Hi team,
A customer wants to measure LED current switched by LMG5200. For that they tried using a shunt resistor at PGND. Unfortunately they see higher current on PGND than on SW. For control they need to measure the actual current going to the LED from SW. Measuring on SW is not an option because of time constraints.
Where is the additional current comming from? Is there a pattern to calculate the offset in relation to SW current?
Thank you,
Franz
