Other Parts Discussed in Thread: LM5176, LM5175
Dears,
I'd like to request the PCB layout review for two parallel configuration of LM5176-Q1. Please refer to the attached files below.
BMS_LM5176-Q1_Two parallel configuration.pdf
Regards, Jeffrey
Dears,
Regards, Jeffrey
Hi Jeffrey,
Thank you for reaching out with your question and for considering the LM5176 in you design.
Looking at the layout file I only see two layers. Are you just looking at placement of the power train components right now? If the other layers have been routed please send those as well.
For your reference this series of blogs will help to layout the LM5176 even though they are written for the LM5175 the layout strategy is very similar.
Please let me know if you have any questions.
Garrett
Hi Garrett,
Yes, I want to know whether the placement of the power train components is correct or not. Please check that. After that, I'll request the layout design review.
Regards, Jeffrey
Hello Jeffrey,
Please excuse the late response.
For a dual phase layout, I would recommend to rotate the power path of the second phase the way that you can use the same GND plane for both phases. In addition I think it is very helpful to review the layout on the EVM for a good power path design.
Hi Brigitte,
Thanks for your response. I'll refer to the your recommendation. Also, I'll try to tune the phase and gain margin of this dual phase layout board next week. Could you help me on tuning the phase and gain margin through changing the resistor and capacitor of COMP pin? I need your help.
Regards, Jeffrey
Hi Jeffrey,
To help tune the loop compensation please use the LM5176 quick-start calculator. This will help find the correct values for the loop compensation.
Please let us know if you have any questions.
Garrett
Hi Garrett,
Thanks for your support. It will be help me understand the loop compensation of LM5176. Let me check it.
