Part Number: AM3359
Hello Support@ti,
I am planning to use UART1, 2, 3, 4 and 5 on BeagleboneBlack AM3359 , But i am not getting any output on any of the UART's.
Here for your reference I have attached my code snippet kindly let me know if there any mistakes in my code.
File :- C:\ti\AM335X_StarterWare_02_00_01_01\platform\beaglebone/uart.c
* \file uart.c
#include "hw_control_AM335x.h"
#include "soc_AM335x.h"
#include "hw_cm_wkup.h"
#include "hw_cm_per.h"
#include "beaglebone.h"
#include "hw_types.h"
* \brief This function selects the UART pins for use. The UART pins
* are multiplexed with pins of other peripherals in the SoC
* \param instanceNum The instance number of the UART to be used.
* \return None.
* \note This pin multiplexing depends on the profile in which the EVM
* is configured.
void UARTPinMuxSetup(unsigned int instanceNum)
if(0 == instanceNum)
/* UART0 RXD */
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_UART_RXD(0)) =
(CONTROL_CONF_UART0_RXD_CONF_UART0_RXD_PUTYPESEL |
CONTROL_CONF_UART0_RXD_CONF_UART0_RXD_RXACTIVE);
/* UART0 TXD */
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_UART_TXD(1)) =
CONTROL_CONF_UART0_TXD_CONF_UART0_TXD_PUTYPESEL;
else if(1 == instanceNum)
/* RXD */
HWREG(SOC_CONTROL_REGS + CONTROL_CONF_UART_RXD(1)) =
(CONTROL_CONF_UART1_RXD_CONF_UART1_RXD_PUTYPESEL |
CONTROL_CONF_UART1_RXD_CONF_UART1_RXD_RXACTIVE);
/* TXD */
CONTROL_CONF_UART1_TXD_CONF_UART1_TXD_PUTYPESEL;
** This function enables the system L3 and system L4_WKUP clocks.
** This also enables the clocks for UART0 instance.
void UART0ModuleClkConfig(void)
/* Configuring L3 Interface Clocks. */
/* Writing to MODULEMODE field of CM_PER_L3_CLKCTRL register. */
HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKCTRL) |=
CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE;
/* Waiting for MODULEMODE field to reflect the written value. */
while(CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE !=
(HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKCTRL) &
CM_PER_L3_CLKCTRL_MODULEMODE));
/* Writing to MODULEMODE field of CM_PER_L3_INSTR_CLKCTRL register. */
HWREG(SOC_CM_PER_REGS + CM_PER_L3_INSTR_CLKCTRL) |=
CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE;
while(CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE !=
(HWREG(SOC_CM_PER_REGS + CM_PER_L3_INSTR_CLKCTRL) &
CM_PER_L3_INSTR_CLKCTRL_MODULEMODE));
/* Writing to CLKTRCTRL field of CM_PER_L3_CLKSTCTRL register. */
HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKSTCTRL) |=
CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
/* Waiting for CLKTRCTRL field to reflect the written value. */
while(CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
(HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKSTCTRL) &
CM_PER_L3_CLKSTCTRL_CLKTRCTRL));
/* Writing to CLKTRCTRL field of CM_PER_OCPWP_L3_CLKSTCTRL register. */
HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) |=
CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
/*Waiting for CLKTRCTRL field to reflect the written value. */
while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
(HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) &
CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL));
/* Writing to CLKTRCTRL field of CM_PER_L3S_CLKSTCTRL register. */
HWREG(SOC_CM_PER_REGS + CM_PER_L3S_CLKSTCTRL) |=
CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
while(CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
(HWREG(SOC_CM_PER_REGS + CM_PER_L3S_CLKSTCTRL) &
CM_PER_L3S_CLKSTCTRL_CLKTRCTRL));
/* Checking fields for necessary values. */
/* Waiting for IDLEST field in CM_PER_L3_CLKCTRL register to be set to 0x0. */
while((CM_PER_L3_CLKCTRL_IDLEST_FUNC << CM_PER_L3_CLKCTRL_IDLEST_SHIFT)!=
CM_PER_L3_CLKCTRL_IDLEST));
** Waiting for IDLEST field in CM_PER_L3_INSTR_CLKCTRL register to attain the
** desired value.
while((CM_PER_L3_INSTR_CLKCTRL_IDLEST_FUNC <<
CM_PER_L3_INSTR_CLKCTRL_IDLEST_SHIFT)!=
CM_PER_L3_INSTR_CLKCTRL_IDLEST));
** Waiting for CLKACTIVITY_L3_GCLK field in CM_PER_L3_CLKSTCTRL register to
** attain the desired value.
while(CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK !=
CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK));
** Waiting for CLKACTIVITY_OCPWP_L3_GCLK field in CM_PER_OCPWP_L3_CLKSTCTRL
** register to attain the desired value.
while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK !=
CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK));
** Waiting for CLKACTIVITY_L3S_GCLK field in CM_PER_L3S_CLKSTCTRL register
** to attain the desired value.
while(CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK !=
CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK));
/* Configuring registers related to Wake-Up region. */
/* Writing to MODULEMODE field of CM_WKUP_CONTROL_CLKCTRL register. */
HWREG(SOC_CM_WKUP_REGS + CM_WKUP_CONTROL_CLKCTRL) |=
CM_WKUP_CONTROL_CLKCTRL_MODULEMODE_ENABLE;
while(CM_WKUP_CONTROL_CLKCTRL_MODULEMODE_ENABLE !=
(HWREG(SOC_CM_WKUP_REGS + CM_WKUP_CONTROL_CLKCTRL) &
CM_WKUP_CONTROL_CLKCTRL_MODULEMODE));
HWREG(SOC_CM_WKUP_REGS + CM_WKUP_CLKSTCTRL) |=
CM_WKUP_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
while(CM_WKUP_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
(HWREG(SOC_CM_WKUP_REGS + CM_WKUP_CLKSTCTRL) &
CM_WKUP_CLKSTCTRL_CLKTRCTRL));
/* Writing to CLKTRCTRL field of CM_L3_AON_CLKSTCTRL register. */
HWREG(SOC_CM_WKUP_REGS + CM_WKUP_CM_L3_AON_CLKSTCTRL) |=
CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
while(CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
(HWREG(SOC_CM_WKUP_REGS + CM_WKUP_CM_L3_AON_CLKSTCTRL) &
CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL));
/* Writing to MODULEMODE field of CM_WKUP_UART0_CLKCTRL register. */
HWREG(SOC_CM_WKUP_REGS + CM_WKUP_UART0_CLKCTRL) |=
CM_WKUP_UART0_CLKCTRL_MODULEMODE_ENABLE;
while(CM_WKUP_UART0_CLKCTRL_MODULEMODE_ENABLE !=
(HWREG(SOC_CM_WKUP_REGS + CM_WKUP_UART0_CLKCTRL) &
CM_WKUP_UART0_CLKCTRL_MODULEMODE));
/* Verifying if the other bits are set to required settings. */
** Waiting for IDLEST field in CM_WKUP_CONTROL_CLKCTRL register to attain
** desired value.
while((CM_WKUP_CONTROL_CLKCTRL_IDLEST_FUNC <<
CM_WKUP_CONTROL_CLKCTRL_IDLEST_SHIFT) !=
CM_WKUP_CONTROL_CLKCTRL_IDLEST));
** Waiting for CLKACTIVITY_L3_AON_GCLK field in CM_L3_AON_CLKSTCTRL
** register to attain desired value.
while(CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKACTIVITY_L3_AON_GCLK !=
CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKACTIVITY_L3_AON_GCLK));
** Waiting for IDLEST field in CM_WKUP_L4WKUP_CLKCTRL register to attain
** desired value.
while((CM_WKUP_L4WKUP_CLKCTRL_IDLEST_FUNC <<
CM_WKUP_L4WKUP_CLKCTRL_IDLEST_SHIFT) !=
(HWREG(SOC_CM_WKUP_REGS + CM_WKUP_L4WKUP_CLKCTRL) &
CM_WKUP_L4WKUP_CLKCTRL_IDLEST));
** Waiting for CLKACTIVITY_L4_WKUP_GCLK field in CM_WKUP_CLKSTCTRL register
** to attain desired value.
while(CM_WKUP_CLKSTCTRL_CLKACTIVITY_L4_WKUP_GCLK !=
CM_WKUP_CLKSTCTRL_CLKACTIVITY_L4_WKUP_GCLK));
** Waiting for CLKACTIVITY_L4_WKUP_AON_GCLK field in CM_L4_WKUP_AON_CLKSTCTRL
while(CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL_CLKACTIVITY_L4_WKUP_AON_GCLK !=
(HWREG(SOC_CM_WKUP_REGS + CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL) &
CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL_CLKACTIVITY_L4_WKUP_AON_GCLK));
** Waiting for CLKACTIVITY_UART0_GFCLK field in CM_WKUP_CLKSTCTRL
while(CM_WKUP_CLKSTCTRL_CLKACTIVITY_UART0_GFCLK !=
CM_WKUP_CLKSTCTRL_CLKACTIVITY_UART0_GFCLK));
** Waiting for IDLEST field in CM_WKUP_UART0_CLKCTRL register to attain
** desired value.
while((CM_WKUP_UART0_CLKCTRL_IDLEST_FUNC <<
CM_WKUP_UART0_CLKCTRL_IDLEST_SHIFT) !=
CM_WKUP_UART0_CLKCTRL_IDLEST));
/****************************** End of file *********************************/
void UART1ModuleClkConfig(void)
HWREG(SOC_CM_PER_REGS + CM_PER_L3S_CLKSTCTRL) =
while((HWREG(SOC_CM_PER_REGS + CM_PER_L3S_CLKSTCTRL) &
CM_PER_L3S_CLKSTCTRL_CLKTRCTRL) != CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP);
HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKSTCTRL) =
while((HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKSTCTRL) &
CM_PER_L3_CLKSTCTRL_CLKTRCTRL) != CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP);
HWREG(SOC_CM_PER_REGS + CM_PER_L3_INSTR_CLKCTRL) =
while((HWREG(SOC_CM_PER_REGS + CM_PER_L3_INSTR_CLKCTRL) &
CM_PER_L3_INSTR_CLKCTRL_MODULEMODE) !=
CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE);
HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKCTRL) =
while((HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKCTRL) &
CM_PER_L3_CLKCTRL_MODULEMODE) != CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE);
HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) =
while((HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) &
CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL) !=
CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP);
HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKSTCTRL) =
CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
while((HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKSTCTRL) &
CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL) !=
CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP);
HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKCTRL) =
CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE;
while((HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKCTRL) &
CM_PER_L4LS_CLKCTRL_MODULEMODE) != CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE);
HWREG(SOC_CM_PER_REGS + CM_PER_UART1_CLKCTRL) |= CM_PER_UART1_CLKCTRL_MODULEMODE_ENABLE;
while((HWREG(SOC_CM_PER_REGS + CM_PER_UART1_CLKCTRL) &
CM_PER_UART1_CLKCTRL_MODULEMODE) != CM_PER_UART1_CLKCTRL_MODULEMODE_ENABLE);
while(!(HWREG(SOC_CM_PER_REGS + CM_PER_L3S_CLKSTCTRL) &
while(!(HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKSTCTRL) &
while(!(HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) &
(CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK |
CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L4_GCLK)));
while(!(HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKSTCTRL) &
(CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK |
CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_UART_GFCLK)));
while(CM_PER_UART1_CLKCTRL_MODULEMODE_ENABLE !=
CM_PER_UART1_CLKCTRL_MODULEMODE));
** desired value.
while((CM_PER_UART1_CLKCTRL_IDLEST_FUNC <<
CM_PER_UART1_CLKCTRL_IDLEST_SHIFT) !=
CM_PER_UART1_CLKCTRL_IDLEST));
File :- C:\ti\AM335X_StarterWare_02_00_01_01\examples\beaglebone\uart/uartecho.c
* Uart1.c
* Created on: May 18, 2021
* Author: Shubhakar
#include "uart_irda_cir.h"
#include "interrupt.h"
#include "consoleUtils.h"
** INTERNAL MACRO DEFINITIONS
#define BAUD_RATE_115200 (115200)
#define UART_MODULE_INPUT_CLK (48000000)
** The number of data bytes to be transmitted to Transmit FIFO of UART
** per generation of the Transmit Empty interrupt. This can take a maximum
** value of TX Trigger Space which is 'TX FIFO size - TX Threshold Level'.
#define NUM_TX_BYTES_PER_TRANS (56)
** INTERNAL FUNCTION PROTOTYPES
static void UartInterruptEnable(void);
static void UART1AINTCConfigure(void);
static void UartFIFOConfigure(void);
static void UartBaudRateSet(void);
static void UARTIsr(void);
** GLOBAL VARIABLE DEFINITIONS
unsigned char txArray[] = "StarterWare AM335X UART Interrupt application\r\n";
/* A flag used to signify the application to transmit data to UART TX FIFO. */
unsigned int txEmptyFlag = FALSE;
** A variable which holds the number of bytes of the data block transmitted to
** UART TX FIFO until the current instant.
unsigned int currNumTxBytes = 0;
** FUNCTION DEFINITIONS
int main()
unsigned int numByteChunks = 0;
unsigned int remainBytes = 0;
unsigned int bIndex = 0;
/* Configuring the system clocks for UART0 instance. */
UART1ModuleClkConfig();
/* Performing the Pin Multiplexing for UART0 instance. */
UARTPinMuxSetup(1);
/* Performing a module reset. */
UARTModuleReset(SOC_UART_1_REGS);
/* Performing FIFO configurations. */
UartFIFOConfigure();
/* Performing Baud Rate settings. */
UartBaudRateSet();
/* Switching to Configuration Mode B. */
UARTRegConfigModeEnable(SOC_UART_1_REGS, UART_REG_CONFIG_MODE_B);
/* Programming the Line Characteristics. */
UARTLineCharacConfig(SOC_UART_1_REGS,
(UART_FRAME_WORD_LENGTH_8 | UART_FRAME_NUM_STB_1),
UART_PARITY_NONE);
/* Disabling write access to Divisor Latches. */
UARTDivisorLatchDisable(SOC_UART_1_REGS);
/* Disabling Break Control. */
UARTBreakCtl(SOC_UART_1_REGS, UART_BREAK_COND_DISABLE);
/* Switching to UART16x operating mode. */
UARTOperatingModeSelect(SOC_UART_1_REGS, UART16x_OPER_MODE);
/* Select the console type based on compile time check */
ConsoleUtilsSetType(CONSOLE_UART);
/* Performing Interrupt configurations. */
UartInterruptEnable();
numByteChunks = (sizeof(txArray) - 1) / NUM_TX_BYTES_PER_TRANS;
remainBytes = (sizeof(txArray) - 1) % NUM_TX_BYTES_PER_TRANS;
#if 0
UARTFIFOWrite(SOC_UART_1_REGS, "Hello World",0x0B);
unsigned char recv_array[11] = {0}, tx_array[11] = {"Hello World"};
int i = 0;
for (i = 0; i < 11; i++){
UARTFIFOCharPut(SOC_UART_1_REGS, tx_array[i] );
recv_array[i] = UARTFIFOCharGet(SOC_UART_1_REGS);
#endif
#if 1
while(1)
/* This branch is entered if the transmission is not yet complete. */
if(TRUE == txEmptyFlag)
if(bIndex < numByteChunks)
/* Transmitting bytes in chunks of NUM_TX_BYTES_PER_TRANS. */
currNumTxBytes += UARTFIFOWrite(SOC_UART_1_REGS,
&txArray[currNumTxBytes],
NUM_TX_BYTES_PER_TRANS);
bIndex++;
else
/* Transmitting remaining data from the data block. */
remainBytes);
** Re-enables the Transmit Interrupt. This interrupt
** was disabled in the Transmit section of the UART ISR.
UARTIntEnable(SOC_UART_1_REGS, UART_INT_THR);
#endif
** A wrapper function performing FIFO configurations.
unsigned int fifoConfig = 0;
** - Transmit Trigger Level Granularity is 4
** - Receiver Trigger Level Granularity is 1
** - Transmit FIFO Space Setting is 56. Hence TX Trigger level
** is 8 (64 - 56). The TX FIFO size is 64 bytes.
** - The Receiver Trigger Level is 1.
** - Clear the Transmit FIFO.
** - Clear the Receiver FIFO.
** - DMA Mode enabling shall happen through SCR register.
** - DMA Mode 0 is enabled. DMA Mode 0 corresponds to No
** DMA Mode. Effectively DMA Mode is disabled.
fifoConfig = UART_FIFO_CONFIG(UART_TRIG_LVL_GRANULARITY_4,
UART_TRIG_LVL_GRANULARITY_1,
UART_FCR_TX_TRIG_LVL_56,
1,
1,
1,
UART_DMA_EN_PATH_SCR,
UART_DMA_MODE_0_ENABLE);
/* Configuring the FIFO settings. */
UARTFIFOConfig(SOC_UART_1_REGS, fifoConfig);
** A wrapper function performing Baud Rate settings.
unsigned int divisorValue = 0;
/* Computing the Divisor Value. */
divisorValue = UARTDivisorValCompute(UART_MODULE_INPUT_CLK,
BAUD_RATE_115200,
UART16x_OPER_MODE,
UART_MIR_OVERSAMPLING_RATE_42);
/* Programming the Divisor Latches. */
UARTDivisorLatchWrite(SOC_UART_1_REGS, divisorValue);
** A wrapper function performing Interrupt configurations.
/* Enabling IRQ in CPSR of ARM processor. */
IntMasterIRQEnable();
/* Configuring AINTC to receive UART0 interrupts. */
UART1AINTCConfigure();
/* Enabling the specified UART interrupts. */
UARTIntEnable(SOC_UART_1_REGS, (UART_INT_LINE_STAT | UART_INT_THR |
UART_INT_RHR_CTI));
// UARTIsr();
** Interrupt Service Routine for UART.
unsigned int rxErrorType = 0;
unsigned char rxByte = 0;
unsigned int intId = 0;
unsigned int idx = 0;
/* Checking ths source of UART interrupt. */
intId = UARTIntIdentityGet(SOC_UART_1_REGS);
switch(intId)
case UART_INTID_TX_THRES_REACH:
** Checking if the entire transmisssion is complete. If this
** condition fails, then the entire transmission has been completed.
if(currNumTxBytes < (sizeof(txArray) - 1))
txEmptyFlag = TRUE;
** Disable the THR interrupt. This has to be done even if the
** transmission is not complete so as to prevent the Transmit
** empty interrupt to be continuously generated.
UARTIntDisable(SOC_UART_1_REGS, UART_INT_THR);
break;
case UART_INTID_RX_THRES_REACH:
rxByte = UARTCharGetNonBlocking(SOC_UART_1_REGS);
UARTCharPutNonBlocking(SOC_UART_1_REGS, rxByte);
break;
case UART_INTID_RX_LINE_STAT_ERROR:
rxErrorType = UARTRxErrorGet(SOC_UART_1_REGS);
/* Check if Overrun Error has occured. */
if(rxErrorType & UART_LSR_RX_OE)
ConsoleUtilsPrintf("\r\nUART Overrun Error occured."
" Reading and Echoing all data in RX FIFO.\r\n");
/* Read the entire RX FIFO and the data in RX Shift register. */
for(idx = 0; idx < (RX_FIFO_SIZE + 1); idx++)
rxByte = UARTFIFOCharGet(SOC_UART_1_REGS);
ConsoleUtilsPrintf("%c\n", rxByte);
UARTFIFOCharPut(SOC_UART_1_REGS, rxByte);
break;
/* Check if Break Condition has occured. */
else if(rxErrorType & UART_LSR_RX_BI)
ConsoleUtilsPrintf("\r\nUART Break Condition occured.");
/* Check if Framing Error has occured. */
else if(rxErrorType & UART_LSR_RX_FE)
ConsoleUtilsPrintf("\r\nUART Framing Error occured.");
/* Check if Parity Error has occured. */
else if(rxErrorType & UART_LSR_RX_PE)
ConsoleUtilsPrintf("\r\nUART Parity Error occured.");
ConsoleUtilsPrintf(" Data at the top of RX FIFO is: ");
break;
case UART_INTID_CHAR_TIMEOUT:
ConsoleUtilsPrintf("\r\nUART Character Timeout Interrupt occured."
/* Read all the data in RX FIFO. */
while(TRUE == UARTCharsAvail(SOC_UART_1_REGS))
break;
default:
break;
** This function configures the AINTC to receive UART interrupts.
/* Initializing the ARM Interrupt Controller. */
IntAINTCInit();
/* Registering the Interrupt Service Routine(ISR). */
IntRegister(SYS_INT_UART1INT, UARTIsr);
/* Setting the priority for the system interrupt in AINTC. */
IntPrioritySet(SYS_INT_UART1INT, 0, AINTC_HOSTINT_ROUTE_IRQ);
/* Enabling the system interrupt in AINTC. */
IntSystemEnable(SYS_INT_UART1INT);
/******************************* End of file *********************************/
Thanks & Regards,
Shubhakara P S
