TPS65400: Are there any ways to turn on LED via SSx/PGx-pin?
Part Number: TPS65400
Hi team,
Customer is wondering how to turn on LED via SSx/PGx-pin.
Their configuration is the attached. Could you tell any ways to turn on LED in these configuration?
TPS65400 questions.pptx
Noriyuki Takahashi
  • Hi, Noriyuki
    1. Confirm you first:
    SSx/PGx pin is programmed to power good function, right?
    2. SSx/PGx pin and ENx pin don't have driving capability, so the configuration won't work.
    3. Below is one method for your reference.
    When SSx/PGx is pull high, the NMOS will turn on, then LED will on.
