BQSTUDIO: An error has occured. See the log file (BQSTUDIO-TEST_1.3.100.1)
Part Number: BQSTUDIO
Other Parts Discussed in Thread: BQ25710EVM-017,
Hi TI,
Our team just got the BQ25710EVM-017 and wanted to test the board with the bqstudio software. The stable version didn't support this charger so we got to the e2e forum and it was advised to download the bq studio test version.
Starting up the test version results in an error. I attached the log file.
Do you have a solution for this?
!SESSION 2020-03-31 14:25:46.648 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_74
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=nl_NL
Framework arguments:  -clearPersistedState -persistState false
Command-line arguments:  -os win32 -ws win32 -arch x86 -clearPersistedState -persistState false
!ENTRY com.ti.evswsdk 4 0 2020-03-31 14:25:48.760
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk [190]
  Unresolved requirement: Import-Package: com.ti.evswsdk.dashboard
    -> Export-Package: com.ti.evswsdk.dashboard; bundle-symbolic-name="com.ti.evswsdk.dashboard"; bundle-version="1.2.0.202002211139"; version="0.0.0"
       com.ti.evswsdk.dashboard [219]
         Unresolved requirement: Import-Package: com.ti.evswsdk.gpcpackager.views
	at org.eclipse.osgi.container.Module.start(Module.java:434)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1561)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY com.ti.evswsdk.authentication 4 0 2020-03-31 14:25:48.765
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.authentication [193]
!ENTRY com.ti.evswsdk.calbq769x2 4 0 2020-03-31 14:25:48.767
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.calbq769x2 [200]
  Unresolved requirement: Import-Package: com.ti.evswsdk.programming769x2
    -> Export-Package: com.ti.evswsdk.programming769x2; bundle-symbolic-name="com.ti.evswsdk.programming769x2"; bundle-version="1.0.0.202002211139"; version="0.0.0"; uses:="org.osgi.framework,  org.eclipse.swt.graphics,  org.eclipse.jface.resource,  org.eclipse.swt.widgets,  org.eclipse.jface.dialogs,  org.eclipse.ui.plugin"
       com.ti.evswsdk.programming769x2 [253]
!ENTRY com.ti.evswsdk.cmdsequence 4 0 2020-03-31 14:25:48.769
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.cmdsequence [216]
!ENTRY com.ti.evswsdk.dashboard 4 0 2020-03-31 14:25:48.772
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.dashboard [219]
!ENTRY com.ti.evswsdk.dataflashview 4 0 2020-03-31 14:25:48.774
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.dataflashview [220]
  Unresolved requirement: Import-Package: com.ti.evswsdk.fsexport
    -> Export-Package: com.ti.evswsdk.fsexport; bundle-symbolic-name="com.ti.evswsdk.fsexport"; bundle-version="1.0.0.202002211139"; version="0.0.0"
       com.ti.evswsdk.fsexport [228]
!ENTRY com.ti.evswsdk.fieldprogrammer 4 0 2020-03-31 14:25:48.777
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.fieldprogrammer [226]
!ENTRY com.ti.evswsdk.firmware 4 0 2020-03-31 14:25:48.779
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.firmware [227]
!ENTRY com.ti.evswsdk.fsexport 4 0 2020-03-31 14:25:48.796
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.fsexport [228]
!ENTRY com.ti.evswsdk.gdk 4 0 2020-03-31 14:25:48.799
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.gdk [230]
  Unresolved requirement: Import-Package: com.ti.evswsdk.dataflashview
    -> Export-Package: com.ti.evswsdk.dataflashview; bundle-symbolic-name="com.ti.evswsdk.dataflashview"; bundle-version="1.3.0.202002211139"; version="0.0.0"
!ENTRY com.ti.evswsdk.goldenizing 4 0 2020-03-31 14:25:48.802
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.goldenizing [233]
!ENTRY com.ti.evswsdk.programming769x2 4 0 2020-03-31 14:25:48.806
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.programming769x2 [253]
!ENTRY com.ti.evswsdk.fsexport 2 0 2020-03-31 14:25:49.348
!MESSAGE Could not resolve module: com.ti.evswsdk.fsexport [228]
!ENTRY com.ti.evswsdk.gdk 2 0 2020-03-31 14:25:49.351
!MESSAGE Could not resolve module: com.ti.evswsdk.gdk [230]
!ENTRY com.ti.evswsdk.calbq769x2 2 0 2020-03-31 14:25:49.353
!MESSAGE Could not resolve module: com.ti.evswsdk.calbq769x2 [200]
!ENTRY com.ti.evswsdk.dashboard 2 0 2020-03-31 14:25:49.356
!MESSAGE Could not resolve module: com.ti.evswsdk.dashboard [219]
!ENTRY com.ti.evswsdk.cmdsequence 2 0 2020-03-31 14:25:49.358
!MESSAGE Could not resolve module: com.ti.evswsdk.cmdsequence [216]
!ENTRY com.ti.evswsdk.dataflashview 2 0 2020-03-31 14:25:49.360
!MESSAGE Could not resolve module: com.ti.evswsdk.dataflashview [220]
!ENTRY com.ti.evswsdk.fieldprogrammer 2 0 2020-03-31 14:25:49.363
!MESSAGE Could not resolve module: com.ti.evswsdk.fieldprogrammer [226]
!ENTRY com.ti.evswsdk.firmware 2 0 2020-03-31 14:25:49.365
!MESSAGE Could not resolve module: com.ti.evswsdk.firmware [227]
!ENTRY com.ti.evswsdk.authentication 2 0 2020-03-31 14:25:49.367
!MESSAGE Could not resolve module: com.ti.evswsdk.authentication [193]
!ENTRY com.ti.evswsdk.goldenizing 2 0 2020-03-31 14:25:49.369
!MESSAGE Could not resolve module: com.ti.evswsdk.goldenizing [233]
!ENTRY com.ti.evswsdk 2 0 2020-03-31 14:25:49.371
!MESSAGE Could not resolve module: com.ti.evswsdk [190]
!ENTRY com.ti.evswsdk.programming769x2 2 0 2020-03-31 14:25:49.374
!MESSAGE Could not resolve module: com.ti.evswsdk.programming769x2 [253]
!ENTRY org.eclipse.osgi 4 0 2020-03-31 14:25:49.407
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "com.ti.evswsdk.evswsdk" could not be found in the registry. The applications available are: org.eclipse.e4.ui.workbench.swt.E4Application, org.eclipse.e4.ui.workbench.swt.GenTopic, org.eclipse.equinox.app.error, org.eclipse.help.base.infocenterApplication, org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool.
	at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
	at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
