Other Parts Discussed in Thread: BQSTUDIO,
Team,
can the Chemical_ID for the battery be changed only via bqStudio?
If the Chemical_ID needs to be changed from 1210 to 0100 for each unit in serial production, does only the Chemical_ID in BQ28Z610 need to be changed? Is it possible to be done without bqStudio?
How to read the Chemical_ID is clear (AltManufacturerAccess() 0x0006 Chemical ID), question is how to change it?
Thank you
