LP5569: Linux drive control LP5569
Part Number: LP5569
Hi sir,to
We want use Linux driver to control Lp5569,but we do not want use CPU to do this .We want use I2C to transmit HEX to  LP5569 to control it,but we can not transmit variate with I2C BUS when  we want to control led flash time.How can I control led flash time with Linux driver?
Thank you.
    For confirmation, you mentioned that cannot control LED flash time is cannot turn on LED by the engine control function? Is your system OK to do other basic control like turn on the LED? Could you share the HEX code and whole procedure?
