Part Number: LMG1210
I am a student trying to create a gate driver circuit for GaN MOSFET. I downloaded the unencrypted PSpice transient model and imported into LTspice and autogenerated the symbol. When simulating it is showing errors are present in the library file. Is it possible to get LTspice library for this LMG1210 IC?
Error log:
Questionable use of curly braces in "b§e_lmg1210_pwm_abm1 lmg1210_pwm_n16782654 0 v={if(v(lmg1210_pwm_n16778522)>800m,1,0)} "
Error: undefined symbol in: "if([v](lmg1210_pwm_n16778522)>800m,1,0)"
Questionable use of curly braces in "b§e_abmgate yint 0 v={if(v(a)>{{vthresh}},{{vss}},{{vdd}})}"
Error: undefined symbol in: "if([v](a)>((vthresh)),((vss)),((vdd)))"
Questionable use of curly braces in "b§e_abmgate yint 0 v={if(v(a)>{{vthresh}}&v(b)>{{vthresh}},{{vdd}},{{vss}})}"
Error: undefined symbol in: "if([v](a)>((vthresh))&v(b)>((vthresh)),((vdd)),((vss)))"
Questionable use of curly braces in "b§e_abmgate yint 0 v={if(v(a)>{{vthresh}},{{vdd}},{{vss}})}"
Error: undefined symbol in: "if([v](a)>((vthresh)),((vdd)),((vss)))"
Error on line 10 : v3 n002 n008 v
Unknown parameter "v"
Error on line 1384 : .model pmos01 pmos vto = -2 kp = 0.6875 lambda = 0.001*$
* Unrecognized parameter "*$" -- ignored
WARNING: Node NC_03 is floating.
WARNING: Less than two connections to node NC_03. This node is used by R:U2:TH_4.
WARNING: Less than two connections to node NC_02. This node is used by L:U2:SS.
V3: Missing value, assumed 0V @ DC
Direct Newton iteration failed to find .op point. (Use ".option noopiter" to skip.)
