We have a DC-DC buck power supply system (LED display driver board) with 48V input and 24V, 12V, 5V outputs.
The 48V input comes from a 1U SPS rectifier and is connected to the led driver board through a 5 meter long cable.
The 48V power equipment supplys 48V all the time, and it happened that the TPS40170 is damaged when the board is powered on by plugged the power cable into the connector's of the borad.
The 24V output is lost, and resumes to work by replacing a new TPS40170 chips.
Pls helps to find out the cause and how to resolve it ,thanks.
