LP87702-Q1: About Watchdog Setting Issue
Part Number: LP87702-Q1
Hi SIr
For Watchdog Setting question
1. if we follow the OTP setting and use enable CLKIN (GPO2) pin to activate Watchdog function .
   http://www.ti.com/lit/df/tidrye2/tidrye2.pdf
2. in Spec Figure 14. Watchdog Operation, it seems we need to send Long Open signal to PMIC after enabling WD (set CLKIN (GPO2) low)
   http://www.ti.com/lit/ds/symlink/lp87702-q1.pdf
Question:
        in HW design , we set CLKIN pin low(resistor to GND) to enable WD. After power-on, CPU starts to work and then send signal to WDI.
        What is the min. time between enabling WD and Send Long-open signal ? if over the time , LongOpenTime expire ?
please advise
BR
Yimin
