TPS23756EVM: EMI and EMC test
Part Number: TPS23756EVM
We would like to do EMI and EMC test on the evaluation module. If you have done the same, would you share the paper or application note?
Sivakumar
    There is EMI data in the User's Guide. However, EMI is a system level solution. So unless every component and the layout are EXACTLY the same, the results will change. So my point is, for your system, my advice would be to wait to test EMI until your system is built.
    For EMI suggestions, please see the following application note:
    If this post answers your question, please indicate so by marking this thread as resolved. Thank you.
    Michael P.
    Applications Engineer
    Texas Instruments
