Other Parts Discussed in Thread: BQ40Z50,
I'm facing the same issue with the VOC75, VOC50, VOC25 parameters. How can i solve it?
Hello Gabriele,
It seems that the BQ40Z50 does not use those parameters to calibrate RSOC anymore. I would recommend you read the BQ40Z50 EVM's User Guide(Section 3.3) to see how to calibrate your BQ40Z50.
Luis Hernandez Salomon
The bq40z50 uses the impedance track for fuel gauging and hence a laearning cycle is to be performed.
In my application I'm using the bq4050 which implements the CEDV algorithm. The technical reference talks about VOC75, VOC50 and VOC25 midrange parameters. How can i set this parameters?
Hello Gabriele,
For the BQ4050, you can ignore those three parameters. They seem to not be in use anymore.
