TPS650864: What is the default power up sequence of TPS6508641?
Part Number: TPS650864
Other Parts Discussed in Thread: TPS650861, TIDA-01393
Hi Expert,
I want to use TPS650864 to provide power supply for Xilinx ZU4EG, and I use TPS6508641.
Can you make me clear about below questions?
1. What is the default power up sequence of TPS6508641? Figure 6-11?
2. Is TPS6508641 not able to change OTP? So if I want to change power up sequence of TPS650841, the only way I can use is to control each power rail power up time by PG+CTRL / I2C?
3. I also find a reference design for Xilinx® Zynq® UltraScale+™ Power Supply https://www.ti.com/lit/ug/tiduep5a/tiduep5a.pdf,  Figure 4 and Figure 5 show TPS6508641 design for ZU2CG ±ZU5EG, can you tell me what is the power sequence of figure 4 and figure 5?
Thank you !
Best regards
Rachel
