Audible noise can be heard near the IC when taper charging.
Is there a cause and solution?
The frequency of the audible noise is about 6.7 kHz.
The schematics and constants are basically created by referring to datasheets and EVMs.
When it shifts to tapered charge, the I2C control squeezes the charge current to make it inaudible.
If this problem can be solved by replacing the value or variety of the parts, I would prefer that.
File attached.
Thank you very much.
schematic_bq25887.pdf
