LM5030: Open loop application
Part Number: LM5030
Hi team,
Can LM5030 control push-pull converter under open loop with fixed duty cycle?
T
Dylan
  • Hi Dylan!
    Thanks so much for taking the time to get in touch. The LM5030 device can control a push-pull converter under open loop conditions as long as a pre-regulated input signal is provided. A great example can be found in the TIDA-00181 TI reference design. The associated documentation (found here) gives some tips and tricks on how to accomplish this.
    Thank you again for reaching out, I hope this information helps you with your design!
    Aidan Davidson
