Hi Team,
I am using BQ25703ARSNR. I would like to understand the current charging and discharging path in this tool/reference design. "6712.BQ2571X_SchematicChecklist_CalculationTool"
Akshata
Hi Team,
Akshata
Hi Akshata,
I would recommend using that resource as a supplemental tool when designing schematic. For a theoretical understanding please refer to the datasheet here: www.ti.com/.../bq25703a.pdf
I already checked datasheet. I am using RRC2057 battery in my system. Max. charge current: 4480mA and Max continuous discharge current is 8000mA. And I am using design similar to "6712.BQ2571X_SchematicChecklist_CalculationTool". How's changing and discharging both is done here? Can you please explain a bit detail. Can you please support reviewing our schematics?
I am attaching the same.. Charger_20201013.pdf
Hi Akshata,
Charging and discharging measurement are done by sensing current across the sense resistor between SRP and SRN. The information is covered in the datasheet under section 8.3.5.1 High-Accuracy Current Sense Amplifier (IADPT and IBAT)
I have few more questions.
1. In my design attached, Q2 allows to flow current from Vsys pin of charger to (+V_CHGR_SW_L) to battery(+VBATTERY) while charging. While discharge how does current flow?
2. U1 and U2 MOSFET outputs are shorted. What is role of U1 MOSFET? and U2 MOSFET? How buck and boost work here?
3. I am unable to understand the current flow here as well. Do you have any video or any other source where detailed explanation is given about IC and reference designs?
4. How to calculate the in and out currents from each of these?
Hi Akshata,
U1 and U2 are dual n channel MOSFETS. We have used them to save space. Please review if our design is proper.
Hi Akshata,
Yes you are right, I can see the LODRV net connected properly. The power stage design is accurate, correct COMP1 COMP2 configuration, correct IADPT setting etc. Schematic looks good to me.
