Hi Team,
I received an inquiry from one of my customers with regards to the BQ34Z100PWR-G1. Would it be possible to use this for two separate Rsense? This is for BBU application and they wanted to know if they can use this part for separate Rsense for the charger and discharger. They need to ensure that charger and discharger should not turn on at the same time. Hence, they have separate R-sense for each, so that once there is current passing thru the Discharger R-sense, then charger will be turned off.
Thanks!
Alfred
