Other Parts Discussed in Thread: BQ34Z110, BQSTUDIO
Hi team,
I want to use bqstudio to test bq34z110, and I check the chemical ID in sluc138dj document.
I found that the maximum capacity of the lead-acid battery model in sluc138dj document is 155Ah. ID is 0807.
Lead Acid 0807 US.Battery: XTREME_Capacity (155Ah)
If I want to test a 200Ah lead-acid battery, How can I select the ID and parameters of battery model as above. Thank you.
