UCC21222: Update for Safety Related Certifications
Guru 19645 points
Part Number: UCC21222
UCC21222 datasheet page-1 is described Safety-Related Certifications (Planned).
Please let me know about update status of safety.
For example, Fully compliant, fixed compliant schedule, continue to reviewing, etc.
Satoshi
  • Hello Satoshi-san,
    Thank you for your question. I work on the applications team in the high power drivers group.
    I believe we have an update for this, but let me double check with my team. I’ll will get back to you tomorrow with an answer.
    Thanks and best regards,
    John
  • John-san
    Thank you for quick reply and checking.
    I understood, I looking forward to your answer.
    Satoshi
  • Hi Satoshi,
    We are working on an update to the datasheet now and should release soon. Here’s a quick summary of the update for this section on UCC21222.
    VDE – completed, fully compliant
    UL – completed, fully compliant
    CQC – in progress, should be complete in two months
    CSA – not planned at this moment, we will remove this from the datasheet in the update
    If this answered your question, could you please press the green button? If not, please feel free to ask more questions.
    John
  • John-san
    Thank you for reply,
    About VDE compliant, could you send to me about certification document and certificate number?
    I found UL1577 document(below), but I didn't find VDE document.
    http://www.tij.co.jp/jp/lit/ml/sluq004/sluq004.pdf
    Satoshi
  • Hi Satoshi-san,
    Since we just recently received the certification, we are still in the release process for updating our VDE certificate on TI.com. This should be updated in about a week.
    UCC21222 will fall under this VDE certificate: number 40047657, http://www.ti.com/lit/ml/szzq073o/szzq073o.pdf
    John
  • John-san
    Thank you for information;
    Sorry for last question,
    Is DIN EN61010-1 also certificate and planning to update document?
    Satoshi
  • Hi Satoshi-san,
    Thanks for your question.
    This standard, DIN EN61010, is checked by the VDE certification and will be listed in the certificate when it is released. We will update this in the datasheet as well.
    Is there anything else I can help you with?
    John
  • John-san
    Thank you very much, my question was cleared.
    I looking forward to update web and datasheet.
    Satoshi
  • John-san
    UCC21222 datasheet have not update yet on today.
    Is there latest schedule for update?
    There is not need to hurry, but I want to share information to customer if possible.
    Satoshi
  • Hi Satoshi,
    I apologize for the delay. We plan to update the datasheet after we receive the CQC qualification information. We estimate 1-2 months before the datasheet is updated with all 3 certifications. The certifications should be uploaded on ti.com before then, though.
    Please find attached the VDE certification (P revision) with UCC21222 included.
    szzq073p.pdf
    If this helped answer your question, could you please press the green button? If not, feel free to ask more questions.
    John
