Good day
I note the datasheet calls for a pull up resistor value of 60.4K to the 5V line. The Solar Magic design uses a 174K pull up resistor.
There is no explanation in the datasheet regarding the function of NC4 (pin 23) so it makes for difficult understanding as to why a specific value of 60.4K is the recommended vlaue.
Anyone have any idea of why this is so?
Kind regards
Nick
Hi Nick,
unfortunately, we can't find detail about the method to select this resistor.
but i think this pin is used for some internal function. please follow the suggestion of the datasheet and use a 60.4K resistor or closed to this value.
Hi Jasper
Thank you for the reply. It is a little unfortunate that the documentation does not cover aspects such as this and my previous thread relating to the Register values. The documentation is a tad scant. Interestingly the Solar Magic design uses a 174K resistor and no explanation given.
Thanks again for your efforts.
Kind regards
Nick
Hi Nick,
yes. i guess there is no specific function in this pin but just need to pull high. but I can't find more document detailing the function of this pin.
thanks for your understanding. let me know if there is further question. I will try to help although i may not know more than you.
