Part Number: UCC28070
Hello.
Bliss-san
I have additional questions.
Please look at the attached document.
Thank you.
Hello.
Bliss-san
Thank you.
Startup_Glitch.pdfHello Ishii-san,
I can provide some help with this issue.
At startup there is a short pulse for either GDA or GDB and this is followed by a longer off time before normal startup is resumed.
This is a normal occurrence for the UCC28070 and will not cause any systems performance issues because the gate drive signal is so short.
The attached document describes in detail why this occurs.
John
Hello
thank you for your answer.
Q1
Answer: 1 pulse output is not a problem because the pulse width is narrow.
What is the maximum pulse width that does not matter? (How long does the short pulse width extend?)
Q2
Inquired on March 28th,
e2e.ti.com/.../2914995
we made an inquiry regarding Q3 of the attached document.
I have not received an answer.
Thank you.
Hi Masazumi,
This thread question is same with Thread ID: 806414. we can discuss your question in Thread ID: 806414. so, I just close this E2E.
