Part Number: TPS63030
Typical application schematic seemed to be changed on the datasheet as below.
Has any problem ever occurred with VIN-VINA direct connection?
If yes, could you let me know the abstract of problem?
Kuramochi
Kuramochi
Hi Kuramochi,
this was done during a datasheet cleanup. Both connections work and are functional.
With the the open connection between you can have a filter on VINA pin (internal 100 ohm with external C3=~100nF) to make the internal voltage more stable. This will reduce the output ripple.
see also this post: https://e2e.ti.com/support/power-management/f/196/t/807419
Julian
Julian-san,
Thank you for your information.
Problems has never occurred with VIN-VINA direct connection, right?
Kuramochi
Hello Kuramochi-san,
i am not aware of an issue with this connection.
Julian
