is a Lion Battery, the Vpos shows +5V correctly but the -5V is showing 0.6V.
Below is a layout of the part.
I am using 1239AS-H-4R7M as my L1 and L2 inductors.
Could you let have a look and let me know?
My design here is nearly identical to the design of your other customer who submitted the files (essentially the recommended design from the datasheet). I've tested several boards all with the same result. 5 V good Vneg reading about 0.66 V. I looked at the switching frequency at the V neg inductor on my design and it was essentially not running. I don't have a scope capture to post at the moment but can do so later in the week if that provides any insight. Would it help if i provide the date codes on the chips.
Thanks for taking a look at this, I think there was some soldering issue on the board near the -5 side of it.
The issue got resolved when I soldered a New chip. The waveform at the SWN pin looks better compared to the previous posted waveform.
Please do let me know if you still want to take a look at the boards
Anand
