BQSTUDIO: The bq studio tool is broken
Part Number: BQSTUDIO
Other Parts Discussed in Thread: BQ20Z90, BQ40Z50, BQKEYPACKAGER, BQKEYPROGRAMMER
2 issues.
First is using SHA-1 algorithm. The documentation SLUA359 stated that you can enter the security code directly but I find that this doesn't work (please see attached document) the tool will not allow you to enter the proper amount of digits.
second issue (also attached) is that the tool doesn't read back the default key, you only get zeroes. Even if you enter a key you only read back zeroes. Your tool is broken.docx
