UCC28950: Simulation and datasheet
Part Number: UCC28950
I am trying to simulate PSFB based on UCC28950. According to datasheet, if ,  VADEL = 1.8 , VTABSET can be programmed between 29 ns and 155 ns:. In my simulation I set RAHI=8.25k and RA=4.64k. RAHI is connected to VREF. RAB and RCD are 13k (minimum value according to datasheet) but delay between outputs A and B is 270ns. To reduce this delay I need to reduce RAB and RCD to 7k (but this is restricted by datasheet). In this case the delay drops to 125ns. Could you,please, explain this.  I use unencrypted UCC28950 model, provided by TI. Simulator - Simetrix.
    The ADEL pin and the ADELF pins are generally set to less than 2V.  It looks like you are trying to use the fix delay approach in your design.
    I just believe the high voltage on the ADEL pin is causing the timing to be off.
    The following link will get you to an application note that goes over the fixed delay approach.  Equations 122 through 125 are the ones that you are interested in for setting up the fixed delays and timing.
    My question is, that delay time in simulation does not match calculation. Please see attached  xls file.
    Lev8802.UCC28950.xlsx
    I reviewed the data sheet and for your resistor values you should have a delay of about 290 ns.
    TAB = (5*63.9/(0.26+1.8*0.359*1.3) = 290 ns.  I do see that your result is 1us which is way off.
    You had mentioned that you were using Simetrex for the simulation, which is Simplis.  There is a TI-Tina model and PSpice model.  Do these models have the same error?  I am just wondering if there is an issue trying to simulate a Tina model or a PSpice model in Simplis.
    Thank you for reply. I am using Simetrix which is SPICE simulator. I am not using SIMPLIS  for this simulation (SIMPLIS does not accept SPICE models). I attached UCC28950 model  which I am using. This model was obtained from TI. I could send you the whole simulation file , but your email does not allow to do this. Because of this I also attached Net List for my simulation.
    Lev
    UCC28950_NetList.txt
    * UCC28950
    * (C) Copyright 2019 Texas Instruments Incorporated. All rights reserved.
    ** This model is designed as an aid for customers of Texas Instruments.
    ** TI and its licensors and suppliers make no warranties, either expressed
    ** or implied, with respect to this model, including the warranties of
    ** merchantability or fitness for a particular purpose.  The model is
    ** provided solely on an "as is" basis.  The entire risk as to its quality
    ** and performance is with the customer
    * This model is subject to change without notice. Texas Instruments
    * Incorporated is not responsible for updating this model.
    ** Released by: Texas Instruments Inc.
    * Part: UCC28950
    * Date: 19JUL2019
    * Model Type: TRANSIENT
    * Simulator: PSPICE
    * Simulator Version: 16.2.0.p001
    * EVM Order Number: UCC28950EVM-442
    * EVM Users Guide: SLUU421A�May 2010�Revised May 2010
    * Datasheet: SLUSA16D �MARCH 2010�REVISED NOVEMBER 2016
    * Topologies Supported: Buck
    * Model Version: Final 1.2
    * Updates:
    * Final 1.2
    * 1. The following features have been are newly modeled or fixed.
    *      a. Hiccup mode (Current Limit functionality).
    *      b. Soft Start voltage pull up.
    *      c. SYNC Pin fuctionality.
    * Final 1.10
    * Updated model to fix Burst Mode
    * Final 1.00
    * Release to Web.
    * Model Usage Notes:
    * 1. The following features have been modeled
    *      a. MIN ON timer.
    *      b. Voltge mode and Current mode.
    *      c. Master and Slave mode.
    * 2. Temperature effects are not modeled.
    .SUBCKT UCC28950_TRANS ADEL ADELEF COMP CS DCM DELAB DELCD DELEF EAM EAP GND OUTA
    +  OUTB OUTC OUTD OUTE OUTF RSUM RT SSEN SYNC TMIN VDD VREF
    R_U4_R2         DCM U4_N134058  77K
    X_U4_U885         CLK U4_N138708 U4_N140048 NOR2_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U4_U10          U4_N133974 U4_N134058 U4_N134506 COMPARATOR
    C_U4_C2         0 U4_N134058  1.37p IC=0
    X_U4_U887         U4_N140048 U4_N924283 TMINP AND2_BASIC_GEN PARAMS: VDD=1
    +  VSS=0 VTHRESH=500E-3
    G_U4_G3         0 U4_N138089 U4_TMIN_I 0 1
    V_U4_V1         U4_N150346 0 2
    X_U4_U18          U4_N144772 MS COMP_HYS2 PARAMS:  TH=1 HYS=1  T=10
    X_U4_U888         U4_N145738 U4_N134506 U4_N145189 AND2_BASIC_GEN PARAMS: VDD=1
    C_U4_C3         U4_N133974 0  1.37p
    R_U4_R1         CS U4_N133974  77K
    X_U4_U889         U4_N134506 U4_N9250570 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U4_D1         U4_N132128 VREFBUF GEN_DIODE
    I_U4_I1         VREFBUF U4_N132128 DC 25u
    X_U4_U886         FAULT U4_N924283 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    G_U4_G2         U4_N144772 0 U4_N147222 0 0.1
    X_U4_D4          U4_N144772 U4_N150346 DC_1mV_1A_1V_1nA
    C_U4_C5         0 U4_N144772  1n IC=0
    E_U4_ABM1         U4_I_TMIN 0 VALUE { V(U4_TMIN_I)    }
    X_U4_S7    CLK U4_N138089 DCMTMIN_U4_S7
    E_U4_ABM2         U4_N911725 0 VALUE {
    +  (((V(VREFBUF)/V(U4_I_TMIN))/1000)*5.92)*0.000000001    }
    X_U4_U891         MS U4_N152056 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U4_S6    U4_N152056 0 U4_N132128 DCM DCMTMIN_U4_S6
    X_U4_U883         U4_N138089 U4_V_TMIN U4_N138606 COMP_BASIC_GEN PARAMS: VDD=1
    +  VSS=0 VTHRESH=0.5
    X_U4_U890         U4_N145738 U4_N9250570 U4_N147222 AND2_BASIC_GEN PARAMS:
    +  VDD=1 VSS=0 VTHRESH=500E-3
    X_U4_U15         PWMN U4_N145738 ONE_SHOT PARAMS:  T=10
    X_U4_D2         U4_N138089 VREFBUF GEN_DIODE
    G_U4_G1         0 U4_N144772 U4_N145189 0 0.1
    E_U4_ABM4         R_TMIN 0 VALUE { V(VREFBUF)/V(U4_TMIN_I)    }
    X_U4_H1    VREFBUF TMIN U4_TMIN_I 0 DCMTMIN_U4_H1
    X_U4_U884         CLKN U4_N138606 U4_N138708 AND2_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U4_D5          0 U4_N144772 DC_1mV_1A_1V_1nA
    E_U4_ABM3         U4_V_TMIN 0 VALUE { ( V(U4_I_TMIN)/11.84p)*V(U4_N911725)
    C_U4_C4         0 U4_N138089  11.84p IC=0
    X_U6_U2         PWM 0 U6_U1Q TRFF_RDOM
    X_U6_U26         QNB QA INV_BASIC_GEN PARAMS: VDD=1 VSS=0 VTHRESH=500E-3
    X_U6_U28         U6_U1Q PWM TD XOR2_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U6_U3         PWM 0 U6_N915416 TRFF_RDOM
    X_U6_U23         U6_U1Q U6_N911991 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U6_U25         C QNB QE OR2_BASIC_GEN PARAMS: VDD=1 VSS=0 VTHRESH=500E-3
    X_U6_U27         U6_N911991 PWM TC XOR2_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    R_U6_R1         U6_N915416 QNB  1
    X_U6_U24         D QA QNF OR2_BASIC_GEN PARAMS: VDD=1 VSS=0 VTHRESH=500E-3
    X_U2_U70         U2_SYNC_IN HICCUP_FAULT_BAR U2_N15287352 AND2_BASIC_GEN
    +  PARAMS: VDD=1 VSS=0 VTHRESH=500E-3
    C_U2_C1         0 U2_VOSC  1n IC=0
    V_U2_V1         U2_N919276 0 0.460
    X_U2_U52         U2_N15268993 U2_SLAVE_B INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U2_U68         U2_N15307604 U2_N15323663 BUF_DELAY_BASIC_GEN PARAMS: VDD=1
    +  VSS=0 VTHRESH=0.5 DELAY=1n
    X_U2_U57         U2_N15287352 U2_N15289807 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U2_H1    U2_N47785 RT U2_SLAVE_IN 0 OSC_U2_H1
    X_U2_U72         HICCUP_FAULT_BAR U2_N15273433 U2_N15421955 AND2_BASIC_GEN
    X_U2_U38         0 U2_TIME_PERIOD D_D1
    R_U2_R6         0 U2_SYNC_IN  1e6
    X_U2_U23          U2_SLAVE_IN SLAVE COMPARATOR2 PARAMS:  TH=0
    E_U2_ABM1         U2_N15269089 0 VALUE { IF(V(U2_N15268959) > 0.5,1,0)    }
    E_U2_ABM11         U2_N15268963 0 VALUE { IF(V(U2_SYNC_IN)>2.5,1,0)    }
    X_U2_U69         U2_N15323663 U2_N15309112 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U2_U33         U2_N14968918 U2_SYNC_IN U2_N14969162 AND2_BASIC_GEN PARAMS:
    X_U2_U36         U2_N14969162 U2_HICCUP_EN_OK U2_N14973647 N14974079
    +  SRLATCHRHP_BASIC_GEN PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    X_U2_U66         U2_N15309096 U2_N15309112 U2_N15309116 AND2_BASIC_GEN PARAMS:
    X_U2_U67         U2_N15309116 FAULT TIME_2ND N15316995 SRLATCHRHP_BASIC_GEN
    +  PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    X_U2_U78         U2_SLAVE_B U2_N15432319 U2_N15274019 OR2_BASIC_GEN PARAMS:
    C_U2_C3         U2_TIME_PERIOD 0  1n IC=0
    E_U2_ABM6         U2_N15163724 0 VALUE {
    +  if(V(U2_N14995361)>0,(2.5/(V(U2_N14995361))*4.815*21),0)    }
    X_U2_S2    SLAVE 0 U2_SYNC_IN SYNC OSC_U2_S2
    X_U2_U55         U2_MASTER_CLK U2_N15260194 U2_N15274019 U2_N15273433
    +  MUX2_BASIC_GEN PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    X_U2_U47         U2_N15010819 U2_N15045326 U2_N15038039 COMP_BASIC_GEN PARAMS:
    +  VDD=1 VSS=0 VTHRESH=0.5
    X_U2_S5    U2_HICCUP_EN_OK 0 U2_TIME_PERIOD 0 OSC_U2_S5
    X_U2_U7         U2_N15268963 U2_N15268997 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    R_U2_R1         U2_N103766 U2_MASTER_CLK  1
    X_U2_U59         U2_IIN_3RD U2_N15292373 U2_N15298392 AND2_BASIC_GEN PARAMS:
    X_U2_U74         TIME_2ND_B U2_SYNC_IN U2_N14996941 OR2_BASIC_GEN PARAMS: VDD=1
    E_U2_ABM8         U2_N14951301 0 VALUE { (V(U2_SYNC_OUT) * 5)    }
    X_U2_U37         U2_N14973647 U2_N14973789 U2_TIME_IN XOR2_BASIC_GEN PARAMS:
    R_U2_R5         U2_N15268997 U2_N15268973  3.16
    E_U2_ABM4         U2_SLAVE_IN_ABS 0 VALUE { ABS(V(U2_SLAVE_IN))    }
    X_U2_U63         U2_IIN_3RD1 U2_SYNC_IN U2_N15307604 OR2_BASIC_GEN PARAMS:
    X_U2_S3    U2_N15126732 0 SYNC U2_N14951301 OSC_U2_S3
    X_U2_U61         U2_N15296481 U2_IIN_3RD U2_N15298721 AND2_BASIC_GEN PARAMS:
    X_U2_U75         TIME_2ND TIME_2ND_B INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    R_U2_R3         U2_N15160708 U2_N14995361  1
    X_U2_U76         U2_N15416974 0 U2_SLAVE_MODE N15418090 SRLATCHRHP_BASIC_GEN
    X_U2_U4         U2_SYNC_IN 0 U2_N14968918 TRFF_RDOM
    X_U2_U3         SLAVE U2_N15126732 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U2_U27         0 U2_SLAVE_IN_ABS U2_N103766 U2_N102757 ANALOG_MUX
    V_U2_V4         U2_N47785 0 2.5
    G_U2_G4         0 U2_TIME_PERIOD U2_TIME_IN 0 1
    X_U2_U62         U2_N15298392 U2_N15298721 U2_IIN_3RD1 N15299389
    X_U2_U40         U2_N15502782 U2_SYNC_IN U2_N15505395 AND2_BASIC_GEN PARAMS:
    X_U2_U53         U2_N15268959 U2_N15268963 D_D1
    C_U2_C7         U2_N15268973 0  1.43u IC=0
    V_U2_V3         U2_N15045326 0 1
    X_U2_U60         U2_N15292373 U2_N15296481 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U2_S4    U2_N14996941 0 U2_N15010819 0 OSC_U2_S4
    X_U2_U73         U2_MASTER_CLK U2_N917872 U2_SYNC_OUT N919832
    X_U2_U49         U2_N15038039 U2_N14996941 U2_SLAVE_CLK NOR2_BASIC_GEN PARAMS:
    X_U2_U26          U2_VOSC U2_MASTER_CLK COMP_HYS2 PARAMS:  TH=0.5 HYS=1  T=1
    X_U2_S1    FAULT 0 U2_VOSC 0 OSC_U2_S1
    X_U2_U35         U2_N15502399 U2_N15502782 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U2_U71         FAULT HICCUP_FAULT_BAR INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U2_U54         U2_N15268973 U2_N15268997 D_D1
    X_U2_U56         U2_N15287352 U2_N15289490 BUF_DELAY_BASIC_GEN PARAMS: VDD=1
    +  VSS=0 VTHRESH=0.5 DELAY=5n
    X_U2_U31         U2_VOSC U2_N919276 U2_N917872 COMP_BASIC_GEN PARAMS: VDD=1
    +  VSS=0 VTHRESH=0.5
    C_U2_C5         U2_N14995361 0  1n IC=0
    E_U2_ABM2         U2_N15269215 0 VALUE { IF(V(U2_N15268973) > 0.5,1,0)    }
    E_U2_ABM3         RAMP 0 VALUE { 2*V(U2_VOSC)    }
    X_U2_U39         U2_N15505395 U2_HICCUP_EN_OK U2_N14973789 N15506170
    C_U2_C2         0 U2_N103766  1n IC=0
    X_U2_U5         CLK CLKN INV_BASIC_GEN PARAMS: VDD=1 VSS=0 VTHRESH=500E-3
    X_U2_U6         U2_SYNC_IN 0 U2_N15502399 TRFF_RDOM
    G_U2_G5         0 U2_N15010819 U2_N15163724 0 1
    X_U2_U77         U2_N15421955 U2_SLAVE_MODE CLK AND2_BASIC_GEN PARAMS: VDD=1
    X_U2_U58         U2_N15289490 U2_N15289807 U2_IIN_3RD AND2_BASIC_GEN PARAMS:
    G_U2_G3         U2_VOSC 0 U2_N102757 0 21
    G_U2_G2         0 U2_VOSC U2_SLAVE_IN_ABS 0 1
    X_U2_U9         U2_N15269089 U2_N15269215 U2_N15268993 OR2_BASIC_GEN PARAMS:
    R_U2_R4         U2_N15268963 U2_N15268959  3.16
    E_U2_ABM9         U2_N15416974 0 VALUE { IF(V(SLAVE) > 0.5,V(U2_SYNC_IN),1)
    E_U2_ABM5         U2_N15160708 0 VALUE {
    +  ((V(U2_TIME_PERIOD)*0.000000001*1000*1000*2.5*2.5*1000)*2)    }
    X_U2_D1          0 U2_VOSC DC_1mV_1A_1V_1nA
    E_U2_ABM10         U2_N15432319 0 VALUE { IF(V(SLAVE) > 0.5, V(TIME_2ND_B),0)
    E_U2_ABM7         U2_N15260194 0 VALUE {
    +  IF(V(SLAVE)>0.5,V(U2_SLAVE_CLK),V(U2_MASTER_CLK))    }
    C_U2_C4         U2_N15010819 0  1n IC=0
    C_U2_C6         U2_N15268959 0  1.43u IC=0
    X_U2_U64         U2_N15307604 U2_N15309096 BUF_DELAY_BASIC_GEN PARAMS: VDD=1
    X_U2_U8         U2_IIN_3RD 0 U2_N15292373 TRFF_RDOM
    E_U8_ABM6         U8_N1227253 0 VALUE { V(VREFBUF)+V(U8_TCDSET_VIN)    }
    R_U8_R1         U8_N113634 U8_N114050  5K
    G_U8_G3         0 U8_N1198281 U8_I_IN 0 1
    X_U8_U13         U8_N128885 U8_N128881 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U8_D5         U8_N1227105 U8_N1227253 GEN_DIODE
    X_U8_D2         U8_N1198281 U8_N1211406 GEN_DIODE
    X_U8_U893         U8_N1265537 U8_RESC U8_N15348216 N1276268
    X_U8_S7    U8_N1262237 U8_N1227105 DELAYCD_U8_S7
    X_U8_U887         TD BFAULT_SHIFT_C U8_N1019891 OR2_BASIC_GEN PARAMS: VDD=1
    R_U8_R2         0 U8_N114050  2Meg
    X_U8_U907         U8_N15350041 HICCUP_FAULT_BAR D AND2_BASIC_GEN PARAMS: VDD=1
    X_U8_U892         U8_N1255156 U8_RESD U8_N15350041 N1227407
    E_U8_ABM8         U8_RES 0 VALUE { IF(V(SLAVE) >0.5,V(TIME_2ND),1)    }
    E_U8_ABM7         U8_K 0 VALUE { IF(V(ADEL)>0,1,0)    }
    X_U8_U901         PWM U8_RESD U8_N1262237 AND2_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U8_U899         U8_N1227105 U8_TCDSET_VIN U8_N1255156 COMP_BASIC_GEN PARAMS:
    X_U8_U885         BFAULT_SHIFT_C U8_N1170281 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U8_U896         U8_N1198281 U8_TCDSET_VIN U8_N1265537 COMP_BASIC_GEN PARAMS:
    X_U8_S4    U8_N128885 0 VDD OUTD DELAYCD_U8_S4
    X_U8_U912         C U8_RES U8_N1170281 U8_N128685 AND3_BASIC_GEN PARAMS: VDD=1
    X_U8_S6    U8_N1242981 U8_N1198281 DELAYCD_U8_S6
    G_U8_G4         0 U8_N1227105 U8_I_IN 0 1
    X_U8_S5    U8_N128881 0 OUTD 0 DELAYCD_U8_S5
    X_U8_S2    U8_N128685 0 VDD OUTC DELAYCD_U8_S2
    C_U8_C2         0 U8_N114050  40p
    E_U8_ABM5         U8_N1211406 0 VALUE { V(VREFBUF)+V(U8_TCDSET_VIN)    }
    X_U8_U913         D U8_RES U8_N963700 U8_N128885 AND3_BASIC_GEN PARAMS: VDD=1
    X_U8_U891         U8_RESC PWM U8_N1242981 AND2_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U8_D4         0 U8_N1227105 GEN_DIODE
    C_U8_C3         0 U8_N1198281  1.77p IC=0
    X_U8_H1    U8_V_IN DELCD U8_I_IN 0 DELAYCD_U8_H1
    X_U8_U20         U8_N1018897 U8_RESD BUF_DELAY_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=0.5 DELAY=10n
    X_U8_S3    U8_N128681 0 OUTC 0 DELAYCD_U8_S3
    G_U8_G1         ADEL U8_N113634 TABLE { V(ADEL, U8_N113634) }
    + ( (-5,0) (0,1n)(0.01,1u)(0.1,1) )
    X_U8_U886         TC BFAULT_SHIFT_C U8_N1018897 OR2_BASIC_GEN PARAMS: VDD=1
    X_U8_U12         U8_N128685 U8_N128681 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U8_U21         U8_N1019891 U8_RESC BUF_DELAY_BASIC_GEN PARAMS: VDD=1 VSS=0
    E_U8_ABM2         U8_R_IN 0 VALUE { (V(U8_V_IN)/V(U8_I_IN))/1000    }
    X_U8_U906         U8_N15348216 HICCUP_FAULT_BAR C AND2_BASIC_GEN PARAMS: VDD=1
    V_U8_V2         U8_V_IN U8_N112342 0.210
    X_U8_D3         0 U8_N1198281 GEN_DIODE
    C_U8_C4         0 U8_N1227105  1.77p IC=0
    X_U8_U17         BFAULT_SHIFT_C U8_N963700 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    E_U8_ABM3         U8_TCDSET_VIN 0 VALUE {
    +  (((5*V(U8_R_IN))/(0.26+LIMIT(V(CS),0,1.8)*1.3*V(U8_K)))*0.000000001*V(U8_I_IN))/(1.77*0.000000000001)
    E_U8_ABM1         U8_N112342 0 VALUE { LIMIT(V(U8_N114050) * 10,0.02,4.25)    }
    X_U3_U28          U3_PWM_H U3_PWM_L INVERTER
    G_U3_G2         U3_N854877 COMP TABLE { V(U3_N854877, COMP) }
    + ( (-10,-5m)(-1m,-4.6m) (1m,3.75m)(10,4.5m) )
    X_U3_U33         PWMI U3_N15171995 BUF_DELAY_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=0.5 DELAY=100n
    X_U3_H1    VRM2R5V RSUM U3_N111703 0 EAPWM_U3_H1
    X_U3_D1         U3_ME VREFBUF GEN_DIODE
    X_U3_U25         RAMP U3_N115946 U3_PCM U3_N1119181 ANALOG_MUX
    X_U3_U24          COMP U3_N112167 U3_PWM_H COMPARATOR
    X_U3_U31         U3_PWM_L CLK PWMI RSFF_RDOM_VAR PARAMS:  T=10
    X_U3_U21         U3_N110746 EAM U3_N854877 OP_AMP PARAMS:  HLIMIT=4.25 RIN=1MEG
    +  BW=3MEG DC_GAIN=100 ROUT=100 LLIMIT=0.25 SRP=1   SRM=1
    E_U3_ABM4         U3_N113332 0 VALUE { ABS(V(U3_N111703))*2    }
    G_U3_G1         GND U3_ME U3_N113332 0 0.001
    X_U3_U23          U3_N111703 U3_PCM COMPARATOR2 PARAMS:  TH=0
    V_U3_V1         U3_N112167 U3_N1119181 0.85
    C_U3_C2         U3_N854877 COMP  10p IC=0
    C_U3_C1         U3_ME 0  1n IC=0
    X_U3_S3    FAULT_1 CS EAPWM_U3_S3
    X_U3_U35         PWMI U3_N15175139 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U3_U27          U3_N115946 OC COMPARATOR2 PARAMS:  TH=2
    E_U3_ABM3         U3_N110746 0 VALUE { if(V(EAP)<V(REFSS),V(EAP),V(REFSS))
    X_U3_S1    FAULT_1 COMP EAPWM_U3_S1
    X_U3_S2    CLK U3_ME EAPWM_U3_S2
    X_U3_U26          U3_ME CS U3_N115946 ANALOG_SUMMER
    X_U3_U34         U3_N15171995 U3_N15175139 U3_CS_S_R AND2_BASIC_GEN PARAMS:
    R_R1         0 GND  1m
    X_U11         PWM N15201465 INV_DELAY_BASIC_GEN PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    +  DELAY=20n
    X_S1    N15201465 0 CS 0 UCC28950_S1
    X_U9_U18         U9_N128783 U9_N128881 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    R_U9_R1         U9_N113634 U9_N114050  5K
    X_U9_U22         FAULT U9_N935984 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U9_U26         U9_FDEL U9_N938984 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    G_U9_G2         0 U9_N115562 U9_I_IN 0 1
    X_U9_U895         U9_N122413 U9_N143329 U9_EDEL N1186789 SRLATCHRHP_BASIC_GEN
    X_U9_U27         U9_N138558 U9_N938984 U9_N1193704 AND2_BASIC_GEN PARAMS: VDD=1
    X_U9_U894         U9_N122413 U9_N1020124 U9_FDEL N1030889 SRLATCHRHP_BASIC_GEN
    E_U9_ABM4         U9_N998652 0 VALUE { V(VREFBUF)+V(U9_TFESET_VIN)    }
    X_U9_U29         QNF U9_N1020124 BUF_DELAY_BASIC_GEN PARAMS: VDD=1 VSS=0
    X_U9_U16         U9_N121368 CLK U9_N122413 OR2_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U9_S1    CLK U9_N115562 DELAYEF_U9_S1
    X_U9_U19         FAULT U9_FAULT_B INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    R_U9_R2         0 U9_N114050  2Meg
    X_U9_U892         U9_N1192437 U9_FAULT_B U9_E AND2_BASIC_GEN PARAMS: VDD=1
    X_U9_U25         U9_N138558 U9_N938419 U9_N1192437 AND2_BASIC_GEN PARAMS: VDD=1
    X_U9_U11         U9_N115562 U9_TFESET_VIN U9_N987398 COMP_BASIC_GEN PARAMS:
    X_U9_D1         U9_N115562 U9_N998652 GEN_DIODE
    X_U9_S4    U9_N128783 0 VDD OUTE DELAYEF_U9_S4
    X_U9_H1    U9_V_IN DELEF U9_I_IN 0 DELAYEF_U9_H1
    X_U9_U20         U9_F U9_FAULT_B U9_N128579 AND2_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U9_S5    U9_N128881 0 OUTE 0 DELAYEF_U9_S5
    X_U9_S2    U9_N128579 0 VDD OUTF DELAYEF_U9_S2
    X_U9_U17         U9_N128579 U9_N128681 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    C_U9_C2         0 U9_N114050  40p
    X_U9_U21         U9_E U9_N935984 U9_N128783 AND2_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U9_U893         U9_N1193704 U9_FAULT_B U9_F AND2_BASIC_GEN PARAMS: VDD=1
    E_U9_ABM1         U9_N112342 0 VALUE { LIMIT(V(U9_N114050) * 10,0.02,4.25)    }
    X_U9_U23         MS BURST U9_N138558 AND2_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    E_U9_ABM6         U9_K 0 VALUE { IF(V(ADELEF)>0,1,0)    }
    X_U9_S3    U9_N128681 0 OUTF 0 DELAYEF_U9_S3
    E_U9_ABM2         U9_R_IN 0 VALUE { (V(U9_V_IN)/V(U9_I_IN))/1000    }
    G_U9_G1         ADELEF U9_N113634 TABLE { V(ADELEF, U9_N113634) }
    X_U9_U28         QE U9_N143329 BUF_DELAY_BASIC_GEN PARAMS: VDD=1 VSS=0
    X_U9_U24         U9_EDEL U9_N938419 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    C_U9_C1         0 U9_N115562  1.915p IC=0
    V_U9_V2         U9_V_IN U9_N112342 2.48
    E_U9_ABM3         U9_TFESET_VIN 0 VALUE {
    +  (((((5*V(U9_R_IN))/(2.65-LIMIT(V(CS),0,1.8)*1.32*V(U9_K)))*0.000000001)+4*1n)*V(U9_I_IN))/(1.915*1p)
    X_U9_U15         U9_N987398 CLKN U9_N121368 AND2_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U7_S1    CLK U7_N115562 DELAYAB_U7_S1
    X_U7_U868         BFAULT_SHIFT U7_N1052118 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U7_U871         A U7_N1141763 U7_N1057855 AND2_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U7_U894         QA U7_RES U7_N15488899 OR2_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U7_U892         U7_N1128713 U7_N1128833 U7_N1128837 N1171824
    G_U7_G1         ADEL U7_N113634 TABLE { V(ADEL, U7_N113634) }
    X_U7_U870         U7_N1057855 U7_N1065753 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U7_U890         U7_N1128837 HICCUP_FAULT_BAR B AND2_BASIC_GEN PARAMS: VDD=1
    R_U7_R2         0 U7_N114050  2Meg
    X_U7_U20         U7_N15488899 U7_N1128833 BUF_DELAY_BASIC_GEN PARAMS: VDD=1
    +  VSS=0 VTHRESH=0.5 DELAY=10n
    E_U7_ABM4         U7_N999252 0 VALUE { V(VREFBUF)+V(U7_TABSET_VIN)    }
    E_U7_ABM5         U7_K 0 VALUE { IF(V(ADEL)>0,1,0)    }
    X_U7_D1         U7_N115562 U7_N999252 GEN_DIODE
    X_U7_U885         BFAULT_SHIFT U7_N1141763 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U7_U11         U7_N115562 U7_TABSET_VIN U7_N1084353 COMP_BASIC_GEN PARAMS:
    X_U7_U867         B U7_N1052118 U7_N127334 AND2_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U7_U893         U7_N1128713 U7_N1128749 U7_N1128851 N1172589
    X_U7_U21         U7_N15503737 U7_N1128749 BUF_DELAY_BASIC_GEN PARAMS: VDD=1
    X_U7_U895         QNB U7_RES U7_N15503737 OR2_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    V_U7_V2         U7_V_IN U7_N112342 0.210
    X_U7_S4    U7_N127334 0 VDD OUTB DELAYAB_U7_S4
    X_U7_S2    U7_N1057855 0 VDD OUTA DELAYAB_U7_S2
    E_U7_ABM2         U7_R_IN 0 VALUE { (V(U7_V_IN)/V(U7_I_IN))/1000    }
    E_U7_ABM6         U7_RES 0 VALUE { IF(V(SLAVE) >0.5,V(TIME_2ND_B),0)    }
    X_U7_S5    U7_N127436 0 OUTB 0 DELAYAB_U7_S5
    E_U7_ABM3         U7_TABSET_VIN 0 VALUE {
    +  (((5*V(U7_R_IN))/(0.26+LIMIT(V(CS),0,1.8)*1.3*V(U7_K)))*0.000000001*V(U7_I_IN))/(1.77*0.000000000001)
    X_U7_U14         U7_N127334 U7_N127436 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U7_S3    U7_N1065753 0 OUTA 0 DELAYAB_U7_S3
    X_U7_U876         U7_N1084353 CLKN U7_N1126723 AND2_BASIC_GEN PARAMS: VDD=1
    G_U7_G2         0 U7_N115562 U7_I_IN 0 1
    C_U7_C1         0 U7_N115562  1.77p IC=0
    C_U7_C2         0 U7_N114050  40p
    X_U7_U891         U7_N1128851 HICCUP_FAULT_BAR A AND2_BASIC_GEN PARAMS: VDD=1
    X_U7_H1    U7_V_IN DELAB U7_I_IN 0 DELAYAB_U7_H1
    X_U7_U881         U7_N1126723 CLK U7_N1128713 OR2_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    R_U7_R1         U7_N113634 U7_N114050  5K
    E_U7_ABM1         U7_N112342 0 VALUE { LIMIT(V(U7_N114050) * 10,0.02,4.25)    }
    X_U1_U26          VREF U1_N107412 COMPARATOR2 PARAMS:  TH=4.9
    X_U1_U890         U1_HICCUP_TIMEOUT U1_N16796815 BUF_DELAY_BASIC_GEN PARAMS:
    +  VDD=1 VSS=0 VTHRESH=0.5 DELAY=1n
    E_U1_ABM13         U1_N16803614 0 VALUE { IF( V(U1_SSEND)>0.5,V(CS),0 )    }
    E_U1_ABM7         U1_N16780645 0 VALUE { if(V(SLAVE)>0.5,25u,20u)    }
    X_U1_U893         U1_HICCUP_EN_START U1_HICCUP_EN U1_HICCUP_TOTAL OR2_BASIC_GEN
    X_U1_U25          U1_5V U1_1V ANALOG_BUFFER PARAMS:  GAIN=0.2
    E_U1_ABM3         U1_FAST_PULL_UP_I 0 VALUE {
    +  if(V(U1_HICCUP_EN)<0.5,if(V(SSEN)>3.6,1,0),0)    }
    X_U1_U24          U1_5V U1_N112197 ANALOG_BUFFER PARAMS:  GAIN=0.93
    V_U1_V16         U1_N868574 0 1
    R_U1_R2         0 U1_TRIP  100MEG
    C_U1_C2         0 FAULT  1n
    G_U1_ABM2I1         SSEN 0 VALUE { IF(V(U1_HICCUP_EN) >0.5,V(U1_N16780645),0)
    E_U1_ABM10         U1_N16790700 0 VALUE { IF(V(U1_N16816339)<3.6,0,1)    }
    X_U1_U898         U1_HICCUP_EN_OK_B U1_N107412 U1_N106282 U1_N107478
    +  U1_N16879479 NAND4_BASIC_GEN PARAMS: VDD=1 VSS=0 VTHRESH=500E-3
    V_U1_V28         U1_N16794656 0 1
    R_U1_R1         U1_N105859 U1_5V  1
    E_U1_ABM14         U1_N16816339 0 VALUE { IF(V(U1_HICCUP_EN)>0.5,V(SSEN),4)
    V_U1_V30         U1_N16827506 0 4.66
    X_U1_U888         U1_N16790700 U1_HICCUP_EN_START INV_BASIC_GEN PARAMS: VDD=1
    X_U1_U683         U1_HICCUP_TIMEOUT N16796320 U1_N16819644 U1_N16794656
    +  U1_N16796815 0 DFFSR_RHPBASIC_GEN PARAMS: VDD=1 VSS=0 VTHRESH=500E-3
    X_U1_S1    U1_TRIP 0 CS 0 HK_U1_S1
    X_U1_U895         U1_HICCUP_EN U1_FAST_PULL_UP_I U1_N16835002 OR2_BASIC_GEN
    X_U1_U14          U1_N106282 U1_N105859 ANALOG_BUFFER PARAMS:  GAIN=5
    G_U1_ABMII1         GND SSEN VALUE { IF(V(U1_N16835002) > 0.5, 0, 25u)    }
    V_U1_V27         U1_N872720 0 2
    R_U1_R3         U1_N16879479 FAULT  1
    X_U1_U900         U1_N107412 U1_N106282 U1_N107478 FAULT_1 NOR3_BASIC_GEN
    X_U1_U892         U1_N16820625 U1_N16819294 U1_N16819644 COMP_BASIC_GEN PARAMS:
    E_U1_LIMIT1         REFSS 0 VALUE {LIMIT(V(U1_N112871),0,5)}
    E_U1_ABM11         U1_N16819294 0 VALUE { IF(V(U1_HICCUP_TOTAL)>0.5,V(SSEN),0)
    X_U1_U891         U1_N868408 U1_HICCUP_TIMEOUT U1_HICCUP_EN N16807368
    E_U1_ABM2         VRM2R5V 0 VALUE {
    +  if(V(VREF)-V(U1_N108451)<0,0,V(VREF)-V(U1_N108451))
    X_U1_U899         HICCUP_EN_OK U1_HICCUP_EN_OK_B INV_BASIC_GEN PARAMS: VDD=1
    X_U1_U17          VDD U1_N106282 COMP_HYS2 PARAMS:  TH=7 HYS=0.6  T=50
    X_U1_D1          SSEN U1_N112197 DC_1mV_1A_1V_1nA
    E_U1_ABM15         U1_SSEND 0 VALUE { if(V(SSEN) >4.6,1,0)    }
    E_U1_ABM8         U1_N16786800 0 VALUE { if(V(SLAVE)>0.5,-22.5u,-17.5u)    }
    G_U1_ABM2I2         SSEN 0 VALUE { IF(V(HICCUP_EN_OK) >0.5,V(U1_N16786800),0)
    X_U1_U19          SSEN U1_N107478 COMP_HYS2 PARAMS:  TH=0.525 HYS=0.05  T=50
    X_U1_U16          U1_5V U1_N108451 ANALOG_BUFFER PARAMS:  GAIN=0.5
    V_U1_V29         U1_N16820625 0 0.55
    X_U1_U887         U1_N16803614 U1_N872720 U1_N868408 COMP_BASIC_GEN PARAMS:
    X_U1_S2    U1_FAST_PULL_UP_I 0 U1_N16827506 SSEN HK_U1_S2
    V_U1_V1         SSEN U1_N112871 0.55
    X_U1_U15         U1_5V VREF ILIMIT PARAMS:  IP=23m   IM=1m   VHARD=100
    X_U1_U681         HICCUP_EN_OK U1_HICCUP_EN_OK_BAR U1_HICCUP_EN_START
    +  U1_N868574 U1_HICCUP_TIMEOUT 0 DFFSR_RHPBASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U1_U22          VREF VREFBUF ANALOG_BUFFER PARAMS:  GAIN=1
    C_U1_C1         U1_5V 0  1n IC=5
    X_U1_U894         U1_N868408 U1_TRIP BUF_DELAY_BASIC_GEN PARAMS: VDD=1 VSS=0
    X_U5_U34         TMINP PWMI U5_N201516 AND2_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U5_U55         U5_N253241 U5_N253069 U5_N253391 AND2_BASIC_GEN PARAMS: VDD=1
    X_U5_U35         TMINP U5_N218486 U5_N201669 AND2_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U5_U32         PWM PWMN INV_BASIC_GEN PARAMS: VDD=1 VSS=0 VTHRESH=500E-3
    X_U5_U22         U5_N147631 U5_N146148 U5_N202297 RSFF_RDOM_VAR PARAMS:  T=10
    X_U5_U20         U5_N144968 U5_N144019 U5_N153858 RSFF_RDOM_VAR PARAMS:  T=10
    X_U5_U18         U5_N240684 0 U5_N240492 TRFF_RDOM
    X_U5_U16         U5_N141258 0 U5_BSYNC TRFF_RDOM
    X_U5_U30         U5_N253103 0 U5_N253069 TRFF_RDOM
    X_U5_U56         U5_N253391 BURST BFAULT_SHIFT_C NOR2_BASIC_GEN PARAMS: VDD=1
    X_U5_U52         U5_N240730 U5_N240452 U5_N243856 AND2_BASIC_GEN PARAMS: VDD=1
    X_U5_U38         U5_N155915 U5_N156103 PWM AND2_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U5_U23         U5_N240452 0 U5_N240730 TRFF_RDOM
    R_U5_R3         U5_N202297 0  1k
    X_U5_U28         U5_N165574 0 U5_N141258 TRFF_RDOM
    X_U5_U49         BURST PWMI CLKN U5_N151959 AND3_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U5_U42         U5_N145999 U5_BSYNC U5_N146148 AND2_BASIC_GEN PARAMS: VDD=1
    X_U5_U44         U5_N145999 U5_N147313 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U5_U46         U5_BSYNC U5_N141258 U5_N141346 AND2_BASIC_GEN PARAMS: VDD=1
    X_U5_U24         CLKN 0 U5_N253195 TRFF_RDOM
    X_U5_U14         CLK 0 U5_N140448 TRFF_RDOM
    X_U5_U25         U5_N253195 0 U5_N253103 TRFF_RDOM
    X_U5_U36         PWMI U5_N218486 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U5_U48         TMINP U5_N227196 U5_N142322 AND2_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U5_U40         U5_N253069 0 U5_N253241 TRFF_RDOM
    X_U5_U33         BURST BURSTN INV_BASIC_GEN PARAMS: VDD=1 VSS=0 VTHRESH=500E-3
    X_U5_U51         U5_N141346 BURST U5_N190650 NOR2_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    R_U5_R1         U5_BSYNC 0  1k
    X_U5_U37         U5_N190650 FAULT BFAULT OR2_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U5_U15         U5_N140448 0 U5_N165574 TRFF_RDOM
    R_U5_R2         BURST 0  1k
    X_U5_U47         FAULT U5_N227196 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U5_U27         OC CLK U5_N156103 RSFF_RDOM_VAR PARAMS:  T=10
    X_U5_U54         CLK U5_N246945 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    +  VTHRESH=500E-3
    X_U5_U26         U5_N153858 U5_N145999 DELAY PARAMS:  T=200
    X_U5_U43         U5_N147313 U5_BSYNC U5_N147631 AND2_BASIC_GEN PARAMS: VDD=1
    X_U5_U45         U5_N141346 U5_N142322 U5_TMINC AND2_BASIC_GEN PARAMS: VDD=1
    X_U5_U53         U5_N243856 BURST BFAULT_SHIFT NOR2_BASIC_GEN PARAMS: VDD=1
    X_U5_U29         U5_N240492 0 U5_N240452 TRFF_RDOM
    X_U5_U19         U5_TMINC PWMI U5_N144019 RSFF_RDOM_VAR PARAMS:  T=10
    R_U5_R5         U5_N253241 0  1k
    X_U5_U31         U5_N201669 U5_N201516 BURST RSFF_RDOM_VAR PARAMS:  T=10
    X_U5_U50         TMINP U5_TMINC CLKN BURSTN U5_N151882 AND4_BASIC_GEN PARAMS:
    X_U5_U21         PWMI U5_TMINC U5_N144968 RSFF_RDOM_VAR PARAMS:  T=10
    R_U5_R4         U5_N240730 0  1k
    X_U5_U39         U5_N151959 U5_N151882 U5_N155915 OR2_BASIC_GEN PARAMS: VDD=1
    X_U5_U17         U5_N246945 0 U5_N240684 TRFF_RDOM
    .ENDS UCC28950_TRANS
    .subckt DCMTMIN_U4_S7 1 3
    S_U4_S7         3 0 1 0 _U4_S7
    RS_U4_S7         1 0 1G
    .MODEL         _U4_S7 VSWITCH Roff=100e6 Ron=1.0 Voff=0.25V Von=0.75V
    .ends DCMTMIN_U4_S7
    .subckt DCMTMIN_U4_S6 1 2 3 4
    S_U4_S6         3 4 1 2 _U4_S6
    RS_U4_S6         1 2 1G
    .MODEL         _U4_S6 VSWITCH Roff=1e6 Ron=1.0 Voff=0.25V Von=0.75V
    .ends DCMTMIN_U4_S6
    .subckt DCMTMIN_U4_H1 1 2 3 4
    H_U4_H1         3 4 VH_U4_H1 1
    VH_U4_H1         1 2 0V
    .ends DCMTMIN_U4_H1
    .subckt OSC_U2_H1 1 2 3 4
    H_U2_H1         3 4 VH_U2_H1 4.815
    VH_U2_H1         1 2 0V
    .ends OSC_U2_H1
    .subckt OSC_U2_S2 1 2 3 4
    S_U2_S2         3 4 1 2 _U2_S2
    RS_U2_S2         1 2 1G
    .MODEL         _U2_S2 VSWITCH Roff=10e9 Ron=1 Voff=0.25V Von=0.75V
    .ends OSC_U2_S2
    .subckt OSC_U2_S5 1 2 3 4
    S_U2_S5         3 4 1 2 _U2_S5
    RS_U2_S5         1 2 1G
    .MODEL         _U2_S5 VSWITCH Roff=1e9 Ron=1m Voff=0.25V Von=0.75V
    .ends OSC_U2_S5
    .subckt OSC_U2_S3 1 2 3 4
    S_U2_S3         3 4 1 2 _U2_S3
    RS_U2_S3         1 2 1G
    .MODEL         _U2_S3 VSWITCH Roff=10e9 Ron=1 Voff=0.25V Von=0.75V
    .ends OSC_U2_S3
    .subckt OSC_U2_S4 1 2 3 4
    S_U2_S4         3 4 1 2 _U2_S4
    RS_U2_S4         1 2 1G
    .MODEL         _U2_S4 VSWITCH Roff=100e6 Ron=1.0 Voff=0.2V Von=0.8V
    .ends OSC_U2_S4
    .subckt OSC_U2_S1 1 2 3 4
    S_U2_S1         3 4 1 2 _U2_S1
    RS_U2_S1         1 2 1G
    .MODEL         _U2_S1 VSWITCH Roff=1e9 Ron=1m Voff=0.25V Von=0.75V
    .ends OSC_U2_S1
    .subckt DELAYCD_U8_S7 1 3
    S_U8_S7         3 0 1 0 _U8_S7
    RS_U8_S7         1 0 1G
    .MODEL         _U8_S7 VSWITCH Roff=1e9 Ron=0.1 Voff=0.25V Von=0.75V
    .ends DELAYCD_U8_S7
    .subckt DELAYCD_U8_S4 1 2 3 4
    S_U8_S4         3 4 1 2 _U8_S4
    RS_U8_S4         1 2 1G
    .MODEL         _U8_S4 VSWITCH Roff=1e6 Ron=20 Voff=0.25V Von=0.75V
    .ends DELAYCD_U8_S4
    .subckt DELAYCD_U8_S6 1 3
    S_U8_S6         3 0 1 0 _U8_S6
    RS_U8_S6         1 0 1G
    .MODEL         _U8_S6 VSWITCH Roff=1e9 Ron=0.1 Voff=0.25V Von=0.75V
    .ends DELAYCD_U8_S6
    .subckt DELAYCD_U8_S5 1 2 3 4
    S_U8_S5         3 4 1 2 _U8_S5
    RS_U8_S5         1 2 1G
    .MODEL         _U8_S5 VSWITCH Roff=1e6 Ron=10 Voff=0.25V Von=0.75V
    .ends DELAYCD_U8_S5
    .subckt DELAYCD_U8_S2 1 2 3 4
    S_U8_S2         3 4 1 2 _U8_S2
    RS_U8_S2         1 2 1G
    .MODEL         _U8_S2 VSWITCH Roff=1e6 Ron=20 Voff=0.25V Von=0.75V
    .ends DELAYCD_U8_S2
    .subckt DELAYCD_U8_H1 1 2 3 4
    H_U8_H1         3 4 VH_U8_H1 1
    VH_U8_H1         1 2 0V
    .ends DELAYCD_U8_H1
    .subckt DELAYCD_U8_S3 1 2 3 4
    S_U8_S3         3 4 1 2 _U8_S3
    RS_U8_S3         1 2 1G
    .MODEL         _U8_S3 VSWITCH Roff=1e6 Ron=10 Voff=0.25V Von=0.75V
    .ends DELAYCD_U8_S3
    .subckt EAPWM_U3_H1 1 2 3 4
    H_U3_H1         3 4 VH_U3_H1 1000
    VH_U3_H1         1 2 0V
    .ends EAPWM_U3_H1
    .subckt EAPWM_U3_S3 1 3
    S_U3_S3         3 0 1 0 _U3_S3
    RS_U3_S3         1 0 1G
    .MODEL         _U3_S3 VSWITCH Roff=100e6 Ron=1.0 Voff=0.25V Von=0.75V
    .ends EAPWM_U3_S3
    .subckt EAPWM_U3_S1 1 3
    S_U3_S1         3 0 1 0 _U3_S1
    RS_U3_S1         1 0 1G
    .MODEL         _U3_S1 VSWITCH Roff=1e6 Ron=1.0 Voff=0.25V Von=0.75V
    .ends EAPWM_U3_S1
    .subckt EAPWM_U3_S2 1 3
    S_U3_S2         3 0 1 0 _U3_S2
    RS_U3_S2         1 0 1G
    .MODEL         _U3_S2 VSWITCH Roff=1e9 Ron=1.0 Voff=0.25V Von=0.75V
    .ends EAPWM_U3_S2
    .subckt UCC28950_S1 1 2 3 4
    S_S1         3 4 1 2 _S1
    RS_S1         1 2 1G
    .MODEL         _S1 VSWITCH Roff=1000e6 Ron=200 Voff=0.2V Von=0.75V
    .ends UCC28950_S1
    .subckt DELAYEF_U9_S1 1 3
    S_U9_S1         3 0 1 0 _U9_S1
    RS_U9_S1         1 0 1G
    .MODEL         _U9_S1 VSWITCH Roff=1e9 Ron=0.1 Voff=0.25V Von=0.75V
    .ends DELAYEF_U9_S1
    .subckt DELAYEF_U9_S4 1 2 3 4
    S_U9_S4         3 4 1 2 _U9_S4
    RS_U9_S4         1 2 1G
    .MODEL         _U9_S4 VSWITCH Roff=1e6 Ron=20 Voff=0.25V Von=0.75V
    .ends DELAYEF_U9_S4
    .subckt DELAYEF_U9_H1 1 2 3 4
    H_U9_H1         3 4 VH_U9_H1 1
    VH_U9_H1         1 2 0V
    .ends DELAYEF_U9_H1
    .subckt DELAYEF_U9_S5 1 2 3 4
    S_U9_S5         3 4 1 2 _U9_S5
    RS_U9_S5         1 2 1G
    .MODEL         _U9_S5 VSWITCH Roff=1e6 Ron=10 Voff=0.25V Von=0.75V
    .ends DELAYEF_U9_S5
    .subckt DELAYEF_U9_S2 1 2 3 4
    S_U9_S2         3 4 1 2 _U9_S2
    RS_U9_S2         1 2 1G
    .MODEL         _U9_S2 VSWITCH Roff=1e6 Ron=20 Voff=0.25V Von=0.75V
    .ends DELAYEF_U9_S2
    .subckt DELAYEF_U9_S3 1 2 3 4
    S_U9_S3         3 4 1 2 _U9_S3
    RS_U9_S3         1 2 1G
    .MODEL         _U9_S3 VSWITCH Roff=1e6 Ron=10 Voff=0.25V Von=0.75V
    .ends DELAYEF_U9_S3
    .subckt DELAYAB_U7_S1 1 3
    S_U7_S1         3 0 1 0 _U7_S1
    RS_U7_S1         1 0 1G
    .MODEL         _U7_S1 VSWITCH Roff=1e9 Ron=0.1 Voff=0.25V Von=0.75V
    .ends DELAYAB_U7_S1
    .subckt DELAYAB_U7_S4 1 2 3 4
    S_U7_S4         3 4 1 2 _U7_S4
    RS_U7_S4         1 2 1G
    .MODEL         _U7_S4 VSWITCH Roff=1e6 Ron=20 Voff=0.25V Von=0.75V
    .ends DELAYAB_U7_S4
    .subckt DELAYAB_U7_S2 1 2 3 4
    S_U7_S2         3 4 1 2 _U7_S2
    RS_U7_S2         1 2 1G
    .MODEL         _U7_S2 VSWITCH Roff=1e6 Ron=20 Voff=0.25V Von=0.75V
    .ends DELAYAB_U7_S2
    .subckt DELAYAB_U7_S5 1 2 3 4
    S_U7_S5         3 4 1 2 _U7_S5
    RS_U7_S5         1 2 1G
    .MODEL         _U7_S5 VSWITCH Roff=1e6 Ron=10 Voff=0.25V Von=0.75V
    .ends DELAYAB_U7_S5
    .subckt DELAYAB_U7_S3 1 2 3 4
    S_U7_S3         3 4 1 2 _U7_S3
    RS_U7_S3         1 2 1G
    .MODEL         _U7_S3 VSWITCH Roff=1e6 Ron=10 Voff=0.25V Von=0.75V
    .ends DELAYAB_U7_S3
    .subckt DELAYAB_U7_H1 1 2 3 4
    H_U7_H1         3 4 VH_U7_H1 1
    VH_U7_H1         1 2 0V
    .ends DELAYAB_U7_H1
    .subckt HK_U1_S1 1 2 3 4
    S_U1_S1         3 4 1 2 _U1_S1
    RS_U1_S1         1 2 1G
    .MODEL         _U1_S1 VSWITCH Roff=1000MEG Ron=200 Voff=0.25V Von=0.75V
    .ends HK_U1_S1
    .subckt HK_U1_S2 1 2 3 4
    S_U1_S2         3 4 1 2 _U1_S2
    RS_U1_S2         1 2 1G
    .MODEL         _U1_S2 VSWITCH Roff=100e9 Ron=1k Voff=0.25V Von=0.75V
    .ends HK_U1_S2
    .SUBCKT AND A B OUT
    EOUT OUT 0 VALUE { IF( V(A)>0.5 & V(B)>0.5,1,0) }
    .ends AND
    .SUBCKT AND_1 A B OUT
    EOUT OUT 0 VALUE { IF( V(A)>0.5 & V(B)<0.5,1,0) }
    .ends AND_1
    .SUBCKT INVERTER IN OUT
    EOUT OUT 0 VALUE { IF( V(IN)<0.5,1,0) }
    .ends INVERTER
    .SUBCKT NAND3 A B C OUT
    EOUT OUT 0 VALUE { IF( V(A)>0.5 & V(B)>0.5 & V(C)>0.5,0,1) }
    .ends NAND3
    .SUBCKT NOR A B OUT
    EOUT OUT 0 VALUE { IF( V(A)>0.5 | V(B)>0.5,0,1) }
    .ends NOR
    .SUBCKT ONE_SHOT IN OUT
    + PARAMs:  T=100
    S_S1         MEAS 0 RESET2 0 S1
    E_ABM1         CH 0 VALUE { if( V(IN)>0.5 | V(OUT)>0.5,1,0)    }
    R_R2         RESET2 RESET  0.1
    E_ABM3         OUT 0 VALUE { if( V(MEAS)<0.5 & V(CH)>0.5,1,0)    }
    R_R1         MEAS CH  {T}
    C_C2         0 RESET2  1.4427n
    C_C1         0 MEAS  1.4427n
    E_ABM2         RESET 0 VALUE { if(V(CH)<0.5,1,0)    }
    .MODEL         S1 VSWITCH Roff=1e9 Ron=1.0 Voff=0.25V Von=0.75V
    .ENDS ONE_SHOT
    .SUBCKT UCCX7324 VINA GND VINB VOUTB VDD VOUTA
    R1 4 GND 1
    R2 VDD 2 30
    D2 VDD 2 _D2_MOD1
    .MODEL _D2_MOD1 D IS=1F N=1 RS=1.9
    D3 2 VDD _D3_MODX
    .MODEL _D3_MODX D BV=3.2 IBV=.1 N=.1 RS=.39
    D1 GND 4 _DZ
    .MODEL _DZ D BV=1.61 IBV=.1 N=.1 RS=.11
    M1 2 3 VOUTA VOUTA _MTOP
    .MODEL _MTOP NMOS KP=10 LAMBDA=1M VTO=4.1
    M2 4 3 VOUTA VOUTA _PMOS
    .MODEL _PMOS PMOS KP=10 LAMBDA=1M VTO=-4.1
    R5 VDD 9 30
    D4 VDD 9 _D2_MOD1
    D5 9 VDD _D3_MODX
    R3 7 3 1K
    C2 3 VOUTA 7P
    M3 9 10 VOUTB VOUTB _MTOP
    R6 11 GND 1
    C1 VOUTA GND 100P
    EB1 7 VOUTA VALUE = {IF(V(VA) < 1.5 , -5 , 5)}
    C3 3 2 0.5P
    C4 3 4 0.5P
    R4 VINA GND 100MEG
    D6 GND 11 _DZ
    M4 11 10 VOUTB VOUTB _PMOS
    R7 12 10 1K
    C6 10 VOUTB 7P
    C7 VOUTB GND 100P
    EB2 12 VOUTB VALUE = {IF(V(VB) < 1.5 , -5 , 5)}
    C8 10 9 0.5P
    C9 10 11 0.5P
    R8 VINB GND 100MEG
    S3 17 18 VINA GND _S3_MOD
    .MODEL _S3_MOD VSWITCH VON=2 VOFF=1 ROFF=10MEG
    V7 17 0 DC=10
    R9 18 GND 1
    EB5 19 GND VALUE = {IF(V(18,GND) > 2.5 , 5 , 0)}
    R10 19 VA 250
    C11 VA GND 120P
    S1 8 15 VINB GND _S3_MOD
    V5 8 0 DC=10
    R11 15 GND 1
    EB3 21 GND VALUE = {IF(V(15,GND) > 2.5 , 5 , 0)}
    R12 21 VB 250
    C12 VB GND 120P
    .ENDS UCCX7324
    .SUBCKT OR A B OUT
    EOUT OUT 0 VALUE { IF( V(A)>0.5 | V(B)>0.5,1,0) }
    .ends OR
    .SUBCKT RSFF_RDOM_VAR R S Q PARAMs:  T=10
    EABM1  1 0 VALUE { If( V(S)>0.5 | V(Q)>0.5, 1,0)    }
    EABM2  Q  0 VALUE { If( V(2)>0.5 & V(R)<0.5, 1,0)    }
    R1   1 2 1
    C1   2  0 {T*1e-9}
    .ENDS RSFF_RDOM_VAR
    .SUBCKT TRFF_RDOM T R QP
    EOUT2 S1 0 VALUE { IF( V(T1)>0.5 & V(Q)<0.5,1,0) }
    C2         T2 0  10n
    R2         T3 T2  1
    EOUT3 R2 0 VALUE { IF( V(T1)>0.5 & V(Q)>0.5,1,0) }
    EOUT6 T3 0 VALUE { IF( V(T)>0.5,1,0) }
    EABM1  1 0 VALUE { If( V(S1)>0.5 | V(QP)>0.5, 1,0)    }
    EABM2  QP  0 VALUE { If( V(1)>0.5 & V(R1)<0.5, 1,0)    }
    R1   QP Q 1
    C1   Q  0 20n
    EOUT4 R1 0 VALUE { IF( V(R2)>0.5 | V(R)>0.5,1,0) }
    EOUT5 T1 0 VALUE { IF( V(T3)>0.5 & V(T2)<0.5,1,0) }
    .ends TRFF_RDOM
    .SUBCKT ANALOG_BUFFER IN OUT
    + PARAMs:  GAIN=1
    EOUT OUT 0 VALUE { GAIN * V(IN)}
    .ends ANALOG_BUFFER
    .SUBCKT ANALOG_MUX A B SEL OUT
    EOUT OUT 0 VALUE { IF( V(SEL)>0.5,V(B),V(A)) }
    .ends ANALOG_MUX
    .SUBCKT ANALOG_SUMMER IN1 IN2 OUT
    EOUT OUT 0 VALUE { V(IN1)+V(IN2)}
    .ends ANALOG_SUMMER
    .SUBCKT CESR IN OUT
    + PARAMs:  C=100u ESR=0.01 X=2 IC=0
    C	IN 1  {C*X} IC={IC}
    RESR	1 OUT {ESR/X}
    .ENDS CESR
    .SUBCKT COMPARATOR INP INM OUT
    EOUT OUT 0 VALUE { IF( V(INP)>V(INM),1,0) }
    .ends COMPARATOR
    .SUBCKT COMPARATOR2 INP OUT
    + PARAMs:  TH=1
    EOUT OUT 0 VALUE { IF( V(INP)>TH,1,0) }
    .ends COMPARATOR2
    .subckt DC_1mV_1A_1V_1nA A C
    G1 A C TABLE { V(A, C) } ( (-1,-1n)(0,0)(1m,1) (2m,10) (3m,1000) )
    .ends DC_1mV_1A_1V_1nA
    .subckt GEN_DIODE 1 2
    D1 1 2 DI2D
    .model DI2D D Is=1e-14 Cjo=.1pF Rs=.1
    .ends GEN_DIODE
    .SUBCKT ILIMIT IN OUT PARAMs:  IP=1 IM=1 VHARD=10
    EATAN      2 0 VALUE {ATAN(V(1))}
    GABM1      IN OUT VALUE { if(V(2)>0,IP*V(2)/1.5708,IM*V(2)/1.5708)    }
    E1         1 0 IN OUT {VHARD}
    .ends ILIMIT
    .SUBCKT LDCR IN OUT
    + PARAMs:  L=1u DCR=0.01 IC=0
    L	IN 1  {L} IC={IC}
    RDCR	1 OUT {DCR}
    .ENDS LDCR
    .SUBCKT LOAD P M
    + PARAMs:  TDELAY=1u TRISE=1u TFALL=1u TPULSE=1u TWIDTH=1 ISTART=1 IPULSE=2 RLOAD=1Meg
    ILOAD P M PULSE({ISTART} {IPULSE} {TDELAY} {TRISE} {TFALL} {TPULSE} {TWIDTH} )
    RLOAD P M {RLOAD}
    GLOAD M P TABLE { V(M, P) } ( (-1,-1n)(0,0)(1m,1) (2m,10) (3m,1000) )
    .ENDS LOAD
    .SUBCKT OP_AMP P M OUT
    + PARAMs:  Hlimit=5 Rin=10Meg BW=18Meg DC_Gain=100 Rout=100 Llimit=0 SRP=1 SRM=1
    R_Rin         P M  {Rin}
    E_E1          5 0 M P {-Gain}
    E_LIMIT2      6 0 VALUE {LIMIT(V(5), {-Abs(SRM)*Ca*1Meg+V(1)/Ra},
    +                 {SRP*Ca*1Meg+V(1)/Ra})}
    G_G2          1 0 6 0 -1
    R_Ra          0 1  {Ra}
    C_Ca          0 1  {Ca}
    E_LIMIT1      2 0 VALUE {LIMIT(V(1),{Llimit},{Hlimit})}
    V_VL          3 0 {Llimit+200m}
    V_VH          4 0 {Hlimit-200m}
    D_D1          3 1 Dideal
    D_D2          1 4 Dideal
    R_Rout        OUT 2  {Rout}
    .model Dideal D Is=1e-10 Cjo=.01pF Rs=1m  N=1
    .PARAM  Ra=1k   Ca={exp(DC_gain*log(10)/20)/(2*3.14159*BW*Ra)}
    + Gain={exp(DC_gain*log(10)/20)/Ra}
    .ENDS OP_AMP
    .SUBCKT XOR A B OUT
    EOUT OUT 0 VALUE { IF( (V(A)>0.5 & V(B)<0.5) | (V(A)<0.5 & V(B)>0.5),1,0) }
    .ends XOR
    .SUBCKT AND3 A B C OUT
    EOUT OUT 0 VALUE { IF( V(A)>0.5 & V(B)>0.5 & V(C)>0.5,1,0) }
    .ends AND3
    .SUBCKT AND4 A B C D OUT
    EOUT OUT 0 VALUE { IF( V(A)>0.5 & V(B)>0.5 & V(C)>0.5 & V(D)>0.5,1,0) }
    .ends AND4
    .SUBCKT DELAY IN OUT
    + PARAMs:  T=100
    E_ABM1         CH 0 VALUE { if( V(IN)>0.5,1,0)    }
    E_ABM3         OUT 0 VALUE { if( V(MEAS)>0.5 & V(CH)>0.5,1,0)    }
    R_R1         MEAS CH  {T}
    C_C1         0 MEAS  1.4427n
    .ENDS DELAY
    .SUBCKT FDP032N08  10 20 30
    M1   1  2  3  3  DMOS L=1U W=1U
    LD  10  1  1.5n
    RD  10  1  1.8m
    RS  40  3  0.5m
    LG  20  2  6n
    RG  20  2  59.54
    CGS  2  3  6.8n
    EGD 12  0  2  1  1
    VFB 14  0  0
    FFB  2  1  VFB  1
    CGD 13 14  3.64n
    R1  13  0  1.00
    D1  12 13  DLIM
    DDG 15 14  DCGD
    R2  12 15  1.00
    D2  15  0  DLIM
    DSD  3 10  DSUB
    LS   30 40  2n
    RLS  30 40  20
    .MODEL DMOS NMOS(LEVEL=3 VMAX=156k THETA=10.0m
    + ETA=2.00m VTO=3.90 KP=525
    .MODEL DCGD D (CJO=3.64n VJ=0.600 M=0.680
    .MODEL DSUB D (IS=975n N=1.50 RS=1.65m BV=75.0
    + CJO=3.09n VJ=0.800 M=0.420 TT=33.0n
    .MODEL DLIM D (IS=100U)
    .ENDS
    .MODEL MURS360T3 D  (IS=266.67E-12 N=1.4165 RS=34.006E-3 IKF=67.563E-3 ISR=2.1110E-3 NR=2.2286
    + BV=600 IBV=10.0u
    + CJO=78.0p  M= 0.727 VJ=1.8 N=2.27 TT=72.0n )
    .MODEL SSR8045 D BV=100 CJO=2.86N IBV=5M IS=26M N=2
    + RS=3.57M TT=14.4P
    .SUBCKT HUF75345S3S  DRAIN GATE SOURCE
    M1 Drain 1 Source Source _MOS
    .MODEL _MOS NMOS KP=120 LAMBDA=2m RD=3m RS=3m VTO=3.5
    Rb 1 Gate 5
    CGS 1 Source 0.0295n
    D1 Source Drain _DBOD
    .MODEL _DBOD D BV=66 CJO=5.621n IBV=250u IS=1.369E-5
    + M=0.503 N=2.142 RS=2.727m TT=32n VJ=0.667
    C2 2 1 0.0487n
    D2 2 Drain _DCRSS
    .MODEL _DCRSS D CJO=4.808n M=1.229 VJ=4.282
    C3 2 Drain 62.69p
    .ENDS
    .MODEL MMBT2907A PNP BF=360 BR=4.00 CJC=23.1p CJE=50.4p
    + EG=1.12 IKF=0.139 IKR=0.307 IS=8.79e-020 ISE=12.6f
    + MJC=0.300 MJE=0.500 NE=2.00 NF=1.00 NR=1.00 RB=4.84
    + RC=0.484 RE=1.21 TF=697p TR=84.5n VAF=139 VAR=20.0
    + VJC=0.300 VJE=1.10 XTB=1.5
    .MODEL UPR10 D
    + IS=820.68E-9 N=1.9505 RS=12.134E-3 IKF=.14249 CJO=100.00E-12
    + M=.3333 VJ=.75 ISR=100.00E-12 BV=100 IBV=100.00E-6 TT=5.0000E-9
    .SUBCKT BAT54_UCC2897A 1 3
    R1 1 3 3.6E+07
    D1 1 3 BAT54S
    .MODEL BAT54S D
    + IS=24.291E-9
    + N=1.0267
    + RS=1.0700
    + IKF=3.5113
    + CJO=15.008E-12
    + M=.53855
    + VJ=.61864
    + ISR=131.86E-9
    + NR=3.3642
    + BV=30
    + IBV=10.000E-6
    + TT=3.6135E-9
    .ENDS
    .SUBCKT AND3_BASIC_GEN A B C Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    E_ABMGATE    YINT 0 VALUE {{IF(V(A) > {VTHRESH}  &
    + V(B) > {VTHRESH} &
    + V(C) > {VTHRESH},{VDD},{VSS})}}
    RINT YINT Y 2
    CINT Y 0 1.4p
    .ENDS AND3_BASIC_GEN
    .SUBCKT AND4_BASIC_GEN A B C D Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    + V(C) > {VTHRESH} &
    + V(D) > {VTHRESH},{VDD},{VSS})}}
    RINT YINT Y 2
    CINT Y 0 1.4p
    .ENDS AND4_BASIC_GEN
    .SUBCKT NOR2_BASIC_GEN A B Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    E_ABMGATE    YINT 0 VALUE {{IF(V(A) > {VTHRESH}  |
    + V(B) > {VTHRESH},{VSS},{VDD})}}
    RINT YINT Y 1
    CINT Y 0 100p
    .ENDS NOR2_BASIC_GEN
    .SUBCKT COMP_BASIC_GEN INP INM Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    E_ABM Yint 0 VALUE {IF (V(INP) >
    + V(INM), {VDD},{VSS})}
    R1 Yint Y 1
    C1 Y 0 1n
    .ENDS COMP_BASIC_GEN
    .SUBCKT COMPARATOR2_1 INP OUT
    + PARAMs:  TH=1
    EOUT OUT 0 VALUE { IF( V(INP)>TH,0,1) }
    .ends COMPARATOR2_1
    .SUBCKT NOR3_BASIC_GEN A B C Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    + V(B) > {VTHRESH} |
    + V(C) > {VTHRESH},{VSS},{VDD})}}
    RINT YINT Y 1
    CINT Y 0 100p
    .ENDS NOR3_BASIC_GEN
    .SUBCKT COMP_HYS INP INM HYS OUT PARAMs: T=10
    EIN INP1 INM1 INP INM 1
    EHYS INP1 INP2 VALUE { IF( V(1)>0.5,-V(HYS)/2,V(HYS)/2) }
    EOUT OUT 0 VALUE { IF( V(INP2)>V(INM1),1,0) }
    R1 OUT 1 1
    C1 1 0 {T*1e-9}
    RINP1 INP1 0 1K
    .ends COMP_HYS
    .SUBCKT COMP_HYS2_new INP OUT
    + PARAMs:  TH=1 HYS=0.1 T=10
    EIN INP1 0 INP 0 1
    EHYS INP1 INP2 VALUE { IF( V(1)>0.5,-(HYS)/2,HYS/2) }
    EOUT OUT 0 VALUE { IF( V(INP2)>TH,0,1) }
    R1 OUT 1 1
    C1 1 0 {T*1e-9}
    RINP1 INP1 0 1K
    .ends COMP_HYS2_new
    .SUBCKT COMP_HYS2 INP OUT
    EIN INP1 0 INP 0 1
    EOUT OUT 0 VALUE { IF( V(INP2)>TH,1,0) }
    R1 OUT 1 1
    C1 1 0 {T*1e-9}
    RINP1 INP1 0 1K
    .ends COMP_HYS2
    .SUBCKT COMP_HYS2_1 INP OUT
    EIN INP1 0 INP 0 1
    EHYS INP1 INP2 VALUE { IF( V(1)>0.5,(HYS)/2,-(HYS)/2) }
    EOUT OUT 0 VALUE { IF( V(INP2)<TH,1,0) }
    R1 OUT 1 1
    C1 1 0 {T*1e-9}
    RINP1 INP1 0 1K
    .ends COMP_HYS2_1
    .subckt srlatchrhp_basic_gen s r q qb params: vdd=1 vss=0 vthresh=0.5
    gq 0 qint value = {if(v(r) > {vthresh},-5,if(v(s) > {vthresh},5,0))}
    cqint qint 0 1n
    rqint qint 0 1000meg
    d_d10 qint my5 d_d1
    v1 my5 0 {vdd}
    d_d11 myvss qint d_d1
    v2 myvss 0 {vss}
    eq qqq 0 qint 0 1
    x3 qqq qqqd1 buf_basic_gen params: vdd={vdd} vss={vss} vthresh={vthresh}
    rqq qqqd1 q 2
    eqb qbr 0 value = {if( v(q) > {vthresh}, {vss},{vdd})}
    rqb qbr qb 20
    cdummy1 q 0 1.44p
    cdummy2 qb 0 1.44p
    .ic v(qint) {vss}
    .model d_d1 d
    + is=1e-015
    + tt=1e-011
    + rs=0.005
    + n=0.1
    .ends srlatchrhp_basic_gen
    .subckt srlatchshp_basic_gen s r q qb params: vdd=1 vss=0 vthresh=0.5
    gq 0 qint value = {if(v(s) > {vthresh},5,if(v(r) > {vthresh},-5,0))}
    cqint qint 0 1n
    d_d10 qint my5 d_d1
    v1 my5 0 {vdd}
    v2 myvss 0 {vss}
    eq qqq 0 qint 0 1
    rqq qqqd1 q 2
    rqb qbr qb 20
    cdummy1 q 0 1.44p
    cdummy2 qb 0 1.44p
    .ic v(qint) {vss}
    .model d_d1 d
    + is=1e-015
    + tt=1e-011
    + rs=0.005
    + n=0.1
    .ends srlatchshp_basic_gen
    .SUBCKT DFFSR_RHPBASIC_GEN Q QB CLK D R S PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    X1 CLK CLKdel1 INV_BASIC_GEN PARAMS: VDD={VDD} VSS={VSS} VTHRESH={VTHRESH}
    R_CLK CLKdel1 CLKdel 21.64502165
    C_CLK CLKdel 0 1n
    X2 CLK CLKdel CLKint AND2_BASIC_GEN PARAMS: VDD={VDD} VSS={VSS} VTHRESH={VTHRESH}
    GQ 0 Qint VALUE = {IF(V(R) > {VTHRESH},-5,IF(V(S) > {VTHRESH},5, IF(V(CLKint)> {VTHRESH},
    + IF(V(D)> {VTHRESH},5,-5),0)))}
    CQint Qint 0 1n
    D_D10 Qint MY5 D_D1
    V1 MY5 0 {VDD}
    D_D11 MYVSS Qint D_D1
    V2 MYVSS 0 {VSS}
    EQ Qqq 0 Qint 0 1
    X3 Qqq Qqqd1 BUF_DELAY_BASIC_GEN PARAMS: VDD={VDD} VSS={VSS} VTHRESH={VTHRESH} DELAY = 1n
    RQq Qqqd1 Q 1
    EQb Qbr 0 VALUE = {IF( V(Q) > {VTHRESH}, {VSS},{VDD})}
    RQb Qbr Qb 1
    Cdummy1 Q 0 1nF
    Cdummy2 QB 0 1nF
    .IC V(Qint) {VSS}
    .MODEL D_D1 D( IS=1e-15 TT=10p Rs=0.05 N=.1 )
    .ENDS DFFSR_RHPBASIC_GEN
    .SUBCKT INV_BASIC_GEN A  Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    E_ABMGATE    YINT 0 VALUE {{IF(V(A) > {VTHRESH} ,
    + {VSS},{VDD})}}
    RINT YINT Y 2
    CINT Y 0 1.4p
    .ENDS INV_BASIC_GEN
    .SUBCKT AND2_BASIC_GEN A B Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    + V(B) > {VTHRESH},{VDD},{VSS})}}
    RINT YINT Y 2
    CINT Y 0 1.4p
    .ENDS AND2_BASIC_GEN
    .SUBCKT OR2_BASIC_GEN A B Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    RINT YINT Y 2
    CINT Y 0 1.4p
    .ENDS OR2_BASIC_GEN
    .SUBCKT XOR2_BASIC_GEN A B Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    E_ABMGATE  YINT 0 VALUE {{IF(V(A) > {VTHRESH}  ^
    RINT YINT Y 1
    CINT Y 0 1n
    .ENDS XOR2_BASIC_GEN
    .SUBCKT BUF_DELAY_BASIC_GEN A  Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5 DELAY = 10n
    E_ABMGATE1    YINT1 0 VALUE {{IF(V(A) > {VTHRESH} ,
    + {VDD},{VSS})}}
    RINT YINT1 YINT2 1
    CINT YINT2 0 {DELAY*1.443}
    E_ABMGATE2    YINT3 0 VALUE {{IF(V(YINT2) > {VTHRESH} ,
    + {VDD},{VSS})}}
    RINT2 YINT3 Y 2
    CINT2 Y 0 1p
    .ENDS BUF_DELAY_BASIC_GEN
    .SUBCKT BUF_BASIC_GEN A  Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    + {VDD},{VSS})}}
    RINT YINT Y 1
    CINT Y 0 1n
    .ENDS BUF_BASIC_GEN
    .subckt d_d1 1 2
    d1 1 2 dd1
    .model dd1 d
    + is=1e-015
    + tt=1e-011
    + rs=0.01
    + n=0.1
    .ends d_d1
    .SUBCKT ASYMMETRIC_DELAY INP  OUT PARAMS: Rising_edge_Delay=1 VTHRESH=0.5 Falling_Edge_Delay=1 VDD=1 VSS=0
    E_ABM1         YIN4 0 VALUE { if(V(YIN3) > {VTHRESH}, {VDD} , {VSS})    }
    E_ABM2         YIN2 0 VALUE { if(V(YIN1) > {VTHRESH}, {VDD} , {VSS})    }
    R_RINT         INP YIN1  1 TC=0,0
    C_CINT         YIN1 0  {1.443*Rising_edge_Delay}  TC=0,0
    D_D10         YIN1 INP D_D1
    R_R1         YIN4 OUT  1 TC=0,0
    R_ROUT         YIN2 YIN3  1 TC=0,0
    C_COUT         YIN3 0 {1.443*Falling_Edge_Delay}  TC=0,0
    C_C1         0 OUT  1n  TC=0,0
    D_D11        YIN2 YIN3 D_D1
    .model D_D1 D
    + is=1e-015
    + tt=1e-011
    + rs=0.005
    + n=0.1
    .ENDS ASYMMETRIC_DELAY
    .SUBCKT MUX2_BASIC_GEN A B S Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    E_ABMGATE  YINT 0 VALUE {{IF(V(S) > {VTHRESH},
    + V(B),V(A))}}
    RINT YINT Y 1
    CINT Y 0 1n
    .ENDS MUX2_BASIC_GEN
    .SUBCKT INV_DELAY_BASIC_GEN A  Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5 DELAY = 10n
    + {VDD},{VSS})}}
    RINT YINT1 YINT2 1
    CINT YINT2 0 {DELAY*1.3}
    + {VSS},{VDD})}}
    RINT2 YINT3 Y 1
    CINT2 Y 0 1n
    .ENDS INV_DELAY_BASIC_GEN
    .SUBCKT NAND4_BASIC_GEN A B C D Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    + V(D) > {VTHRESH},{VSS},{VDD})}}
    RINT YINT Y 1
    CINT Y 0 1n
    .ENDS NAND4_BASIC_GEN
    .SUBCKT mmsz5242bt1 2 1
    D1 2 1 MD1
    .MODEL MD1 D IS=1.31137e-16 N=0.88099 XTI=1 RS=1.073
    + CJO=3e-11 TT=1e-08
    R 1 2  MDR 1.1375e+10
    .MODEL MDR RES TC1=0 TC2=0
    RZ 2 3 0.295363
    IZG 4 3 0.12
    R4 4 3 190
    D3 3 4 MD3
    .MODEL MD3 D IS=2.5e-12 N=1.4997 XTI=0 EG=0.1
    D2 5 4 MD2
    .MODEL MD2 D IS=2.5e-12 N=2.41368 XTI=0 EG=0.1
    EV1 1 5 6 0 1
    IBV 0 6 0.001
    RBV 6 0 MDRBV 11518.1
    .MODEL MDRBV RES TC1=0.000651148
    .ENDS mmsz5242bt1
    .MODEL DN4148 D(RS=.8 CJO=4PF IS=7E-09 N=2 VJ=.6V
    + TT=6E-09 M=.45 BV=100V)
    .MODEL ES3B D (IS=7.27p RS=22.4m BV=100 IBV=10.0u
    + CJO=83.2p M=0.333 N=0.700 TT=36.0n )
    .SUBCKT XFOR_1P2S P1A P1B S1A S1B S2A S2B PARAMS: NP1=10 NS1=1 NS2=1 RP1=0.001
    + RS1=0.001 RS2=0.001 LLEAK=100E-9 LM=0.01 RCORE=100e3
    R_R3         P1B 2  {RCORE}
    L_L1         P1A 1  {LLEAK}
    R_R1         1 2  {RP1}
    L_L2         P1B 2  {LM} IC=0
    E_E1         3 S1B 2 P1B {NS1/NP1}
    R_R2         3 4  {RS1}
    F_F1         2 P1B VF_F1 {NS1/NP1}
    VF_F1         4 S1A 0V
    E_E2         6 S2B 2 P1B {NS2/NP1}
    R_R4         6 7  {RS2}
    F_F2         2 P1B VF_F2 {NS2/NP1}
    VF_F2         7 S2A 0V
    .ends XFOR_1P2S
    .SUBCKT XFOR_CS P1A P1B S1A S1B PARAMS: N=100
    F_F1         S1A S1B VF_F1 {1/N}
    VF_F1        P1B P1A 0V
    .ends XFOR_CS
    .SUBCKT SPP20N60CFD_L0  drain  gate  source
    Lg     gate  g1    7n
    Ld     drain d1    3n
    Ls     source s1   7n
    Rs      s1    s2   1m
    Rg     g1    g2     0.54
    M1      d2    g2    s2    s2    DMOS    L=1u   W=1u
    .MODEL DMOS NMOS ( KP= 15.089  VTO=4.95  THETA=0  VMAX=1.5e5  ETA=0  LEVEL=3)
    Rd     d2    d1a  RdMOD  0.178
    .model RdMOD RES TC1=10m
    .MODEL MVDR NMOS (KP=71.37 VTO=-1   LAMBDA=0.1)
    Mr d1 d2a d1a d1a MVDR W=1u L=1u
    Rx d2a d1a 1m
    Cds1 s2 d2 67.3p
    Dbd     s2    d2    Dbt
    .MODEL     Dbt    D(BV=600   M=0.38  CJO=0.67n  VJ=0.5V)
    Dbody   s2   21    DBODY
    .MODEL DBODY  D(IS=3099280p  N=2.1  RS=7u  EG=1.12  TT=130n)
    Rdiode  d1  21  RdiodeMOD  4.9m
    .model RdiodeMOD RES TC1=4m
    .MODEL   sw    NMOS(VTO=0  KP=10   LEVEL=1)
    Maux      g2   c    a    a   sw
    Maux2     b    d    g2    g2   sw
    Eaux      c    a    d2    g2   1
    Eaux2     d    g2   d2    g2   -1
    Cox       b    d2   5.3n
    .MODEL     DGD    D(M=1.2   CJO=5.3n   VJ=0.5)
    Rpar      b    d2   1Meg
    Dgd       a    d2   DGD
    Rpar2     d2   a    10Meg
    Cgs     g2    s2    2.65n
    .ENDS  SPP20N60CFD_L0
    .SUBCKT XFOR_GATE_1P2S P1A P1B S1A S1B S2A S2B PARAMS: NP1=10 NS1=1 NS2=1 RP1=0.001
    R_R3         P1B 2  {RCORE}
    L_L1         P1A 1  {LLEAK}
    R_R1         1 2  {RP1}
    R_R2         3 4  {RS1}
    VF_F1         4 S1A 0V
    R_R4         6 7  {RS2}
    VF_F2         7 S2A 0V
    .ends XFOR_GATE_1P2S
    I thought Simetrix/Simplis was not a full blown spice simulator.  There does appear to be something wrong with your PSpice model.  This is straight forwarded and should give you the correct delay.
    I will discuss this with our Systems team.
    Mike
  • Helo Mike,
    Thank you for reply. Please let me know your System Team respond. This is very impotent for us as we going to use this controller in not typical application but for low voltage input converter (10-16V) and the behavior of PSFB is a bit different compare with typical 300-400V application and correct simulation can help to avoid costly mistakes.
    Lev
  • Hello Lev
    I'm working to understand and fix the issue - unfortunately it may take some time but it is high on my list of priorities - please have patience.
    In the meanwhile - if there are any other issues, or if I've been negligent in sending updates then please let me know.
    Colin
  • Hello Lev
    We're still working on this but I don't have a final outcome yet. In the meanwhile I'd suggest that you run your simulations with the 7k values. That will allow you to look at the performance of the power stage and allow you to move forward to hardware design.
    Colin
