There is a problem that voltage leaks to the source side (OUT pin) at the timing when voltage is applied to the drain side (VS pin).
Please check the following waveform. CH1 is OUT and CH2 is VS.
Is that normal behavior?
If yes, could you tell me the general measures?
If you need to discuss by checking customer's schematic, I would like to contact you via email or private message.
Yuto Sakai
