I'm trying to calculate the OVP resistor values using the data sheet revised June 2017. The given formula is R3 (top resistor) = ((Vout_ovp - 1) / 3.04) x R4 (bottom resistor). The problem is that I can't make the values used in the example schematics match this formula, or in the evaluation board schematic, for that matter. For example, the example resistor values of 1M and 20K respectively give an OVP value of 149V! Does anyone know of a revision to this formula or why the values don't correspond?
