Hi Team,
My customer use TPS2546. It can play when USB insert but it can't connect when phone insert (can't charge and can'r transfer data).
Do you have any advice about this?
Thanks a lot!
Hi Team,
Thanks a lot!
Hi Amelie,
The problem has been solved on the call, I will close this item.
Kevin
If this answers your query, Please click "This resolved my issue" button.
Hi Adam,
I have checked the customer SCH and found it is just because they connect the status/Fault pin with CTL pin. When they disconnect them, it work normal. Thanks for your reply! Many thanks!
