Other Parts Discussed in Thread: TPS92692-Q1
I'm looking at a design using the TPS92682-Q1 so for all my designs I generate a spreadsheet.to calculate the values.
As part of this I usually put a know design into my calculations to ensure that my spreadsheet results are working.
I've gone through 8.4.4 of the TPS92682-Q1 Datasheet that describes a Buck-Boost Design Procedure to use this to check my spreadsheet.
When I've got to 8.4.4.4 Inductor selection the value given for L is 23.4 uH
I'm trying to get my spreadsheet to match this but even changing the values to VO , VIN & PO(BDRY) I can't get the values to match.
Is there stored anywhere the original values used for the equations in other examples I've seen on TI datasheets these values are given.
or does anyone have a spreadsheet that will calculate the values for a TPS92682-Q1 ?
