TPS61165: The way to turn off LED cmpletely
Part Number: TPS61165
In the above thread, I learned to use a Shottky diode to turn off the LED completely. My understanding is that the total VF increases when shottkey dioe is put in forword direction of LED current and I can stop the weak current when the total VF is bigger than VIN. Is it right? Or does it say other usage of shottkey diode?
  • Hi Sir,
         Yes, since in your application, your output voltage is near the supply voltage, so there may be some leakage current through the output side, so I have suggest to add another diode to increase the output voltage. Your understand is right.
    Sean
