TPS61088: What does Co indicate in R5, C5 and C8 calculations for external compensation ( loop stability)?
Part Number: TPS61088
I am using TPS61088 in an application. Please clarify my below query regarding the calculation of passive component values.
What does Co indicate in R5, C5 and C8 calculations? Is it the rated output capacitance or derated output capacitance?
In our application, we are using 3 capacitors having rated capacitance 22uF. The derated capacitance of each capacitor at output voltage is 9.31uF. In this case, what is the value of Co?
Here is the datasheet link for your reference. http://www.ti.com/lit/ds/symlink/tps61088.pdf
Regards.
