LM3431: Please help to check my circuit is Pass or failure
Part Number: LM3431
Please help to check my circuit is Pass or failure?
if that is failure,Please tell me reason.11-F019_20-20200109.pdf
    For the LM3431:
    There should be a DLY capacitor, the EVM uses 4.7 nF.
    R71, R73, R75 are 5.1 Kohm, if REFIN is 300 mV that gives 59 uA of LED current, this is set at 272 mV so 53 uA.
    R25, R110 do not show values, the schematic is difficult to read.
    Many values are not shown on the schematic.  I would recommend using the datasheet calculations to make sure the design is setup the way you want it to work.
    I add 4.7nF for  DLY capacitor.
    R71, R73, R75 modify to 5.1 ohm
    I am attach files for Bill of  materials and upate schematic.
    The CON1.1pin input +13.5V that is for U7 Power.
    CON4 connection to LED board of ECP1 that current of per LED is 75mA
    The CON1.5pin input +13.5V that is for U7 Power(high DIM).
    CON3 connection to LED board of ECP2 that current of per LED is 75mA.
    The CON1.5pin input +13.5V that is for U7 Power(low DIM) and LED board of ECP2 that current of per LED is 5mA.
    Please help us to check our schematic again.
    ECP2.pdf
    11-F019_20-20200110.pdf
    11-F019_20-20200110.xml
    <?xml version = "1.0" ?>
    <?xml-stylesheet type="text/xsl" href="11-F019_20-20200110.xsl"?>
    <!DOCTYPE GRID [
      <!ELEMENT GRID (BANDS, COLUMNS, ROWS*)>
      <!ATTLIST GRID ExportVersion CDATA #REQUIRED>
      <!ELEMENT BANDS (BAND*)>
      <!ELEMENT BAND EMPTY>
      <!ATTLIST BAND Index CDATA #REQUIRED>
      <!ATTLIST BAND Caption CDATA #IMPLIED>
      <!ELEMENT COLUMNS (COLUMN*)>
      <!ELEMENT COLUMN EMPTY>
      <!ATTLIST COLUMN Name CDATA #REQUIRED>
      <!ATTLIST COLUMN Caption CDATA #IMPLIED>
      <!ATTLIST COLUMN Index CDATA #REQUIRED>
      <!ATTLIST COLUMN BandIndex CDATA #REQUIRED>
      <!ATTLIST COLUMN RowIndex CDATA #REQUIRED>
      <!ATTLIST COLUMN ColIndex CDATA #REQUIRED>
      <!ATTLIST COLUMN Width CDATA #IMPLIED>
      <!ELEMENT GROUP (GROUP*, ROW*)>
      <!ATTLIST GROUP GroupText CDATA #IMPLIED>
      <!ELEMENT ROWS (ROW*)>
      <!ELEMENT ROW EMPTY>
      <!ATTLIST ROW Comment CDATA #IMPLIED>
      <!ATTLIST ROW Description CDATA #IMPLIED>
      <!ATTLIST ROW Designator CDATA #IMPLIED>
      <!ATTLIST ROW Footprint CDATA #IMPLIED>
      <!ATTLIST ROW LibRef CDATA #IMPLIED>
      <!ATTLIST ROW Quantity CDATA #IMPLIED>
    <GRID ExportVersion="1.0">
      <BANDS>
        <BAND Index="0" Caption=""></BAND>
      </BANDS>
      <COLUMNS>
        <COLUMN Name="Comment" Caption="Comment" Index="0" BandIndex="0" RowIndex="0" ColIndex="0" Width="100"></COLUMN>
        <COLUMN Name="Description" Caption="Description" Index="1" BandIndex="0" RowIndex="0" ColIndex="1" Width="100"></COLUMN>
        <COLUMN Name="Designator" Caption="Designator" Index="2" BandIndex="0" RowIndex="0" ColIndex="2" Width="100"></COLUMN>
        <COLUMN Name="Footprint" Caption="Footprint" Index="3" BandIndex="0" RowIndex="0" ColIndex="3" Width="100"></COLUMN>
        <COLUMN Name="LibRef" Caption="LibRef" Index="4" BandIndex="0" RowIndex="0" ColIndex="4" Width="100"></COLUMN>
        <COLUMN Name="Quantity" Caption="Quantity" Index="5" BandIndex="0" RowIndex="0" ColIndex="5" Width="100"></COLUMN>
      </COLUMNS>
      <ROWS>
        <ROW Comment="0.1uF/50V,0805" Description="0.1uF/50V, 10&#37; , X7R, 0805" Designator="C1, C9, C39" Footprint="SMD-C0805H0125" LibRef="S1040500C0805H0125" Quantity="3"></ROW>
        <ROW Comment="10uF/50V,1206" Description="10uF/50V, 10&#37;, X7R, 1206" Designator="C3, C5, C8, C11, C45, C46, C77" Footprint="SMD-C1206H0160" LibRef="S1060500C1206H0160" Quantity="7"></ROW>
        <ROW Comment="0.1uF/50V,1206" Description="0.1uF/50V, SMD1206" Designator="C4" Footprint="SMD-C1206H0115" LibRef="S10405001206H0115" Quantity="1"></ROW>
        <ROW Comment="2.2uF/50V,1206" Description="10uF/50V, 10&#37;, X7R, 1206" Designator="C6, C7, C76" Footprint="SMD-C1206H0160" LibRef="S1060500C1206H0160" Quantity="3"></ROW>
        <ROW Comment="47uF,6.3mm,35V" Description="CHIP ELECTROLYTIC CAPACITOR" Designator="C10, C14, C68" Footprint="SMD-EC 6.3 X 7.7" LibRef="CEC" Quantity="3"></ROW>
        <ROW Comment="0.1uF,0805" Description="Chip&#38651;&#23481;, 1000pF/50V, 10&#37;, X7R, SMD0805" Designator="C12, C61, C64, C65, C67" Footprint="C0805" LibRef="C" Quantity="5"></ROW>
        <ROW Comment="10uF,1206" Description="Capacitor" Designator="C13, C60, C63, C66" Footprint="C1206" LibRef="Cap" Quantity="4"></ROW>
        <ROW Comment="4700pF/50V, 10&#37;, X7RV, SMD0805" Description="4700pF/50V, 10&#37;, X7RV, SMD0805" Designator="C15, C16" Footprint="SMD-C0805H0085" LibRef="S47205000805H0085" Quantity="2"></ROW>
        <ROW Comment="56nF/50V 10&#37;, X7R SMD0603" Description="56nF/50V 10&#37;, X7R SMD0603" Designator="C20, C23, C25, C35" Footprint="SMD-C0603H0080" LibRef="S56305000603H0080" Quantity="4"></ROW>
        <ROW Comment="0.01uF/50V, 10&#37;, X7R, SMD0603" Description="0.01uF/50V, 10&#37;, X7R, SMD0603" Designator="C21, C26, C27" Footprint="SMD-C0603H0080" LibRef="S10305000603H0080" Quantity="3"></ROW>
        <ROW Comment="10uF/50V, 10&#37;, X7R, 1206" Description="10uF/50V, 10&#37;, X7R, 1206" Designator="C22, C32" Footprint="SMD-C1206H0160" LibRef="S1060500C1206H0160" Quantity="2"></ROW>
        <ROW Comment="0.1uF/50V, 10&#37;, X7R, SMD0603&#40;YAGEO&#41;" Description="0.1uF/50V, 10&#37;, X7R, SMD0603&#40;YAGEO&#41;" Designator="C24, C31, C62" Footprint="SMD-C0603H0080" LibRef="S10405000603H0080" Quantity="3"></ROW>
        <ROW Comment="1uF/50V,1206" Description="1uF/50V, 10&#37;, X7R, 1206" Designator="C44" Footprint="SMD-C1206H0160" LibRef="S1050500C1206H0160" Quantity="1"></ROW>
        <ROW Comment="0.01uF/50V, 10&#37;, X7R, SMD0805" Description="0.01uF/50V, 10&#37;, X7R, SMD0805" Designator="C73" Footprint="SMD-C0805H0085" LibRef="S10305000805H0085" Quantity="1"></ROW>
        <ROW Comment="1x6Pins Header" Description="1x6Pins Header 2.54mm" Designator="CON1" Footprint="DIP-1X6PIN-177" LibRef="DIP-1x6Pins Header 2.54mm" Quantity="1"></ROW>
        <ROW Comment="2060PS 8Pins Straight" Description="2060PS 8Pins Straight" Designator="CON3" Footprint="SMD-2060PS-07" LibRef="SMD-2060PS-08" Quantity="1"></ROW>
        <ROW Comment="2060PR 6Pins Right-Angle" Description="2060PR 6Pins Right-Angle" Designator="CON4" Footprint="SMD-2060PR-06" LibRef="SMD-2060PR-06" Quantity="1"></ROW>
        <ROW Comment="SM3100A-Q" Description="SM3100A-H, 20-100V/3A Schottky Diode" Designator="D1, D4, D9, D29, D30, Q7" Footprint="SMD-SMA/DO-214AC" LibRef="DIODE-SM3100A-H" Quantity="6"></ROW>
        <ROW Comment="D5V100SP, TO-277" Description="D5V100SP, 5A 100V Schottky Retifiers" Designator="D2, D6" Footprint="SMD-TO277" LibRef="DIODE-D5V100SP" Quantity="2"></ROW>
        <ROW Comment="1N4148WSFL, SMA" Description="1N4148WSFL, SMA" Designator="D5, D8, D11, D12, D13, D14, D15, D16, D17, D18, D19, D20, D26, D27" Footprint="SMD-SMA/DO-214AC" LibRef="DIODE-1N4148WSFL" Quantity="14"></ROW>
        <ROW Comment="IMI1040-220M 22uH" Description="IMI1040-220M 22uH" Designator="L1, L5" Footprint="SMD-IMI1040" LibRef="SMD-IMI1040-220M" Quantity="2"></ROW>
        <ROW Comment="IMI0650-330M 33uH" Description="IMI0650-330M 33uH" Designator="L2" Footprint="SMD-IMI0650" LibRef="SMD-IMI0650-330M" Quantity="1"></ROW>
        <ROW Comment="FCM7060-701" Description="FCM7060-701" Designator="L6" Footprint="SMD-ACM70V" LibRef="SMD-FCM7060-701" Quantity="1"></ROW>
        <ROW Comment="FNR6045-100MA 10uH" Description="FNR6045-100MA 10uH,20&#37;" Designator="L7" Footprint="SMD-FNR5040" LibRef="SMD-FNR6045-100MA" Quantity="1"></ROW>
        <ROW Comment="FCM5040-102B" Description="FCM5040-102B" Designator="L9" Footprint="SMD-FCM5040" LibRef="SMD-FCM5040-102B" Quantity="1"></ROW>
        <ROW Comment="CM100805-601" Description="&#21151;&#29575;&#38651;&#24863;" Designator="L17, L19" Footprint="SMD-CM100805-601" LibRef="Trans Adj" Quantity="2"></ROW>
        <ROW Comment="EMB26N10A, TO252" Description="EMB26N10A, N-Channel MOSFET" Designator="Q1, Q5" Footprint="SMD-TO252-GDS" LibRef="MOSFET EMB26N10A" Quantity="2"></ROW>
        <ROW Comment="BCP56-16, SOT223" Description="&#38651;&#26230;&#39636;,NXP_BCP56-16 &#40;SOT-223&#41;" Designator="Q2, Q3, Q6, Q8, Q9, Q12" Footprint="SMD-SOT223-BCE" LibRef="TR-BCP56-16" Quantity="6"></ROW>
        <ROW Comment="ZVP1320F, SOT-23" Description="ZVP1320F, P-Channel MOSFET" Designator="Q4" Footprint="SMD-SOT23-GDS" LibRef="MOSFET ZVP1320F" Quantity="1"></ROW>
        <ROW Comment="EMB55N03J, SOT-23" Description="EMB55N03J, N-Channel MOSFET" Designator="Q11" Footprint="SMD-SOT23-GDS" LibRef="MOSFET EMB55N03J" Quantity="1"></ROW>
        <ROW Comment="180K,0805" Description="180K, 1&#37;, 0805, 0.5mm" Designator="R1" Footprint="SMD-R0805H050" LibRef="S180K0805H050P01" Quantity="1"></ROW>
        <ROW Comment="10K,0805" Description="10K, 5&#37;, 0805, 0.5mm" Designator="R2" Footprint="SMD-R0805H050" LibRef="S10K0805H050P05" Quantity="1"></ROW>
        <ROW Comment="0.3R,1206" Description="1.5R, 1&#37;, 1206, 0.55mm" Designator="R3" Footprint="SMD-R1206H055" LibRef="S1P5R1206H055P01" Quantity="1"></ROW>
        <ROW Comment="DNE" Description="1.5R, 1&#37;, 1206, 0.55mm" Designator="R4" Footprint="SMD-R1206H055" LibRef="S1P5R1206H055P01" Quantity="1"></ROW>
        <ROW Comment="3.3R, 1&#37;, SMD0805" Description="3.3R, 1&#37;, 0805, 0.5mm" Designator="R5, R27" Footprint="SMD-R0805H050" LibRef="S3P3R0805H050P01" Quantity="2"></ROW>
        <ROW Comment="0.2R, 1&#37;, 1206" Description="0.2R, 1&#37;, 1206, 0.55mm" Designator="R7, R8, R26, R31" Footprint="SMD-R1206H055" LibRef="S0P2R1206H055P01" Quantity="4"></ROW>
        <ROW Comment="6.2K, 1&#37;, SMD0805" Description="6.2K, 1&#37;, 0805, 0.5mm" Designator="R12, R32" Footprint="SMD-R0805H050" LibRef="S6P2K0805H050P01" Quantity="2"></ROW>
        <ROW Comment="220K, 5&#37;, SMD0805" Description="220K, 5&#37;, 0805, 0.5mm" Designator="R17, R19" Footprint="SMD-R0805H050" LibRef="S220K0805H050P05" Quantity="2"></ROW>
        <ROW Comment="10K" Description="100K, 5&#37;, 1206, 0.55mm" Designator="R18" Footprint="SMD-R1206H055" LibRef="S100K1206H055P05" Quantity="1"></ROW>
        <ROW Comment="47K" Description="100K, 5&#37;, 1206, 0.55mm" Designator="R20" Footprint="SMD-R1206H055" LibRef="S100K1206H055P05" Quantity="1"></ROW>
        <ROW Comment="91K" Description="100K, 5&#37;, 1206, 0.55mm" Designator="R22, R36" Footprint="SMD-R1206H055" LibRef="S100K1206H055P05" Quantity="2"></ROW>
        <ROW Comment="13K, 1&#37;, SMD0805" Description="13K, 1&#37;, 0805, 0.5mm" Designator="R23, R28" Footprint="SMD-R0805H050" LibRef="S13K0805H050P01" Quantity="2"></ROW>
        <ROW Comment="10K, 1&#37;, SMD0805" Description="10K, 1&#37;, 0805, 0.5mm" Designator="R24, R25, R34, R37, R119" Footprint="SMD-R0805H050" LibRef="S10K0805H050P01" Quantity="5"></ROW>
        <ROW Comment="13K" Description="100K, 5&#37;, 1206, 0.55mm" Designator="R30" Footprint="SMD-R1206H055" LibRef="S100K1206H055P05" Quantity="1"></ROW>
        <ROW Comment="100K" Description="100K, 5&#37;, 1206, 0.55mm" Designator="R33" Footprint="SMD-R1206H055" LibRef="S100K1206H055P05" Quantity="1"></ROW>
        <ROW Comment="56K, 5&#37;, SMD0805" Description="56K, 5&#37;, 0805, 0.5mm" Designator="R35" Footprint="SMD-R0805H050" LibRef="S56K0805H050P05" Quantity="1"></ROW>
        <ROW Comment="82K, 1&#37;, SMD0805" Description="82K, 1&#37;, 0805, 0.5mm" Designator="R39, R110" Footprint="SMD-R0805H050" LibRef="S82K0805H050P01" Quantity="2"></ROW>
        <ROW Comment="1K, 5&#37;, SMD0805" Description="1K, 5&#37;, 0805, 0.5mm" Designator="R40, R54, R103" Footprint="SMD-R0805H050" LibRef="S1K0805H050P05, S1K0805H050P05, S15K0805H050P05" Quantity="3"></ROW>
        <ROW Comment="20K, 5&#37;, SMD0805" Description="20K, 5&#37;, 0805, 0.5mm" Designator="R41, R61" Footprint="SMD-R0805H050" LibRef="S20K0805H050P05" Quantity="2"></ROW>
        <ROW Comment="150R, 5&#37;, SMD0805" Description="150R, 5&#37;, 0805, 0.5mm" Designator="R43, R53, R56, R70, R76, R87" Footprint="SMD-R0805H050" LibRef="S150R0805H050P05" Quantity="6"></ROW>
        <ROW Comment="9.1K, 1&#37;, SMD0805" Description="9.1K, 1&#37;, 0805, 0.5mm" Designator="R44" Footprint="SMD-R0805H050" LibRef="S9P1K0805H050P01" Quantity="1"></ROW>
        <ROW Comment="100K, 5&#37;, SMD0805" Description="100K, 5&#37;, 0805, 0.5mm" Designator="R62, R65, R105" Footprint="SMD-R0805H050" LibRef="S100K0805H050P05" Quantity="3"></ROW>
        <ROW Comment="51K, 5&#37;, SMD0805" Description="51K, 5&#37;, 0805, 0.5mm" Designator="R64" Footprint="SMD-R0805H050" LibRef="S51K0805H050P05" Quantity="1"></ROW>
        <ROW Comment="5.1R, 5&#37;, SMD1206" Description="5.1R, 5&#37;, 1206, 0.55mm" Designator="R69, R71, R72, R73, R74, R75" Footprint="SMD-R1206H055" LibRef="S5P1R1206H055P05" Quantity="6"></ROW>
        <ROW Comment="3.9R, 1&#37;, SMD1206" Description="3.9R, 1&#37;, 1206, 0.55mm" Designator="R90, R92, R101" Footprint="SMD-R1206H055" LibRef="S3P9R1206H055P01" Quantity="3"></ROW>
        <ROW Comment="4.3R, 1&#37;, SMD1206" Description="4.3R, 1&#37;, 1206, 0.55mm" Designator="R91, R93, R102" Footprint="SMD-R1206H055" LibRef="S4P3R1206H055P01" Quantity="3"></ROW>
        <ROW Comment="100K, 5&#37;, SMD1206" Description="100K, 5&#37;, 1206, 0.55mm" Designator="R99" Footprint="SMD-R1206H055" LibRef="S100K1206H055P05" Quantity="1"></ROW>
        <ROW Comment="0R, 5&#37;, SMD0805" Description="0R, 5&#37;, 0805, 0.5mm" Designator="R100, R108" Footprint="SMD-R0805H050" LibRef="S0R0805H050P05" Quantity="2"></ROW>
        <ROW Comment="10K" Description="1K, 1&#37;, 0805, 0.5mm" Designator="R106" Footprint="SMD-R0805H050" LibRef="S1K0805H050P01" Quantity="1"></ROW>
        <ROW Comment="0" Description="220K, 5&#37;, 0805, 0.5mm" Designator="R109" Footprint="SMD-R0805H050" LibRef="S220K0805H050P05" Quantity="1"></ROW>
        <ROW Comment="20K" Description="100K, 5&#37;, 1206, 0.55mm" Designator="R117" Footprint="SMD-R1206H055" LibRef="S100K1206H055P05" Quantity="1"></ROW>
        <ROW Comment="100K, 5&#37;, SMD2010" Description="100K, 5&#37;, 2010, 0.55mm" Designator="R200, R201, R202" Footprint="SMD-R2010H055" LibRef="S100K2010H055P05" Quantity="3"></ROW>
        <ROW Comment="20K, 5&#37;, SMD2010" Description="20K, 5&#37;, 2010, 0.55mm" Designator="R203" Footprint="SMD-R2010H055" LibRef="S20K2010H055P05" Quantity="1"></ROW>
        <ROW Comment="A6213," Description="Allegro A6213, SOIC-8" Designator="U1" Footprint="SMD-SOP8-G" LibRef="IC-A6213" Quantity="1"></ROW>
        <ROW Comment="LM3431, TSSOP28" Description="LM3431, TSSOP28" Designator="U2, U7" Footprint="SMD-TSSOP-28" LibRef="IC-LM3431" Quantity="2"></ROW>
        <ROW Comment="BSP752T, SOP8" Description="BSP752T, SOP8" Designator="U5" Footprint="SMD-SOP8" LibRef="IC-BSP752T" Quantity="1"></ROW>
        <ROW Comment="SMBJ26CA,SMB/DO-214AA" Description="SMBJ26CA, 26V TVS" Designator="VR1, VR2, VR3, VR4" Footprint="SMD-SMB/DO-214AA" LibRef="DIODE-SMBJ26CA" Quantity="4"></ROW>
      </ROWS>
    </GRID>
  • Hello Victor,
    I sent you an email to take this off of e2e.
