TPS2372-4EVM-006: TPS2372-4 software problem
Part Number: TPS2372-4EVM-006
Other Parts Discussed in Thread: TPS2372
Hi, Hello
 as discussion, we understanded that single signature class 0~8 could be implement by class resistor selection as below table in TPS2372 chip.
Please help to confirm dual signature class resistor selection inTPS2372 are as same as single signature. (class 1~class 5).
IPORTER2_PD_BOARD_20190812_Test.pdf
  • Hello Zhao,
    Thank you for your question. Yes the class resistor selection is the same for dual and single signature.
    However, we usually suggest using a higher power PD that uses single signature, and then using the power converter stage to transform the power into your system requirements.
    Michael Pahl
