Other Parts Discussed in Thread: BQSTUDIO, EV2400
I am trying to calibrate my BQ35100 using an MCU. I have difficulties with the Board Offset calibration, particularly the CCA bit.
After entering calibration mode, I send the BOARD_OFFSET command to the gauge, as detailed in the Board Offset Calibration flowchart from the datasheet. The BCA bit is set to 1, but the CCA bit stays 0, no matter how long I wait.
I have seen other posts with the same problem and the solutions were to use bqstudio. Unfortunately, I can't get an adapter to soon, so bqstudio is not an option for me.
Did anyone succeeded in doing a Board Offset calibration using an MCU?
Thank you,
Florin
