Hi Team
There is a linear power project, the design diagram is below , it use MCU DAC output the linear voltage, then use the amplifier as buffer and driver NMOS. Maybe it works, can you give some other solutions? The amplifier is OPA2192 that had been use. Can you give the appropriate part number?
below is design diagram:
this is the power output linear
