Hi
I want to replace video.x64P with loopback.x64P in encodedecode, and video.x64P has integrated the videnc1 and viddec2 codecs, but I run "encodedecode", errors are as following
./enco /encodedecode
TraceUtil> Warning: Failed to open local log file "trace/cearmlog.txt", using st
dout
TraceUtil> Warning: Failed to open dsp CE log file "trace/cedsp0log.txt", using
stdout
TraceUtil> Warning: Failed to open dsp/bios log file "trace/bioslog.dat", disabl
ing log
@0x000803a3:[T:0x40018528] OG - Global_atexit> enter (fxn=0x1186c)
@0x0008061d:[T:0x40018528] OM - Memory_alloc> Enter(0x18)
@0x000806b1:[T:0x40018528] OM - Memory_alloc> return (0x5b170)
@0x00080818:[T:0x40018528] OG - Global_atexit> enter (fxn=0x2cae4)
@0x000808f9:[T:0x40018528] OM - Memory_alloc> Enter(0x18)
@0x00080988:[T:0x40018528] OM - Memory_alloc> return (0x5b1c0)
@0x00080a04:[T:0x40018528] OG - Global_atexit> enter (fxn=0x2a730)
@0x00080ad6:[T:0x40018528] OG - Global_atexit> enter (fxn=0x2d880)
@0x00080bbb:[T:0x40018528] ti.sdo.ce.osal.Sem - Sem_create> count: 0
@0x00080c61:[T:0x40018528] OM - Memory_alloc> Enter(0x14)
@0x00080ce1:[T:0x40018528] OM - Memory_alloc> return (0x5b240)
@0x00080d71:[T:0x40018528] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x5b240]
@0x00080dfb:[T:0x40018528] ti.sdo.ce.osal.Sem - Sem_create> count: 0
@0x00080e6e:[T:0x40018528] OM - Memory_alloc> Enter(0x14)
@0x00080edf:[T:0x40018528] OM - Memory_alloc> return (0x5b258)
@0x00080f4f:[T:0x40018528] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x5b258]
@0x00080fc8:[T:0x40018528] OM - Memory_alloc> Enter(0x18)
@0x00081037:[T:0x40018528] OM - Memory_alloc> return (0x5b270)
@0x000810a9:[T:0x40018528] OT - Thread_create> Enter (fxn=0x29870, attrs=0x0)
@0x00081122:[T:0x40018528] OM - Memory_alloc> Enter(0x64)
@0x00081190:[T:0x40018528] OM - Memory_alloc> return (0x5b290)
@0x000813ef:[T:0x40018528] OT - Thread_create> Exit (task=0x5b290)
@0x00081495:[T:0x40018528] OG - Global_atexit> enter (fxn=0x29430)
@0x0008152f:[T:0x40018528] OG - Global_atexit> enter (fxn=0x2b524)
@0x000815cd:[T:0x40018528] ti.sdo.ce.alg - ALG_init> Enter
@0x00081642:[T:0x40018528] OG - Global_atexit> enter (fxn=0x28978)
@0x00081727:[T:0x40018528] ti.sdo.ce.alg - ALG_init> Exit
@0x0008179d:[T:0x40018528] OG - Global_atexit> enter (fxn=0x28418)
@0x0008182b:[T:0x40018528] OM - Memory_alloc> Enter(0x18)
@0x000818a8:[T:0x40018528] OM - Memory_alloc> return (0x5b428)
@0x0008191f:[T:0x40018528] OG - Global_atexit> enter (fxn=0x2d9e4)
@0x000819fd:[T:0x40018528] OG - Global_atexit> enter (fxn=0x2579c)
@0x00081a90:[T:0x40018528] OM - Memory_alloc> Enter(0x18)
@0x00081b0b:[T:0x40018528] OM - Memory_alloc> return (0x5b488)
@0x00081b82:[T:0x40018528] OM - Memory_alloc> Enter(0x18)
@0x00081bf7:[T:0x40018528] OM - Memory_alloc> return (0x5b4a8)
@0x00081c6c:[T:0x40018528] OM - Memory_alloc> Enter(0x18)
@0x00081cde:[T:0x40018528] OM - Memory_alloc> return (0x5b4c8)
@0x00081daa:[T:0x40018528] CS - Server_init()
@0x00081e20:[T:0x40018528] CS - Server_init> Global_useLinkArbiter = 0
@0x00081ea0:[T:0x40018528] OG - Global_atexit> enter (fxn=0x242ec)
@0x00081f77:[T:0x40018528] OG - Global_atexit> enter (fxn=0x11c04)
Encodedecode demo started.
@0x00082248:[T:0x40018528] CE - Engine_getNumAlgs('encodedecode', 0xbefffb44)
@0x000822f1:[T:0x40018528] CE - Engine_getAlgInfo('encodedecode', 0xbefffb48, 0x
0)
@0x000824dd:[T:0x412cab60] CE - Engine_open> Enter('encodedecode', 0x0, 0x412ca5
64)
@0x000825b7:[T:0x412cab60] OM - Memory_alloc> Enter(0x2c)
@0x00082647:[T:0x412cab60] OM - Memory_alloc> return (0x5b5b0)
@0x000826c5:[T:0x412cab60] CE - rserverOpen('video_copy.x64P'), count = 0
@0x00082770:[T:0x412cab60] OP - Processor_create> Enter(imageName='video_copy.x6
4P', linkCfg='(null)', attrs=0x412ca568)
@0x000829ac:[T:0x40acab60] OP - daemon> thread created.
@0x00082b7b:[T:0x412cab60] OM - Memory_alloc> Enter(0x24)
@0x00082c2b:[T:0x412cab60] OM - Memory_alloc> return (0x5b5e0)
@0x00082cb0:[T:0x412cab60] OP - doCmd> Enter (cmdId=1, proc=0x5b5e0)
@0x00082d4e:[T:0x412cab60] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x5b240]
@0x00082e2b:[T:0x412cab60] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x5b240]
@0x00082ec6:[T:0x412cab60] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x5b258] t
imeout[0xffffffff]
@0x00082f96:[T:0x40acab60] OP - getCmd_d> Enter (proc=0x40aca5a4)
@0x00083025:[T:0x40acab60] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x5b240] t
imeout[0xffffffff]
@0x000d4cc9:[T:0x40acab60] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x5b240] s
tatus[0]
@0x000d4d74:[T:0x40acab60] OP - getCmd_d> Exit (result=1)
@0x000d4def:[T:0x40acab60] OP - Processor_create_d> Enter(proc=0x5b5e0)
@0x000d4e6f:[T:0x40acab60] OP - Processor_create_d> Initializing DSP PROC...
@0x000d4ef4:[T:0x40acab60] OP - Processor_create_d> Using DspLink config data fo
r entry #0 [server 'video_copy.x64P']
@0x000d4f9a:[T:0x40acab60] OM - Memory_alloc> Enter(0xe0)
@0x000d501b:[T:0x40acab60] OM - Memory_alloc> return (0x5b608)
@0x000d50c4:[T:0x40acab60] OP - Processor_create_d> Adding DSP segment #0 to Lin
k configuration: name='DDR2', startAddress=0x8fa00000, sizeInBytes=0x400000, sha
red=1
@0x000d51a6:[T:0x40acab60] OP - Processor_create_d> Adding DSP segment #1 to Lin
k configuration: name='DSPLINKMEM', startAddress=0x8fe00000, sizeInBytes=0x10000
0, shared=1
@0x000d5280:[T:0x40acab60] OP - Processor_create_d> Adding DSP segment #2 to Lin
k configuration: name='RESET_VECTOR', startAddress=0x8ff00000, sizeInBytes=0x80,
shared=0
@0x000d5353:[T:0x40acab60] OP - Processor_create_d> Adding DSP segment #3 to Lin
k configuration: name='DDRALGHEAP', startAddress=0x88000000, sizeInBytes=0x7a000
00, shared=0
@0x000d5424:[T:0x40acab60] OP - Processor_create_d> DOPOWERCONTROL was=0; now=0
@0x000d5f6f:[T:0x40acab60] OP - Processor_create_d> Attaching to DSP PROC...
@0x000d8db5:[T:0x40acab60] OP - Processor_create_d> Opening MSGQ pool...
@0x000d901c:[T:0x40acab60] OP - Processor_create_d> Loading video_copy.x64P on D
SP (1 args)...
@0x000e16d2:[T:0x40acab60] OP - Processor_create_d> Starting DSP PROC...
@0x000e5472:[T:0x40acab60] OP - Processor_create_d> Opening remote transport...
@0x000e567d:[T:0x40acab60] OP - Processor_create_d> return (1)
@0x000e5725:[T:0x40acab60] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x5b258]
@0x000e57dc:[T:0x412cab60] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x5b258] s
tatus[0]
@0x000e58b8:[T:0x412cab60] OP - doCmd> Exit (result=1)
@0x000e592f:[T:0x412cab60] OP - Processor_create> return (0x5b5e0)
@0x000e59a9:[T:0x412cab60] CE - rserverOpen('video_copy.x64P'): 0x5a734 done.
@0x000e5a2f:[T:0x412cab60] OM - Memory_alloc> Enter(0x20)
@0x000e5aac:[T:0x412cab60] OM - Memory_alloc> return (0x5b7c0)
@0x000e5b65:[T:0x412cab60] OC - Comm_create> Enter(queueName='encodedecode_0', q
ueue=0x5b5c0, attrs=0x0)
@0x000e5c0c:[T:0x412cab60] OM - Memory_alloc> Enter(0x4)
@0x000e5c8b:[T:0x412cab60] OM - Memory_alloc> return (0x5b7e8)
@0x000e5e14:[T:0x412cab60] OC - Comm_create> return (0x5b7e8)
@0x000e5ed8:[T:0x412cab60] OM - Memory_free> Enter(0x5b7c0, 0x20)
@0x000e5f8f:[T:0x412cab60] OM - Memory_free> return (0x1)
@0x000e6015:[T:0x412cab60] OC - Comm_alloc> Enter(poolId=0x0, msg=0x5b5cc, size=
576)
@0x000e60c7:[T:0x412cab60] OC - Comm_alloc> msg=0x41ad9880, returning (0)
@0x000e6153:[T:0x412cab60] OC - Comm_locate> Enter(queueName='rmsq', queue=0x5b5
bc)
@0x000e778a:[T:0x412cab60] OC - Comm_locate> return (0)
@0x000e7830:[T:0x412cab60] CE - checkServer(0x5b5b0)
@0x000e78c1:[T:0x412cab60] OC - Comm_put> Enter(queue=0x0, msg=0x41ad9880)
@0x000e797f:[T:0x412cab60] OC - Comm_put> return (0)
@0x000e7a46:[T:0x412cab60] OC - Comm_get> Enter(queue=0x10000, msg=0x412ca560, t
imeout=-1)
@0x000e7af9:[T:0x412cab60] OC - Comm_get> MSGQ_Get() status=0x8000, return (0)
@0x000e7b9a:[T:0x412cab60] CE - rmsInit(0x5b5b0), setting DSP trace mask to *=01
234567,ti.bios=01324567
@0x000e7c3a:[T:0x412cab60] CE - Engine_setTrace> Enter(engine=0x5b5b0, mask='*=0
1234567,ti.bios=01324567')
@0x000e7ceb:[T:0x412cab60] CE - Engine_setTrace> Requesting DSP set trace ...
@0x000e7d68:[T:0x412cab60] OC - Comm_put> Enter(queue=0x0, msg=0x41ad9880)
@0x000e7e10:[T:0x412cab60] OC - Comm_put> return (0)
@0x000e7e8f:[T:0x412cab60] OC - Comm_get> Enter(queue=0x10000, msg=0x412ca524, t
imeout=-1)
@0x000e7f98:[T:0x40acab60] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x5b258]
@0x000e803c:[T:0x40acab60] OP - getCmd_d> Enter (proc=0x40aca5a4)
@0x000e80bf:[T:0x40acab60] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x5b240] t
imeout[0xffffffff]
@0x000e85d5:[T:0x412cab60] OC - Comm_get> MSGQ_Get() status=0x8000, return (0)
@0x000e867c:[T:0x412cab60] CE - Engine_setTrace> return(0)
@0x000e86f6:[T:0x412cab60] CE - Engine_open> return(374192)
@0x000e876a:[T:0x412cab60] CE - Engine_setTrace> Enter(engine=0x5b5b0, mask='*=0
@0x000e8817:[T:0x412cab60] CE - Engine_setTrace> Requesting DSP set trace ...
@0x000e8894:[T:0x412cab60] OC - Comm_put> Enter(queue=0x0, msg=0x41ad9880)
@0x000e893e:[T:0x412cab60] OC - Comm_put> return (0)
@0x000e89bb:[T:0x412cab60] OC - Comm_get> Enter(queue=0x10000, msg=0x412ca594, t
imeout=-1)
@0x000e8abd:[T:0x412cab60] OC - Comm_get> MSGQ_Get() status=0x8000, return (0)
@0x0013a9ed:[T:0x412cab60] CE - Engine_setTrace> return(0)
@0x0013aa7a:[T:0x412cab60] OM - Memory_alloc> Enter(0x18)
@0x0013aafe:[T:0x412cab60] OM - Memory_alloc> return (0x5b7f8)
@0x0013ad76:[T:0x412cab60] CE - Engine_fwriteTrace(0x5b5b0, '[DSP] ', 0x40201798
@0x0013ae39:[T:0x412cab60] CE - Engine_fwriteTrace(): requesting DSP trace @0x13
ae2d ...
@0x0013af99:[T:0x412cab60] OC - Comm_put> Enter(queue=0x0, msg=0x41ad9880)
@0x0013b06d:[T:0x412cab60] OC - Comm_put> return (0)
@0x0013b0f6:[T:0x412cab60] OC - Comm_get> Enter(queue=0x10000, msg=0x412ca588, t
imeout=-1)
@0x0013b1eb:[T:0x412cab60] OC - Comm_get> MSGQ_Get() status=0x8000, return (0)
@0x0013b27f:[T:0x412cab60] CE - Engine_fwriteTrace> got 4032 chars @0x13ae2d (22
32 still avail, max: 32744, lost: 0)
[DSP] @0x00000236:[T:0x00000000] servers.video_copy.evmDM6467 - main> Welcome to
DSP server's main().
[DSP] @0x00006150:[T:0x8fa4580c] OG - Global_setSpecialTrace> enter(mask='*=0123
[DSP] @0x000061b6:[T:0x8fa4580c] OG - Global_setSpecialTrace> checking if initia
lized...
[DSP] @0x00006201:[T:0x8fa4580c] OG - Global_setSpecialTrace> query returned trc
Mask=0xff
[DSP] @0x00006254:[T:0x8fa4580c] OG - Global_setSpecialTrace> This program was b
uilt with the following packages:
[DSP] @0x000062b0:[T:0x8fa4580c] OG - package ti.targets.rts6000 (/home/davi
nci/dvsdk_1_40_02_33/xdc_3_00_06/packages/ti/targets/rts6000/) [1,0,0,0,12036211
86754]
[DSP] @0x00006325:[T:0x8fa4580c] OG - package ti.xdais.dm.examples.viddec2_c
opy (/home/davinci/dvsdk_1_40_02_33/codec_engine_2_10_02/examples/ti/xdais/dm/ex
amples/viddec2_copy/) [2,0,0,1268616273000]
[DSP] @0x000063aa:[T:0x8fa4580c] OG - package ti.xdais.dm.examples.videnc1_c
amples/videnc1_copy/) [2,0,0,1268727827000]
[DSP] @0x00006430:[T:0x8fa4580c] OG - package ti.sdo.fc.dman3 (/home/davinci
/dvsdk_1_40_02_33/framework_components_2_10_02/packages/ti/sdo/fc/dman3/) [1,0,3
,1220943053023]
[DSP] @0x000064a9:[T:0x8fa4580c] OG - package ti.xdais.dm (/home/davinci/dvs
dk_1_40_02_33/xdais_6_10_01/packages/ti/xdais/dm/) [1,0,4,1210262746529]
[DSP] @0x00006516:[T:0x8fa4580c] OG - package ti.xdais (/home/davinci/dvsdk_
1_40_02_33/xdais_6_10_01/packages/ti/xdais/) [1,2,1,1210262742149]
[DSP] @0x00006580:[T:0x8fa4580c] OG - package ti.sdo.ce.node (/home/davinci/
dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/node/) [1,0,0,122095112
2176]
[DSP] @0x000065f3:[T:0x8fa4580c] OG - package ti.sdo.ce.ipc.dsplink.dsp (/ho
me/davinci/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/ipc/dsplink/
dsp/) [2,0,1,1220951102696]
[DSP] @0x00006699:[T:0x8fa4580c] OG - package ti.sdo.utils.trace (/home/davi
nci/dvsdk_1_40_02_33/framework_components_2_10_02/packages/ti/sdo/utils/trace/)
[1,0,0,1220943366422]
[DSP] @0x0000674a:[T:0x8fa4580c] OG - package ti.sdo.ce.utils.xdm (/home/dav
inci/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/utils/xdm/) [1,0,1
,1220951322616]
[DSP] @0x000067dc:[T:0x8fa4580c] OG - package ti.sdo.fc.acpy3 (/home/davinci
/dvsdk_1_40_02_33/framework_components_2_10_02/packages/ti/sdo/fc/acpy3/) [1,0,2
,1220943014135]
[DSP] @0x00006855:[T:0x8fa4580c] OG - package dsplink.dsp (/home/davinci/dvs
dk_1_40_02_33/dsplink-davinci-v1.50-prebuilt/packages/dsplink/dsp/) [1,3,0]
[DSP] @0x000068c3:[T:0x8fa4580c] OG - package ti.rtdx (/home/davinci/dvsdk_1
_40_02_33/bios_5_32_01/packages/ti/rtdx/) [2,0,0,1,1194024051755]
[DSP] @0x0000692e:[T:0x8fa4580c] OG - package ti.psl (/home/davinci/dvsdk_1_
40_02_33/bios_5_32_01/packages/ti/psl/) [5,0,0,0,0]
[DSP] @0x00006990:[T:0x8fa4580c] OG - package ti.bios (/home/davinci/dvsdk_1
_40_02_33/bios_5_32_01/packages/ti/bios/) [5,2,4,9,1193960176642]
[DSP] @0x000069f9:[T:0x8fa4580c] OG - package ti.sdo.fc.dskt2 (/home/davinci
/dvsdk_1_40_02_33/framework_components_2_10_02/packages/ti/sdo/fc/dskt2/) [1,0,4
,1220943095081]
@0x0013d691:[T:0x43b48b60] CE - Engine_open> Enter('encodedecode', 0x0, 0x43b484
4c)
@0x00191ff8:[T:0x43b48b60] OM - Memory_alloc> Enter(0x2c)
@0x0019215c:[T:0x43b48b60] OM - Memory_alloc> return (0x5bee8)
@0x001921f5:[T:0x43b48b60] CE - rserverOpen('video_copy.x64P'), count = 1
@0x0019227d:[T:0x43b48b60] CE - rserverOpen('video_copy.x64P'): 0x5a734 done.
@0x00192304:[T:0x43b48b60] OM - Memory_alloc> Enter(0x20)
@0x0019237b:[T:0x43b48b60] OM - Memory_alloc> return (0x5b7c0)
@0x00192404:[T:0x43b48b60] OC - Comm_create> Enter(queueName='encodedecode_1', q
ueue=0x5bef8, attrs=0x0)
@0x0019249c:[T:0x43b48b60] OM - Memory_alloc> Enter(0x4)
@0x00192513:[T:0x43b48b60] OM - Memory_alloc> return (0x5bf18)
@0x001926ad:[T:0x43b48b60] OC - Comm_create> return (0x5bf18)
@0x00192753:[T:0x43b48b60] OM - Memory_free> Enter(0x5b7c0, 0x20)
@0x001927de:[T:0x43b48b60] OM - Memory_free> return (0x1)
@0x00192852:[T:0x43b48b60] OC - Comm_alloc> Enter(poolId=0x0, msg=0x5bf04, size=
576)
@0x001928fb:[T:0x43b48b60] OC - Comm_alloc> msg=0x41ada880, returning (0)
@0x00192980:[T:0x43b48b60] OC - Comm_locate> Enter(queueName='rmsq', queue=0x5be
f4)
@0x00193ff5:[T:0x43b48b60] OC - Comm_locate> return (0)
@0x00194095:[T:0x43b48b60] CE - checkServer(0x5bee8)
@0x00194478:[T:0x43b48b60] OC - Comm_put> Enter(queue=0x0, msg=0x41ada880)
@0x0019461f:[T:0x43b48b60] OC - Comm_put> return (0)
@0x001acfef:[T:0x43b48b60] OC - Comm_get> Enter(queue=0x10001, msg=0x43b48448, t
imeout=-1)
@0x001ad154:[T:0x43b48b60] OC - Comm_get> MSGQ_Get() status=0x8000, return (0)
@0x001ad46f:[T:0x43b48b60] CE - Engine_open> return(376552)
@0x001ad522:[T:0x43b48b60] ti.sdo.dmai - [Venc1] Creating encoder videnc1_copy f
or max 720x480 bitrate 2000000 ratectrl 4
@0x001ad643:[T:0x43b48b60] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> Enter (eng
ine=0x5bee8, name='videnc1_copy', params=0x43b48568)
@0x001ad741:[T:0x43b48b60] CV - VISA_create(0x5bee8, 'videnc1_copy', 0x43b48568,
0x2496, 'ti.sdo.ce.video1.IVIDENC1')
@0x001ad7fd:[T:0x43b48b60] CV - VISA_create2(0x5bee8, 'videnc1_copy', 0x43b48568
, 0x30, 0x2496, 'ti.sdo.ce.video1.IVIDENC1')
@0x001ad8be:[T:0x43b48b60] OM - Memory_alloc> Enter(0x30)
@0x001ad940:[T:0x43b48b60] OM - Memory_alloc> return (0x5bd90)
@0x001ad9b9:[T:0x43b48b60] CE - Engine_createNode(0x5bee8, 'videnc1_copy', 2496,
0x43b48568, 0x30, 0x43b48370)
@0x001ada60:[T:0x43b48b60] OM - Memory_alloc> Enter(0x20)
@0x001adad4:[T:0x43b48b60] OM - Memory_alloc> return (0x5b7c0)
@0x001adb90:[T:0x43b48b60] OC - Comm_create> Enter(queueName='gppfromnode_2', qu
eue=0x5b7c8, attrs=0x0)
@0x001adc33:[T:0x43b48b60] OM - Memory_alloc> Enter(0x4)
@0x001adcae:[T:0x43b48b60] OM - Memory_alloc> return (0x5bdc8)
@0x001ade52:[T:0x43b48b60] OC - Comm_create> return (0x5bdc8)
@0x001adf00:[T:0x43b48b60] OC - Comm_put> Enter(queue=0x0, msg=0x41ada880)
@0x001adfbc:[T:0x43b48b60] OC - Comm_put> return (0)
@0x001ae03c:[T:0x43b48b60] OC - Comm_get> Enter(queue=0x10001, msg=0x43b48254, t
imeout=-1)
[DSP] @0x00006a70:[T:0x8fa4580c] OG - package ti.bios.utils (/home/davinci/d
vsdk_1_40_02_33/biosutils_1_01_00/packages/ti/bios/utils/) [2,0,1,0,119189183060
9]
[DSP] @0x00006ae2:[T:0x8fa4580c] OG - package ti.catalog.c6000 (/home/davinc
i/dvsdk_1_40_02_33/xdc_3_00_06/packages/ti/catalog/c6000/) [1,0,0,0,120356178169
5]
[DSP] @0x00006b53:[T:0x8fa4580c] OG - package ti.platforms.evmDM6467 (/home/
davinci/dvsdk_1_40_02_33/bios_5_32_01/packages/ti/platforms/evmDM6467/) [1,0,0,0
,119222963321@0x001ae4b2:[T:0x43b48b60] OC - Comm_get> MSGQ_Get() status=0x8000,
return (0)
@0x001ae603:[T:0x43b48b60] OC - Comm_put> Enter(queue=0x0, msg=0x41ada880)
@0x001ae6ba:[T:0x43b48b60] OC - Comm_put> return (0)
@0x001ae76f:[T:0x43b48b60] OC - Comm_get> Enter(queue=0x10001, msg=0x43b48254, t
imeout=-1)
@0x001ae827:[T:0x43b48b60] OC - Comm_get> MSGQ_Get() status=0x8000, return (0)
@0x001ae8b4:[T:0x43b48b60] CE - Engine_createNode> created node(stdIn=0x2, stdOu
t=0x10002, msgq=0x5bdc8, algName='videnc1_copy', rmsNode=0x8fa466b8, algHandle=0
x8fa467a0)
@0x001ae98a:[T:0x43b48b60] CE - Engine_createNode> Returning 0x5b7c0
@0x001aea00:[T:0x43b48b60] OM - Memory_alloc> Enter(0x4)
@0x001aea7a:[T:0x43b48b60] OM - Memory_alloc> return (0x5bf28)
@0x001aeaf1:[T:0x43b48b60] OC - Comm_alloc> Enter(poolId=0x0, msg=0x5bf28, size=
2496)
@0x001aebb5:[T:0x43b48b60] OC - Comm_alloc> msg=0x41adb880, returning (0)
@0x001aec55:[T:0x43b48b60] CV - VISA_create> remote codec created (name='videnc1
_copy', localQueueID=0x10002, remoteQueueID=0x0002)
@0x001aed11:[T:0x43b48b60] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> return (0x
5bd90)
@0x001aed9c:[T:0x43b48b60] ti.sdo.dmai - [Venc1] Setting dynParams size 720x480
bitrate 2000000
@0x001aee30:[T:0x43b48b60] ti.sdo.ce.video1.VIDENC1 - VIDENC1_control> Enter (ha
ndle=0x5bd90, id=1, params=0x43b484a8 (size=0x3c), status=0x43b483e8 (size=0x9c)
@0x001aef2a:[T:0x43b48b60] CV - VISA_allocMsg> Allocating message for messageId=
0x0002c6cd
@0x001aefc7:[T:0x43b48b60] CV - VISA_call(visa=0x5bd90, msg=0x41adb880): message
Id=0x0002c6cd, command=0x1
@0x001af06c:[T:0x43b48b60] OC - Comm_put> Enter(queue=0x2, msg=0x41adb880)
@0x001af11b:[T:0x43b48b60] OC - Comm_put> return (0)
@0x001af197:[T:0x43b48b60] OC - Comm_get> Enter(queue=0x10002, msg=0x43b48314, t
imeout=-1)
@0x0022d0a5:[T:0x43b48b60] OC - Comm_get> MSGQ_Get() status=0x8000, return (0)
@0x0022d150:[T:0x43b48b60] CV - VISA_call Completed: messageId=0x0002c6cd, comma
nd=0x1, return(status=-3)
@0x0022d220:[T:0x43b48b60] CV - VISA_freeMsg(0x5bd90, 0x41adb880): Freeing messa
ge with messageId=0x0002c6cd
@0x0022d2c4:[T:0x43b48b60] ti.sdo.ce.video1.VIDENC1 - VIDENC1_control> Exit (han
dle=0x5bd90, retVal=0xfffffffd)
@0x0022d361:[T:0x43b48b60] ti.sdo.dmai - [Venc1] XDM_SETPARAMS failed, status=-3
@0x0022d3e4:[T:0x43b48b60] ti.sdo.ce.video1.VIDENC1 - VIDENC1_delete> Enter (han
dle=0x5bd90)
@0x0022d46c:[T:0x43b48b60] CV - VISA_delete(0x5bd90)
@0x0022d4d4:[T:0x43b48b60] CV - VISA_delete> deleting codec (localQueue=0x10002,
remoteQueue=0x2)
@0x0022d564:[T:0x43b48b60] OC - Comm_put> Enter(queue=0x2, msg=0x41adb880)
@0x0022d60e:[T:0x43b48b60] OC - Comm_put> return (0)
@0x0022d6c8:[T:0x43b48b60] OC - Comm_get> Enter(queue=0x10002, msg=0x5bf28, time
out=-1)
@0x0022d772:[T:0x43b48b60] OC - Comm_get> MSGQ_Get() status=0x8000, return (0)
@0x0022d7fd:[T:0x43b48b60] CE - Engine_deleteNode(0x5b7c0)
@0x0022d870:[T:0x43b48b60] OC - Comm_put> Enter(queue=0x0, msg=0x41ada880)
@0x0022d916:[T:0x43b48b60] OC - Comm_put> return (0)
@0x0022d991:[T:0x43b48b60] OC - Comm_get> Enter(queue=0x10001, msg=0x43b4835c, t
imeout=-1)
@0x002a7d0e:[T:0x43b48b60] OC - Comm_get> MSGQ_Get() status=0x8000, return (0)
@0x002a7de1:[T:0x43b48b60] CE - Engine_deleteNode(0x5b7c0): algName = videnc1_co
py, algHandle = 0x8fa467a0, stack size = 10288, stack used = 771(8%)
@0x002a7eb6:[T:0x43b48b60] OC - Comm_delete> Enter (comm=0x5bdc8)
@0x002a8058:[T:0x43b48b60] OM - Memory_free> Enter(0x5bdc8, 0x4)
@0x002a8105:[T:0x43b48b60] OM - Memory_free> return (0x1)
@0x002a8183:[T:0x43b48b60] OC - Comm_delete> return
@0x002a81eb:[T:0x43b48b60] OM - Memory_free> Enter(0x5b7c0, 0x20)
@0x002a8268:[T:0x43b48b60] OM - Memory_free> return (0x1)
@0x002a82d7:[T:0x43b48b60] OC - Comm_free> Enter (msg=0x41adb880)
@0x002a836f:[T:0x43b48b60] OC - Comm_free> return (0)
@0x002a83e4:[T:0x43b48b60] OM - Memory_free> Enter(0x5bf28, 0x4)
@0x002a8460:[T:0x43b48b60] OM - Memory_free> return (0x1)
@0x002a84cf:[T:0x43b48b60] OM - Memory_free> Enter(0x5bd90, 0x30)
@0x002a8549:[T:0x43b48b60] OM - Memory_free> return (0x1)
@0x002a85b6:[T:0x43b48b60] ti.sdo.ce.video1.VIDENC1 - VIDENC1_delete> return
Error: Failed to create videnc1_copy video encoder
7]
[DSP] @0x00006bcb:[T:0x8fa4580c] OG - package ti.sdo.ce.osal (/home/davinci/
dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/osal/) [2,0,2,122095112
7739]
[DSP] @0x00006c3d:[T:0x8fa4580c] OG - package ti.sdo.ce.ipc (/home/davinci/d
vsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/ipc/) [2,0,1,12209510857
87]
[DSP] @0x00006cae:[T:0x8fa4580c] OG - package ti.sdo.ce.alg (/home/davinci/d
vsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/alg/) [1,0,1,12209507819
38]
[DSP] @0x0@0x002a87a5:[T:0x40018528] CE - Engine_open> Enter('encodedecode', 0x0
, 0xbefffacc)
@0x002a8f90:[T:0x40018528] OM - Memory_alloc> Enter(0x2c)
@0x002a90a2:[T:0x40018528] OM - Memory_alloc> return (0x5bc68)
@0x002a91aa:[T:0x40018528] CE - rserverOpen('video_copy.x64P'), count = 2
@0x002a931f:[T:0x40018528] CE - rserverOpen('video_copy.x64P'): 0x5a734 done.
@0x002a9443:[T:0x40018528] OM - Memory_alloc> Enter(0x20)
@0x002a9569:[T:0x40018528] OM - Memory_alloc> return (0x5b7c0)
@0x002a9684:[T:0x40018528] OC - Comm_create> Enter(queueName='encodedecode_3', q
ueue=0x5bc78, attrs=0x0)
@0x002a97a7:[T:0x40018528] OM - Memory_alloc> Enter(0x4)
@0x002a98ab:[T:0x40018528] OM - Memory_alloc> return (0x5bf28)
@0x002a9b1d:[T:0x40018528] OC - Comm_create> return (0x5bf28)
@0x002a9c5d:[T:0x40018528] OM - Memory_free> Enter(0x5b7c0, 0x20)
@0x002a9d89:[T:0x40018528] OM - Memory_free> return (0x1)
@0x002a9e92:[T:0x40018528] OC - Comm_alloc> Enter(poolId=0x0, msg=0x5bc84, size=
576)
@0x002aa019:[T:0x40018528] OC - Comm_alloc> msg=0x41adb880, returning (0)
@0x002aa122:[T:0x40018528] OC - Comm_locate> Enter(queueName='rmsq', queue=0x5bc
74)
@0x002aa5f2:[T:0x42b48b60] ti.sdo.dmai - [Display] Video output set to size 720x
480 pitch 720
@0x002aa74a:[T:0x42b48b60] ti.sdo.dmai - [BufTab] Allocating BufTab for 3 buffer
s
@0x002aaad8:[T:0x42b48b60] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=
0x43b49000, size=4)
@0x002aab95:[T:0x42b48b60] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x43b
49000, size=4)
@0x002aac29:[T:0x42b48b60] OM - Memory__getPhysicalAddress> returning physAddr=0
x0
@0x002aacbc:[T:0x42b48b60] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x
43b49000) = 0x84400000.
@0x002aad5f:[T:0x42b48b60] OM - Memory__addContigBuf> Enter(virtAddr=0x43b49000,
size=4, physAddr=0x84400000)
@0x002aadff:[T:0x42b48b60] OM - Memory__addContigBuf> creating new contigBuf obj
ect
@0x002aae7c:[T:0x42b48b60] OM - Memory_alloc> Enter(0x10)
@0x002aaef6:[T:0x42b48b60] OM - Memory_alloc> return (0x5bd20)
@0x002aaf6b:[T:0x42b48b60] OM - Memory__addContigBuf> returning: cb->phys=0x8440
0000, cb->size=4, cb->virt=0x43b49000
@0x002ab00a:[T:0x42b48b60] OM - Memory_getBufferPhysicalAddress> return (0x84400
000)
@0x002ab08a:[T:0x42b48b60] ti.sdo.dmai - [Buffer] Set user pointer 0x43b49000 (p
hysical 0x84400000)
@0x002fb203:[T:0x42b48b60] ti.sdo.dmai - [Dmai] Driver buffer 0 mapped to 0x43b4
9000 has physical address 0x84400000
@0x002fb58a:[T:0x42b48b60] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=
0x43f3e000, size=4)
@0x002fb642:[T:0x42b48b60] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x43f
3e000, size=4)
@0x002fb6d8:[T:0x42b48b60] OM - Memory__getPhysicalAddress> returning physAddr=0
x0
@0x002fb76d:[T:0x42b48b60] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x
43f3e000) = 0x84800000.
@0x002fb815:[T:0x42b48b60] OM - Memory__addContigBuf> Enter(virtAddr=0x43f3e000,
size=4, physAddr=0x84800000)
@0x002fb8b8:[T:0x42b48b60] OM - Memory__addContigBuf> creating new contigBuf obj
ect
@0x002fb934:[T:0x42b48b60] OM - Memory_alloc> Enter(0x10)
@0x002fb9ad:[T:0x42b48b60] OM - Memory_alloc> return (0x5bd38)
@0x002fba24:[T:0x42b48b60] OM - Memory__addContigBuf> returning: cb->phys=0x8480
0000, cb->size=4, cb->virt=0x43f3e000
@0x002fbac5:[T:0x42b48b60] OM - Memory_getBufferPhysicalAddress> return (0x84800
000)
@0x002fbb46:[T:0x42b48b60] ti.sdo.dmai - [Buffer] Set user pointer 0x43f3e000 (p
hysical 0x84800000)
@0x0034b858:[T:0x42b48b60] ti.sdo.dmai - [Dmai] Driver buffer 1 mapped to 0x43f3
e000 has physical address 0x84800000
@0x0034bbf4:[T:0x42b48b60] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=
0x44333000, size=4)
@0x0034bcb0:[T:0x42b48b60] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x443
33000, size=4)
@0x0034bd47:[T:0x42b48b60] OM - Memory__getPhysicalAddress> returning physAddr=0
x0
@0x0034bddc:[T:0x42b48b60] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x
44333000) = 0x84c00000.
@0x0034be82:[T:0x42b48b60] OM - Memory__addContigBuf> Enter(virtAddr=0x44333000,
size=4, physAddr=0x84c00000)
@0x0034bf20:[T:0x42b48b60] OM - Memory__addContigBuf> creating new contigBuf obj
ect
@0x0034bf9c:[T:0x42b48b60] OM - Memory_alloc> Enter(0x10)
@0x0034c014:[T:0x42b48b60] OM - Memory_alloc> return (0x5c100)
@0x0034c088:[T:0x42b48b60] OM - Memory__addContigBuf> returning: cb->phys=0x84c0
0000, cb->size=4, cb->virt=0x44333000
@0x0034c129:[T:0x42b48b60] OM - Memory_getBufferPhysicalAddress> return (0x84c00
000)
@0x0034c1a9:[T:0x42b48b60] ti.sdo.dmai - [Buffer] Set user pointer 0x44333000 (p
hysical 0x84c00000)
@0x0039bea5:[T:0x42b48b60] ti.sdo.dmai - [Dmai] Driver buffer 2 mapped to 0x4433
3000 has physical address 0x84c00000
@0x0039c393:[T:0x412cab60] CE - Engine_fwriteTrace(): requesting DSP trace @0x2a
8dd8 ...
@0x0039c45f:[T:0x412cab60] OC - Comm_put> Enter(queue=0x0, msg=0x41ad9880)
@0x0039c51e:[T:0x412cab60] OC - Comm_put> return (0)
@0x0039c5a1:[T:0x412cab60] OC - Comm_get> Enter(queue=0x10000, msg=0x412ca588, t
imeout=-1)
@0x0039c695:[T:0x412cab60] OC - Comm_get> MSGQ_Get() status=0x8000, return (0)
@0x0039c727:[T:0x412cab60] CE - Engine_fwriteTrace> got 4032 chars @0x2a8dd8 (30
28 still avail, max: 32744, lost: 0)
0006d21:[T:0x8fa4580c] OG - package ti.sdo.ce.osal.bios (/home/davinci/dvsdk
_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/osal/bios/) [2,0,1,122095113
3740]
[DSP] @0x00006d99:[T:0x8fa4580c] OG - package ti.sdo.ce.ipc.bios (/home/davi
nci/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/ipc/bios/) [2,0,1,1
220951091097]
[DSP] @0x00006e11:[T:0x8fa4580c] OG - package ti.sdo.ce (/home/davinci/dvsdk
_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/) [1,0,6,1220950771473]
[DSP] @0x00006e9b:[T:0x8fa4580c] OG - package ti.sdo.ce.bioslog (/home/davin
ci/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/bioslog/) [1,0,1,122
0950800329]
[DSP] @0x00006f42:[T:0x8fa4580c] OG - package ti.sdo.ce.video2 (/home/davinc
i/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/video2/) [1,0,2,12209
51347240]
[DSP] @0x00006fd8:[T:0x8fa4580c] OG - package ti.sdo.ce.examples.codecs.vidd
ec2_copy (/home/davinci/dvsdk_1_40_02_33/codec_engine_2_10_02/examples/ti/sdo/ce
/examples/codecs/viddec2_copy/) []
[DSP] @0x0000705a:[T:0x8fa4580c] OG - package ti.sdo.ce.video1 (/home/davinc
i/dvsdk_1_40_02_33/codec_engine_2_10_02/packages/ti/sdo/ce/video1/) [1,0,2,12209
51340734]
[DSP] @0x000070cf:[T:0x8fa4580c] OG - package ti.sdo.ce.examples.codecs.vide
nc1_copy (/home/davinci/dvsdk_1_40_02_33/codec_engine_2_10_02/examples/ti/sdo/ce
/examples/codecs/videnc1_copy/) []
[DSP] @0x00007150:[T:0x8fa4580c] OG - package video_copy (/home/davinci/dvsd
k_1_40_02_33/codec_engine_2_10_02/examples/ti/sdo/ce/examples/servers/video_copy
/evmDM6467/video_copy/) []
[DSP] @0x000071ce:[T:0x8fa4580c] OG - Global_setSpecialTrace> return
[DSP] @0x00007b16:[T:0x8fa4580c] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 8
[DSP] @0x00007b7f:[T:0x8fa4580c] CR - setting trace mask to *=01234567,ti.bios=0
1324567
[DSP] @0x00007bf9:[T:0x8fa4580c] OG - Global_setSpecialTrace> enter(mask='*=0123
[DSP] @0x00007c5b:[T:0x8fa4580c] OG - Global_setSpecialTrace> checking if initia
lized...
[DSP] @0x00007ca9:[T:0x8fa4580c] OG - Global_setSpecialTrace> query returned trc
Mask=0xff
[DSP] @0x00007cfc:[T:0x8fa4580c] OG - Global_setSpecialTrace> return
[DSP] @0x000c7009:[T:0x8fa4580c] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
[DSP] @0x000c7071:[T:0x8fa4580c] CR - remote time = 0x0, trace buffer size = 403
2
[DSP] @0x001964e5:[T:0x8fa4580c] CR - processRmsCmd(0x8fe048a8, 4056): cmd = 6
[DSP] @0x001d1bbe:[T:0x8fa4580c] CR - processRmsCmd(0x8fe048a8, 4056): cmd = 0
[DSP] @0x001d1c2e:[T:0x8fa4580c] OM - Memory_alloc> Enter(size=0x18)
[DSP] @0x001d1c88:[T:0x8fa4580c] OM - Memory_alloc> return (0x8fa466b8)
[DSP] @0x001d1cd9:[T:0x8fa4580c] OM - Memory_alloc> Enter(size=0xf)
[DSP] @0x001d1d51:[T:0x8fa4580c] OM - Memory_alloc> return (0x8fa466d0)
[DSP] @0x001d1dab:[T:0x8fa4580c] OM - Memory_alloc> Enter(size=0x20)
[DSP] @0x001d1dfd:[T:0x8fa4580c] OM - Memory_alloc> return (0x8fa466e0)
[DSP] @0x001d1e4b:[T:0x8fa4580c] OM - Memory_alloc> Enter(size=0x24)
[DSP] @0x001d1ea0:[T:0x8fa4580c] OM - Memory_alloc> return (0x8fa46700)
[DSP] @0x001d1f23:[T:0x8fa4580c] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> Ente
r (engine=0x0, name='videnc1_copy', params=0x8fe048c0)
[DSP] @0x001d1fb4:[T:0x8fa4580c] CV - VISA_create(0x0, 'videnc1_copy', 0x8fe048c
[DSP] @0x001d2034:[T:0x8fa4580c] CV - VISA_create2(0x0, 'videnc1_copy', 0x8fe048
c0, 0x30, 0x2496, 'ti.sdo.ce.video1.IVIDENC1')
[DSP] @0x001d20c1:[T:0x8fa4580c] CE - Engine_open> Enter('local', 0x8fa45d0c, 0x
9c0)
[DSP] @0x001d2122:[T:0x8fa4580c] OM - Memory_alloc> Enter(size=0x2c)
[DSP] @0x001d2173:[T:0x8fa4580c] OM - Memory_alloc> return (0x8fa46770)
[DSP] @0x001d21ca:[T:0x8fa4580c] CE - Engine_open> return(-1885051024)
[DSP] @0x001d2227:[T:0x8fa4580c] OM - Memory_alloc> Enter(size=0x30)
[DSP] @0x001d227c:[T:0x8fa4580c] OM - Memory_alloc> return (0x8fa467a0)
[DSP] @0x001d22ce:[T:0x8fa4580c] ti.sdo.ce.alg.Algorithm - Algorithm_create> Ent
er(fxns=0x8fa6eb6c, idma3Fxns=0x0, params=0x8fe048c0, attrs=0x8fa45e20)
[DSP] @0x001d235a:[T:0x8fa4580c] OM - Memory_alloc> Enter(size=0x10)
[DSP] @0x001d23ac:[T:0x8fa4580c] OM - Memory_alloc> return (0x8fa467d0)
[DSP] @0x001d2469:[T:0x8fa4580c] ti.sdo.ce.alg.Algorithm - Algorithm_create> ret
urn (0x8fa467d0)
[DSP] @0x001d@0x0039f5ce:[T:0x40018528] OC - Comm_locate> return (0)
@0x0049d394:[T:0x40018528] CE - checkServer(0x5bc68)
@0x0049d416:[T:0x40018528] OC - Comm_put> Enter(queue=0x0, msg=0x41adb880)
@0x0049d4cb:[T:0x40018528] OC - Comm_put> return (0)
@0x0049d58b:[T:0x40018528] OC - Comm_get> Enter(queue=0x10002, msg=0xbefffac8, t
imeout=-1)
@0x0049d642:[T:0x40018528] OC - Comm_get> MSGQ_Get() status=0x8000, return (0)
@0x0049d6d5:[T:0x40018528] CE - Engine_open> return(375912)
@0x0049d7e9:[T:0x412cab60] CE - Engine_fwriteTrace(): requesting DSP trace @0x49
d2b0 ...
@0x0049d8c2:[T:0x412cab60] OC - Comm_put> Enter(queue=0x0, msg=0x41ad9880)
@0x0049d983:[T:0x412cab60] OC - Comm_put> return (0)
@0x0049daac:[T:0x412cab60] OC - Comm_get> Enter(queue=0x10000, msg=0x412ca588, t
imeout=-1)
@0x0049db95:[T:0x412cab60] OC - Comm_get> MSGQ_Get() status=0x8000, return (0)
@0x0049dc2b:[T:0x412cab60] CE - Engine_fwriteTrace> got 3250 chars @0x49d2b0 (0
24c6:[T:0x8fa4580c] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> return (0x8fa467a
0)
[DSP] @0x001d2528:[T:0x8fa4580c] OT - Thread_create > name: "videnc1_copy#0", pr
i: -1, stack size: 10288, stack seg: 0
[DSP] @0x001d2c0b:[T:0x8fa4580c] CR - processRmsCmd(0x8fe048a8, 4056): cmd = 1
[DSP] @0x001d441b:[T:0x8fa46bc4] CN - NODE> 0x8fa466e0(videnc1_copy#0) call(algH
andle=0x8fa467a0, msg=0x8fe05880); messageId=0x0002c6cd
[DSP] @0x001d44b4:[T:0x8fa46bc4] ti.sdo.ce.video1.VIDENC1 - VIDENC1_control> Ent
er (handle=0x8fa467a0, id=1, params=0x8fe058b4 (size=0x3c), status=0x8fe058f0 (s
ize=0x9c)
[DSP] @0x001d455f:[T:0x8fa46bc4] CV - VISA_enter(visa=0x8fa467a0): algHandle = 0
x8fa467d0
[DSP] @0x001d45c1:[T:0x8fa46bc4] ti.sdo.ce.alg.Algorithm - Algorithm_activate> E
nter(handle=0x8fa467d0)
[DSP] @0x001d4629:[T:0x8fa46bc4] ti.sdo.ce.alg.Algorithm - Algorithm_activate> r
eturn
[DSP] @0x001d4680:[T:0x8fa46bc4] CV - VISA_exit(visa=0x8fa467a0): algHandle = 0x
8fa467d0
[DSP] @0x001d46df:[T:0x8fa46bc4] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate>
Enter(handle=0x8fa467d0)
[DSP] @0x001d4745:[T:0x8fa46bc4] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate>
return
[DSP] @0x001d4798:[T:0x8fa46bc4] ti.sdo.ce.video1.VIDENC1 - VIDENC1_control> Exi
t (handle=0x8fa467a0, retVal=0xfffffffd)
[DSP] @0x001d4809:[T:0x8fa46bc4] CN - NODE> returned from call(algHandle=0x8fa46
[DSP] @0x002f9572:[T:0x8fa46bc4] CN - NODE_EXECFXN(0x8fa466e0): videnc1_copy#0 e
xiting per request ...
[DSP] @0x002f9c60:[T:0x8fa4580c] CR - processRmsCmd(0x8fe048a8, 4056): cmd = 2
[DSP] @0x002f9e0f:[T:0x8fa4580c] CN - NODE_delete(0x8fa466e0): videnc1_copy#0
[DSP] @0x002f9e95:[T:0x8fa4580c] ti.sdo.ce.video1.VIDENC1 - VIDENC1_delete> Ente
r (handle=0x8fa467a0)
[DSP] @0x002f9ef5:[T:0x8fa4580c] CV - VISA_delete(0x8fa467a0)
[DSP] @0x002f9f42:[T:0x8fa4580c] CV - VISA_delete> deleting codec (localQueue=0x
ffff, remoteQueue=0xffff)
[DSP] @0x002f9fa4:[T:0x8fa4580c] ti.sdo.ce.alg.Algorithm - Algorithm_delete> Ent
[DSP] @0x002fa020:[T:0x8fa4580c] OM - Memory_free> Enter(addr=0x8fa467d0, size=1
6)
[DSP] @0x002fa07a:[T:0x8fa4580c] OM - Memory_free> return (0x1)
[DSP] @0x002fa0c2:[T:0x8fa4580c] ti.sdo.ce.alg.Algorithm - Algorithm_delete> ret
urn
[DSP] @0x002fa111:[T:0x8fa4580c] OM - Memory_free> Enter(addr=0x8fa467a0, size=4
8)
[DSP] @0x002fa184:[T:0x8fa4580c] OM - Memory_free> return (0x1)
[DSP] @0x002fa1cd:[T:0x8fa4580c] ti.sdo.ce.video1.VIDENC1 - VIDENC1_delete> retu
rn
[DSP] @0x002fa21f:[T:0x8fa4580c] OM - Memory_free> Enter(addr=0x8fa46700, size=3
6)
@0x0059c35e:[T:0x43348b60] ti.sdo.dmai - [Capture] COMPOSITE input selected
[DSP] @0x002fa278:[T:0x8fa4580c] OM - Memory_free> return (0x1)
[DSP] @0x002fa2bf:[T:0x8fa4580c] OM - Memory_free> Enter(addr=0x8fa466e0, size=3
2)
[DSP] @0x002fa317:[T:0x8fa4580c] OM - Memory_free> return (0x1)
[DSP] @0x002fa35f:[T:0x8fa4580c] OM - Memory_free> Enter(addr=0x8fa466d0, size=1
5)
[DSP] @0x002fa3b7:[T:0x8fa4580c] OM - Memory_free> return (0x1)
[DSP] @0x002fa3ff:[T:0x8fa4580c] OM - Memory_free> Enter(addr=0x8fa466b8, size=2
4)
[DSP] @0x002fa456:[T:0x8fa4580c] OM - Memory_free> return (0x1)
[DSP] @0x0064cbfc:[T:0x8fa4580c] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
[DSP] @0x0064cc65:[T:0x8fa4580c] CR - remote time = 0x0,@0x0059cd7d:[T:0x43348b6
0] ti.sdo.dmai - [Capture] Capture input set to COMPOSITE
@0x0059ce83:[T:0x43348b60] ti.sdo.dmai - [Capture] Video input connected size 72
0x576 pitch 720
@0x0059cf6d:[T:0x43348b60] ti.sdo.dmai - [BufTab] Allocating BufTab for 4 buffer
s
@0x0059d2cd:[T:0x43348b60] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=
0x44728000, size=4)
@0x0059d384:[T:0x43348b60] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x447
28000, size=4)
@0x0059d41b:[T:0x43348b60] OM - Memory__getPhysicalAddress> returning physAddr=0
x0
@0x0059d4c5:[T:0x43348b60] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x
44728000) = 0x85000000.
@0x0059d56c:[T:0x43348b60] OM - Memory__addContigBuf> Enter(virtAddr=0x44728000,
size=4, physAddr=0x85000000)
@0x0059d60e:[T:0x43348b60] OM - Memory__addContigBuf> creating new contigBuf obj
ect
@0x0059d68b:[T:0x43348b60] OM - Memory_alloc> Enter(0x10)
@0x0059d702:[T:0x43348b60] OM - Memory_alloc> return (0x5bda8)
@0x0059d776:[T:0x43348b60] OM - Memory__addContigBuf> returning: cb->phys=0x8500
0000, cb->size=4, cb->virt=0x44728000
@0x0059d816:[T:0x43348b60] OM - Memory_getBufferPhysicalAddress> return (0x85000
000)
@0x0059d899:[T:0x43348b60] ti.sdo.dmai - [Buffer] Set user pointer 0x44728000 (p
hysical 0x85000000)
@0x005ed7b0:[T:0x43348b60] ti.sdo.dmai - [Dmai] Driver buffer 0 mapped to 0x4472
8000 has physical address 0x85000000
@0x005edb44:[T:0x43348b60] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=
0x44b1d000, size=4)
@0x005edbff:[T:0x43348b60] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x44b
1d000, size=4)
@0x005edc95:[T:0x43348b60] OM - Memory__getPhysicalAddress> returning physAddr=0
x0
@0x005edd2a:[T:0x43348b60] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x
44b1d000) = 0x85400000.
@0x005eddd1:[T:0x43348b60] OM - Memory__addContigBuf> Enter(virtAddr=0x44b1d000,
size=4, physAddr=0x85400000)
@0x005ede72:[T:0x43348b60] OM - Memory__addContigBuf> creating new contigBuf obj
ect
@0x005edef0:[T:0x43348b60] OM - Memory_alloc> Enter(0x10)
@0x005edf69:[T:0x43348b60] OM - Memory_alloc> return (0x5c458)
@0x005edfde:[T:0x43348b60] OM - Memory__addContigBuf> returning: cb->phys=0x8540
0000, cb->size=4, cb->virt=0x44b1d000
@0x005ee07f:[T:0x43348b60] OM - Memory_getBufferPhysicalAddress> return (0x85400
000)
@0x005ee100:[T:0x43348b60] ti.sdo.dmai - [Buffer] Set user pointer 0x44b1d000 (p
hysical 0x85400000)
@0x0063decb:[T:0x43348b60] ti.sdo.dmai - [Dmai] Driver buffer 1 mapped to 0x44b1
d000 has physical address 0x85400000
@0x0063e26b:[T:0x43348b60] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=
0x44f12000, size=4)
@0x0063e325:[T:0x43348b60] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x44f
12000, size=4)
@0x0063e3be:[T:0x43348b60] OM - Memory__getPhysicalAddress> returning physAddr=0
x0
@0x0063e456:[T:0x43348b60] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x
44f12000) = 0x80800000.
@0x0063e4fc:[T:0x43348b60] OM - Memory__addContigBuf> Enter(virtAddr=0x44f12000,
size=4, physAddr=0x80800000)
@0x0063e59f:[T:0x43348b60] OM - Memory__addContigBuf> creating new contigBuf obj
ect
@0x0063e61c:[T:0x43348b60] OM - Memory_alloc> Enter(0x10)
@0x0063e693:[T:0x43348b60] OM - Memory_alloc> return (0x5c470)
@0x0063e708:[T:0x43348b60] OM - Memory__addContigBuf> returning: cb->phys=0x8080
0000, cb->size=4, cb->virt=0x44f12000
@0x0063e7a8:[T:0x43348b60] OM - Memory_getBufferPhysicalAddress> return (0x80800
000)
@0x0063e82c:[T:0x43348b60] ti.sdo.dmai - [Buffer] Set user pointer 0x44f12000 (p
hysical 0x80800000)
@0x0068e5cc:[T:0x43348b60] ti.sdo.dmai - [Dmai] Driver buffer 2 mapped to 0x44f1
2000 has physical address 0x80800000
@0x0068e964:[T:0x43348b60] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=
0x45307000, size=4)
@0x0068ea1f:[T:0x43348b60] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x453
07000, size=4)
@0x0068eab6:[T:0x43348b60] OM - Memory__getPhysicalAddress> returning physAddr=0
x0
@0x0068eb4c:[T:0x43348b60] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x
45307000) = 0x80c00000.
@0x0068ebf1:[T:0x43348b60] OM - Memory__addContigBuf> Enter(virtAddr=0x45307000,
size=4, physAddr=0x80c00000)
@0x0068ec92:[T:0x43348b60] OM - Memory__addContigBuf> creating new contigBuf obj
ect
@0x0068ed10:[T:0x43348b60] OM - Memory_alloc> Enter(0x10)
@0x0068ed88:[T:0x43348b60] OM - Memory_alloc> return (0x5c488)
@0x0068edfd:[T:0x43348b60] OM - Memory__addContigBuf> returning: cb->phys=0x80c0
0000, cb->size=4, cb->virt=0x45307000
@0x0068ee9f:[T:0x43348b60] OM - Memory_getBufferPhysicalAddress> return (0x80c00
000)
@0x0068ef20:[T:0x43348b60] ti.sdo.dmai - [Buffer] Set user pointer 0x45307000 (p
hysical 0x80c00000)
@0x006decd7:[T:0x43348b60] ti.sdo.dmai - [Dmai] Driver buffer 3 mapped to 0x4530
7000 has physical address 0x80c00000
trace buffer size = 4032
[DSP] @0x008a1056:[T:0x8fa4580c] CR - processRmsCmd(0x8fe058a8, 4056): cmd = 6
[DSP] @0x008a1b4c:[T:0x8fa4580c] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
[DSP] @0x008a1bb5:[T:0x8fa4580c] CR - remote time = 0x0, trace buffer size = 403
2
@0x006ece51:[T:0x412cab60] CE - Engine_fwriteTrace> returning count [11956]
@0x006f039f:[T:0x43b48b60] CE - Engine_close(0x5bee8)
@0x006f0440:[T:0x43b48b60] OC - Comm_free> Enter (msg=0x41ada880)
@0x006f0509:[T:0x43b48b60] OC - Comm_free> return (0)
@0x006f0587:[T:0x43b48b60] OC - Comm_delete> Enter (comm=0x5bf18)
@0x006f070c:[T:0x43b48b60] OM - Memory_free> Enter(0x5bf18, 0x4)
@0x006f07b9:[T:0x43b48b60] OM - Memory_free> return (0x1)
@0x006f0836:[T:0x43b48b60] OC - Comm_delete> return
@0x006f08a2:[T:0x43b48b60] OC - Comm_release> Enter(queue=0x0)
@0x006f0927:[T:0x43b48b60] OC - Comm_release> return (0)
@0x006f099c:[T:0x43b48b60] CE - rserverClose(0x5a734), count = 3
@0x006f0a14:[T:0x43b48b60] CE - rserverClose(0x5a734) done.
@0x006f0a7f:[T:0x43b48b60] OM - Memory_free> Enter(0x5bee8, 0x2c)
@0x006f0af9:[T:0x43b48b60] OM - Memory_free> return (0x1)
@0x006fb301:[T:0x40018528] CE - Engine_close(0x5bc68)
@0x006fb39e:[T:0x40018528] OC - Comm_free> Enter (msg=0x41adb880)
@0x006fb466:[T:0x40018528] OC - Comm_free> return (0)
@0x006fb4e0:[T:0x40018528] OC - Comm_delete> Enter (comm=0x5bf28)
@0x006fb665:[T:0x40018528] OM - Memory_free> Enter(0x5bf28, 0x4)
@0x006fb711:[T:0x40018528] OM - Memory_free> return (0x1)
@0x006fb790:[T:0x40018528] OC - Comm_delete> return
@0x006fb7fc:[T:0x40018528] OC - Comm_release> Enter(queue=0x0)
@0x006fb880:[T:0x40018528] OC - Comm_release> return (0)
@0x006fb8f4:[T:0x40018528] CE - rserverClose(0x5a734), count = 2
@0x006fb967:[T:0x40018528] CE - rserverClose(0x5a734) done.
@0x006fb9d3:[T:0x40018528] OM - Memory_free> Enter(0x5bc68, 0x2c)
@0x006fba4e:[T:0x40018528] OM - Memory_free> return (0x1)
@0x00715fe4:[T:0x412cab60] CE - Engine_fwriteTrace(0x5b5b0, '[DSP] ', 0x40201798
@0x007160cb:[T:0x412cab60] CE - Engine_fwriteTrace(): requesting DSP trace @0x71
60bd ...
@0x00716161:[T:0x412cab60] OC - Comm_put> Enter(queue=0x0, msg=0x41ad9880)
@0x0071623c:[T:0x412cab60] OC - Comm_put> return (0)
@0x007162fa:[T:0x412cab60] OC - Comm_get> Enter(queue=0x10000, msg=0x412ca588, t
imeout=-1)
@0x007163b5:[T:0x412cab60] OC - Comm_get> MSGQ_Get() status=0x8000, return (0)
@0x00716447:[T:0x412cab60] CE - Engine_fwriteTrace> got 149 chars @0x7160bd (0 s
[DSP] @0x00e5d68b:[T:0x8fa4580c] CR - processRmsCmd(0x8fe038a8, 4056): cmd = 5
[DSP] @0x00e5d6f4:[T:0x8fa4580c] CR - remote time = 0x0, trace buffer size = 403
2
@0x00716632:[T:0x412cab60] CE - Engine_fwriteTrace> returning count [161]
@0x007166b1:[T:0x412cab60] CE - Engine_close(0x5b5b0)
@0x00716721:[T:0x412cab60] OC - Comm_free> Enter (msg=0x41ad9880)
@0x007167b7:[T:0x412cab60] OC - Comm_free> return (0)
@0x0071682e:[T:0x412cab60] OC - Comm_delete> Enter (comm=0x5b7e8)
@0x007169b0:[T:0x412cab60] OM - Memory_free> Enter(0x5b7e8, 0x4)
@0x00716a5e:[T:0x412cab60] OM - Memory_free> return (0x1)
@0x00716ade:[T:0x412cab60] OC - Comm_delete> return
@0x00716b4b:[T:0x412cab60] OC - Comm_release> Enter(queue=0x0)
@0x00716bd0:[T:0x412cab60] OC - Comm_release> return (0)
@0x00716c4c:[T:0x412cab60] CE - rserverClose(0x5a734), count = 1
@0x00716ce3:[T:0x412cab60] OP - Processor_delete> Enter(proc=0x5b5e0)
@0x00716d60:[T:0x412cab60] OP - doCmd> Enter (cmdId=2, proc=0x5b5e0)
@0x00716ddd:[T:0x412cab60] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x5b240]
@0x00716e77:[T:0x412cab60] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x5b240]
@0x00716eff:[T:0x412cab60] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x5b258] t
imeout[0xffffffff]
@0x00717a1c:[T:0x40acab60] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x5b240] s
tatus[0]
@0x00717adf:[T:0x40acab60] OP - getCmd_d> Exit (result=2)
@0x00717bea:[T:0x40acab60] OP - Processor_delete_d> Enter (proc=0x5b5e0)
@0x00717c7c:[T:0x40acab60] OP - Processor_delete_d> Closing remote transport...
@0x00717e0d:[T:0x40acab60] OP - Processor_delete_d> Stopping DSP...
@0x00717fa2:[T:0x40acab60] OP - Processor_delete_d> Closing pool...
@0x007181d6:[T:0x40acab60] OP - Processor_delete_d> Detaching from DSP...
@0x0071c00e:[T:0x40acab60] OP - Processor_delete_d> Destroying DSP... (object, t
hat is)
@0x0071c474:[T:0x40acab60] OM - Memory_free> Enter(0x5b608, 0x0)
@0x0071c527:[T:0x40acab60] OM - Memory_free> return (0x1)
@0x0071c5a8:[T:0x40acab60] OP - Processor_delete_d> return
@0x0071c61a:[T:0x40acab60] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x5b258]
@0x0071c6c8:[T:0x412cab60] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x5b258] s
tatus[0]
@0x0071c766:[T:0x412cab60] OP - doCmd> Exit (result=1)
@0x0071c7d8:[T:0x412cab60] OP - Processor_delete(0x5b5e0) freeing object ...
@0x0071c858:[T:0x412cab60] OM - Memory_free> Enter(0x5b5e0, 0x24)
@0x0071c8d8:[T:0x412cab60] OM - Memory_free> return (0x1)
@0x0071c947:[T:0x412cab60] OP - Processor_delete> return.
@0x0071c9b1:[T:0x412cab60] CE - rserverClose(0x5a734) done.
@0x0071ca22:[T:0x412cab60] OM - Memory_free> Enter(0x5b5b0, 0x2c)
@0x0071ca9e:[T:0x412cab60] OM - Memory_free> return (0x1)
@0x00733771:[T:0x40018528] OG - Global_exit> enter
@0x0073380b:[T:0x40018528] OG - Global_exit> calling function *0x11c04()...
@0x007338ab:[T:0x40018528] OG - Global_exit> calling function *0x242ec()...
@0x00733952:[T:0x40018528] OG - Global_exit> calling function *0x2579c()...
@0x007339d4:[T:0x40018528] OM - Memory_free> Enter(0x5b488, 0x18)
@0x00733a53:[T:0x40018528] OM - Memory_free> return (0x1)
@0x00733ac3:[T:0x40018528] OM - Memory_free> Enter(0x5b4a8, 0x18)
@0x00733b3b:[T:0x40018528] OM - Memory_free> return (0x1)
@0x00733ba9:[T:0x40018528] OM - Memory_free> Enter(0x5b4c8, 0x18)
@0x00733c20:[T:0x40018528] OM - Memory_free> return (0x1)
@0x00733c8f:[T:0x40018528] OG - Global_exit> calling function *0x2d9e4()...
@0x00733d0a:[T:0x40018528] OG - Global_exit> calling function *0x28418()...
@0x00733d86:[T:0x40018528] OG - Global_exit> calling function *0x28978()...
@0x00733e02:[T:0x40018528] OG - Global_exit> calling function *0x2b524()...
@0x00733e7d:[T:0x40018528] OG - Global_exit> calling function *0x29430()...
@0x00733ef7:[T:0x40018528] OP - doCmd> Enter (cmdId=3, proc=0x0)
@0x00733f6b:[T:0x40018528] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x5b240]
@0x00733ff4:[T:0x40018528] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x5b240]
@0x00734074:[T:0x40018528] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x5b258] t
imeout[0xffffffff]
@0x00734138:[T:0x40acab60] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x5b258]
@0x007341cd:[T:0x40acab60] OP - getCmd_d> Enter (proc=0x40aca5a4)
@0x0073424a:[T:0x40acab60] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x5b240] t
imeout[0xffffffff]
@0x007342db:[T:0x40acab60] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x5b240] s
tatus[0]
@0x00734366:[T:0x40acab60] OP - getCmd_d> Exit (result=3)
@0x007343f1:[T:0x40acab60] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x5b258]
@0x0073449c:[T:0x40018528] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x5b258] s
tatus[0]
@0x00734534:[T:0x40018528] OP - doCmd> Exit (result=1)
@0x007345a3:[T:0x40018528] OT - Thread_delete> Enter (task=0x5b290)
@0x0073481d:[T:0x40acab60] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x5b258]
@0x00734dd3:[T:0x40018528] OT - Thread_delete> pthread_cancel (0x0)
@0x0074b665:[T:0x40018528] OT - Thread_delete> pthread_join (0x0)
@0x0074b70c:[T:0x40018528] OM - Memory_free> Enter(0x5b290, 0x64)
@0x0074b798:[T:0x40018528] OM - Memory_free> return (0x1)
@0x0074b80b:[T:0x40018528] OT - Thread_delete> Exit (task=0x5b290)
@0x0074b89e:[T:0x40018528] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0x5b240]
@0x0074b93b:[T:0x40018528] OM - Memory_free> Enter(0x5b240, 0x14)
@0x0074b9c5:[T:0x40018528] OM - Memory_free> return (0x1)
@0x0074ba37:[T:0x40018528] ti.sdo.ce.osal.Sem - Leaving Sem_delete>
@0x0074baa4:[T:0x40018528] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0x5b258]
@0x0074bb61:[T:0x40018528] OM - Memory_free> Enter(0x5b258, 0x14)
@0x0074bbee:[T:0x40018528] OM - Memory_free> return (0x1)
@0x0074bc5f:[T:0x40018528] ti.sdo.ce.osal.Sem - Leaving Sem_delete>
@0x0074bcd2:[T:0x40018528] OM - Memory_free> Enter(0x5b270, 0x18)
@0x0074bd4c:[T:0x40018528] OM - Memory_free> return (0x1)
@0x0074bdbb:[T:0x40018528] OG - Global_exit> calling function *0x2d880()...
@0x0074be54:[T:0x40018528] OG - Global_exit> calling function *0x2a730()...
@0x0074bedd:[T:0x40018528] OM - Memory_free> Enter(0x5b1c0, 0x18)
@0x0079db30:[T:0x40018528] OM - Memory_free> return (0x1)
@0x0079dbc9:[T:0x40018528] OG - Global_exit> calling function *0x2cae4()...
@0x0079dc68:[T:0x40018528] OM - Memory_free> Enter(0x5b170, 0x18)
@0x0079dcf0:[T:0x40018528] OM - Memory_free> return (0x1)
@0x0079dd69:[T:0x40018528] OG - Global_exit> calling function *0x1186c()...
@0x0079dde9:[T:0x40018528] OM - Memory_free> Enter(0x5b7f8, 0x18)
@0x0079de63:[T:0x40018528] OM - Memory_free> return (0x1)
@0x0079ded3:[T:0x40018528] OG - Global_exit> calling function *0x2e1fc()...
@0x0079df50:[T:0x40018528] OG - Global_exit> calling function *0x2ed64()...
@0x0079dfcd:[T:0x40018528] OG - Global_exit> calling function *0x2dc08()...
root@192.168.1.104:/opt/ImageBinary#
and the dvsdk is version 1.4,
who can help me,thank you,and I am a beginner on 6467,and in trouble of being without an example, if anyone can give me simple one , thanks very much ,my email is pdgphm@163.com . Foward to receive your replies!
thanks
