Hi Team,
In "7.3 Recommended Operating Conditions" of datasheet, there is VIH, VIL and VO.
What does the VO means, VOL or VOH? I want to know the VOL and VOH.
Tom Liu
Hi Tom,
You can take this VO as voltage supply of LED minus LED forward voltage. What is your meaning of VOL and VOH? High-level and low-level of output voltage? I think the voltage range of output pins relate the output current you set and voltage supply of LED. You can refer Figure 2 in datasheet.
