Other Parts Discussed in Thread: TPS22975
Hi
If TPS22965 Vout is short to GND, will it take any protection, due to no OTP/OCP inside? There is a discharge resistor internally. If pin 3 (ON) is High, and test SCP, will TPS22965 protect? or the protection depends on upstream VR OCP?
Guessed on this case, the discharge resistor is off because ON pin high, right?
