AM4378: eMMC recognition problem
Part Number: AM4378
Hi, Forum.
I have an eMMC problem on AM4378 Custom board.
in u-boot
=> mmc list
OMAP SD/MMC: 0 (SD)
OMAP SD/MMC: 1
=> mmc dev 1
switch to partitions #0, OK
mmc1(part 0) is current device
=> mmc info
Device: OMAP SD/MMC
Manufacturer ID: 9d
OEM: 101
Bus Speed: 48000000
Mode : MMC High Speed (52MHz)
Rd Block Len: 512
MMC version 5.0
High Capacity: Yes
Capacity: 3.6 GiB
Bus Width: 8-bit
Erase Group Size: 512 KiB
HC WP Group Size: 8 MiB
User Capacity: 3.6 GiB WRREL
Boot Capacity: 2 MiB ENH
RPMB Capacity: 512 KiB ENH
=> mmc list
OMAP SD/MMC: 0 (SD)
OMAP SD/MMC: 1 (eMMC)
in kernel
fdisk -l
Disk /dev/mmcblk1: 59.5 GiB, 63864569856 bytes, 124735488 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xcba0b265
Device Boot Start End Sectors Size Id Type
/dev/mmcblk1p1 * 2048 145407 143360 70M c W95 FAT32 (LBA)
/dev/mmcblk1p2 145408 24543231 24397824 11.6G 83 Linux
dmesg | grep -i "mmc"
If have any ideas, please share to me.
Thank you.
    Are you seeing any errors? Or are you just concerned about the "of_get_named_gpoid_flags" outputs? These are expected, since your device tree entry will not provide all available options. See Documentation/devicetree/bindings/mmc/mmc.txt for more information.
    Nick
  • I want to be able to mount eMMC and use it on linux OS.
    The U-boot code is as follows.
    /dts-v1/;
    #include "am4372.dtsi"
    #include <dt-bindings/pinctrl/am43xx.h>
    #include <dt-bindings/pwm/pwm.h>
    #include <dt-bindings/gpio/gpio.h>
    #include <dt-bindings/input/input.h>
    #include <dt-bindings/interrupt-controller/irq.h>
    	model = "TI AM437x SK EVM";
    	compatible = "ti,am437x-sk-evm","ti,am4372","ti,am43";
    	chosen {
    		stdout-path = &uart0;
    	evm_v3_3d: fixedregulator-v3_3d {
            compatible = "regulator-fixed";
            regulator-name = "evm_v3_3d";
            regulator-min-microvolt = <3300000>;
            regulator-max-microvolt = <3300000>;
            enable-active-high;
            regulator-boot-on;
            regulator-always-on;
    &am43xx_pinmux {
    	mycam1_pins_default: mycam1_pins_default {
    		pinctrl-single,pins = <
    			AM4372_IOPAD(0x9b0, PIN_INPUT | MUX_MODE0) /* (AE17) cam0_hd.cam0_hd */
    			AM4372_IOPAD(0x9b4, PIN_INPUT | MUX_MODE0) /* (AD18) cam0_vd.cam0_vd */
    			AM4372_IOPAD(0x9c0, PIN_INPUT | MUX_MODE0) /* (AC20) cam0_pclk.cam0_pclk */
    			AM4372_IOPAD(0xa08, PIN_INPUT | MUX_MODE0) /* (AE18) cam0_data0.cam0_data0 */
    			AM4372_IOPAD(0xa0c, PIN_INPUT | MUX_MODE0) /* (AB18) cam0_data1.cam0_data1 */
    			AM4372_IOPAD(0xa10, PIN_INPUT | MUX_MODE0) /* (Y18) cam0_data2.cam0_data2 */
    			AM4372_IOPAD(0xa14, PIN_INPUT | MUX_MODE0) /* (AA18) cam0_data3.cam0_data3 */
    			AM4372_IOPAD(0xa18, PIN_INPUT | MUX_MODE0) /* (AE19) cam0_data4.cam0_data4 */
    			AM4372_IOPAD(0xa1c, PIN_INPUT | MUX_MODE0) /* (AD19) cam0_data5.cam0_data5 */
    			AM4372_IOPAD(0xa20, PIN_INPUT | MUX_MODE0) /* (AE20) cam0_data6.cam0_data6 */
    			AM4372_IOPAD(0xa24, PIN_INPUT | MUX_MODE0) /* (AD20) cam0_data7.cam0_data7 */
    	mydebugss1_pins_default: mydebugss1_pins_default {
    			AM4372_IOPAD(0xa90, PIN_INPUT | MUX_MODE0) /* (Y24) TMS.TMS */
    			AM4372_IOPAD(0xa94, PIN_INPUT | MUX_MODE0) /* (Y20) TDI.TDI */
    			AM4372_IOPAD(0xa98, PIN_OUTPUT | MUX_MODE0) /* (AA24) TDO.TDO */
    			AM4372_IOPAD(0xa9c, PIN_INPUT | MUX_MODE0) /* (AA25) TCK.TCK */
    			AM4372_IOPAD(0xaa0, PIN_INPUT | MUX_MODE0) /* (Y25) nTRST.nTRST */
    			AM4372_IOPAD(0xaa4, PIN_INPUT | MUX_MODE0) /* (N23) EMU0.EMU0 */
    			AM4372_IOPAD(0xaa8, PIN_INPUT | MUX_MODE0) /* (T24) EMU1.EMU1 */
    	mydss1_pins_default: mydss1_pins_default {
    			AM4372_IOPAD(0x8e0, PIN_OUTPUT | MUX_MODE0) /* (B23) dss_vsync.dss_vsync */
    			AM4372_IOPAD(0x8e4, PIN_OUTPUT | MUX_MODE0) /* (A23) dss_hsync.dss_hsync */
    			AM4372_IOPAD(0x8e8, PIN_OUTPUT | MUX_MODE0) /* (A22) dss_pclk.dss_pclk */
    			AM4372_IOPAD(0x8ec, PIN_OUTPUT | MUX_MODE0) /* (A24) dss_ac_bias_en.dss_ac_bias_en */
    			AM4372_IOPAD(0x8a0, PIN_OUTPUT | MUX_MODE0) /* (B22) dss_data0.dss_data0 */
    			AM4372_IOPAD(0x8a4, PIN_OUTPUT | MUX_MODE0) /* (A21) dss_data1.dss_data1 */
    			AM4372_IOPAD(0x8a8, PIN_OUTPUT | MUX_MODE0) /* (B21) dss_data2.dss_data2 */
    			AM4372_IOPAD(0x8ac, PIN_OUTPUT | MUX_MODE0) /* (C21) dss_data3.dss_data3 */
    			AM4372_IOPAD(0x8b0, PIN_OUTPUT | MUX_MODE0) /* (A20) dss_data4.dss_data4 */
    			AM4372_IOPAD(0x8b4, PIN_OUTPUT | MUX_MODE0) /* (B20) dss_data5.dss_data5 */
    			AM4372_IOPAD(0x8b8, PIN_OUTPUT | MUX_MODE0) /* (C20) dss_data6.dss_data6 */
    			AM4372_IOPAD(0x8bc, PIN_OUTPUT | MUX_MODE0) /* (E19) dss_data7.dss_data7 */
    			AM4372_IOPAD(0x8c0, PIN_OUTPUT | MUX_MODE0) /* (A19) dss_data8.dss_data8 */
    			AM4372_IOPAD(0x8c4, PIN_OUTPUT | MUX_MODE0) /* (B19) dss_data9.dss_data9 */
    			AM4372_IOPAD(0x8c8, PIN_OUTPUT | MUX_MODE0) /* (A18) dss_data10.dss_data10 */
    			AM4372_IOPAD(0x8cc, PIN_OUTPUT | MUX_MODE0) /* (B18) dss_data11.dss_data11 */
    			AM4372_IOPAD(0x8d0, PIN_OUTPUT | MUX_MODE0) /* (C19) dss_data12.dss_data12 */
    			AM4372_IOPAD(0x8d4, PIN_OUTPUT | MUX_MODE0) /* (D19) dss_data13.dss_data13 */
    			AM4372_IOPAD(0x8d8, PIN_OUTPUT | MUX_MODE0) /* (C17) dss_data14.dss_data14 */
    			AM4372_IOPAD(0x8dc, PIN_OUTPUT | MUX_MODE0) /* (D17) dss_data15.dss_data15 */
    			AM4372_IOPAD(0x83c, PIN_OUTPUT | MUX_MODE1) /* (A11) gpmc_ad15.dss_data16 */
    			AM4372_IOPAD(0x838, PIN_OUTPUT | MUX_MODE1) /* (B11) gpmc_ad14.dss_data17 */
    			AM4372_IOPAD(0x834, PIN_OUTPUT | MUX_MODE1) /* (C11) gpmc_ad13.dss_data18 */
    			AM4372_IOPAD(0x830, PIN_OUTPUT | MUX_MODE1) /* (E11) gpmc_ad12.dss_data19 */
    			AM4372_IOPAD(0x82c, PIN_OUTPUT | MUX_MODE1) /* (D11) gpmc_ad11.dss_data20 */
    			AM4372_IOPAD(0x828, PIN_OUTPUT | MUX_MODE1) /* (F11) gpmc_ad10.dss_data21 */
    			AM4372_IOPAD(0x824, PIN_OUTPUT | MUX_MODE1) /* (A10) gpmc_ad9.dss_data22 */
    			AM4372_IOPAD(0x820, PIN_OUTPUT | MUX_MODE1) /* (B10) gpmc_ad8.dss_data23 */
    	mygpio1_pins_default: mygpio1_pins_default {
    			AM4372_IOPAD(0x9d0, PIN_INPUT | MUX_MODE7) /* (AD24) cam1_data8.gpio4[8] */
    			AM4372_IOPAD(0x9d4, PIN_INPUT | MUX_MODE7) /* (AD25) cam1_hd.gpio4[9] */
    			AM4372_IOPAD(0x9d8, PIN_INPUT | MUX_MODE7) /* (AC23) cam1_vd.gpio4[10] */
    			AM4372_IOPAD(0x9dc, PIN_INPUT | MUX_MODE7) /* (AE21) cam1_pclk.gpio4[11] */
    			AM4372_IOPAD(0x9e0, PIN_INPUT | MUX_MODE7) /* (AC25) cam1_field.gpio4[12] */
    			AM4372_IOPAD(0x9e4, PIN_INPUT | MUX_MODE7) /* (AB25) cam1_wen.gpio4[13] */
    			AM4372_IOPAD(0x9e8, PIN_INPUT | MUX_MODE7) /* (AB20) cam1_data0.gpio4[14] */
    			AM4372_IOPAD(0x9ec, PIN_INPUT | MUX_MODE7) /* (AC21) cam1_data1.gpio4[15] */
    			AM4372_IOPAD(0x9f0, PIN_INPUT | MUX_MODE7) /* (AD21) cam1_data2.gpio4[16] */
    			AM4372_IOPAD(0x9f4, PIN_INPUT | MUX_MODE7) /* (AE22) cam1_data3.gpio4[17] */
    			AM4372_IOPAD(0x9f8, PIN_INPUT | MUX_MODE7) /* (AD22) cam1_data4.gpio4[18] */
    			AM4372_IOPAD(0x9fc, PIN_INPUT | MUX_MODE7) /* (AE23) cam1_data5.gpio4[19] */
    			AM4372_IOPAD(0xa00, PIN_INPUT | MUX_MODE7) /* (AD23) cam1_data6.gpio4[20] */
    			AM4372_IOPAD(0xa04, PIN_INPUT | MUX_MODE7) /* (AE24) cam1_data7.gpio4[21] */
    	myi2c1_pins_default: myi2c1_pins_default {
    			AM4372_IOPAD(0x98c, PIN_INPUT | MUX_MODE0) /* (Y22) I2C0_SCL.I2C0_SCL */
    			AM4372_IOPAD(0x988, PIN_INPUT | MUX_MODE0) /* (AB24) I2C0_SDA.I2C0_SDA */
    	myi2c2_pins_default: myi2c2_pins_default {
    			AM4372_IOPAD(0xa40, PIN_INPUT | MUX_MODE1) /* (G20) gpio5_10.I2C1_SCL */
    			AM4372_IOPAD(0xa48, PIN_INPUT | MUX_MODE1) /* (E25) gpio5_12.I2C1_SDA */
    	mymcasp1_pins_default: mymcasp1_pins_default {
    			AM4372_IOPAD(0x990, PIN_INPUT | MUX_MODE0) /* (N24) mcasp0_aclkx.mcasp0_aclkx */
    			AM4372_IOPAD(0x994, PIN_INPUT | MUX_MODE0) /* (N22) mcasp0_fsx.mcasp0_fsx */
    			AM4372_IOPAD(0x998, PIN_OUTPUT | MUX_MODE0) /* (H23) mcasp0_axr0.mcasp0_axr0 */
    			AM4372_IOPAD(0x9a8, PIN_OUTPUT | MUX_MODE0) /* (M25) mcasp0_axr1.mcasp0_axr1 */
    	mymdio1_pins_default: mymdio1_pins_default {
    			AM4372_IOPAD(0x94c, PIN_OUTPUT | MUX_MODE0) /* (B17) mdio_clk.mdio_clk */
    			AM4372_IOPAD(0x948, PIN_INPUT | MUX_MODE0) /* (A17) mdio_data.mdio_data */
            cpsw_default: cpsw_default {
               		AM4372_IOPAD(0x878, PIN_INPUT | MUX_MODE1) /* (A3) gpmc_be1n.gmii2_col */
    			AM4372_IOPAD(0x870, PIN_INPUT | MUX_MODE1) /* (A2) gpmc_wait0.gmii2_crs */
    			AM4372_IOPAD(0x874, PIN_INPUT | MUX_MODE1) /* (B3) gpmc_wpn.gmii2_rxer */
    			AM4372_IOPAD(0x840, PIN_OUTPUT | MUX_MODE1) /* (C3) gpmc_a0.gmii2_txen */
    			AM4372_IOPAD(0x844, PIN_INPUT | MUX_MODE1) /* (C5) gpmc_a1.gmii2_rxdv */
    			AM4372_IOPAD(0x858, PIN_INPUT | MUX_MODE1) /* (E8) gpmc_a6.gmii2_txclk */
    			AM4372_IOPAD(0x85c, PIN_INPUT | MUX_MODE1) /* (F6) gpmc_a7.gmii2_rxclk */
    			AM4372_IOPAD(0x854, PIN_OUTPUT | MUX_MODE1) /* (E7) gpmc_a5.gmii2_txd0 */
    			AM4372_IOPAD(0x850, PIN_OUTPUT | MUX_MODE1) /* (D7) gpmc_a4.gmii2_txd1 */
    			AM4372_IOPAD(0x84c, PIN_OUTPUT | MUX_MODE1) /* (A4) gpmc_a3.gmii2_txd2 */
    			AM4372_IOPAD(0x848, PIN_OUTPUT | MUX_MODE1) /* (C6) gpmc_a2.gmii2_txd3 */
    			AM4372_IOPAD(0x86c, PIN_INPUT | MUX_MODE1) /* (D8) gpmc_a11.gmii2_rxd0 */
    			AM4372_IOPAD(0x868, PIN_INPUT | MUX_MODE1) /* (G8) gpmc_a10.gmii2_rxd1 */
    			AM4372_IOPAD(0x864, PIN_INPUT | MUX_MODE1) /* (B4) gpmc_a9.gmii2_rxd2 */
    			AM4372_IOPAD(0x860, PIN_INPUT | MUX_MODE1) /* (F7) gpmc_a8.gmii2_rxd3 */
    			AM4372_IOPAD(0x908, PIN_INPUT | MUX_MODE0) /* (D16) mii1_col.gmii1_col */
    			AM4372_IOPAD(0x90c, PIN_INPUT | MUX_MODE0) /* (B14) mii1_crs.gmii1_crs */
    			AM4372_IOPAD(0x910, PIN_INPUT | MUX_MODE0) /* (B13) mii1_rx_er.gmii1_rxer */
    			AM4372_IOPAD(0x914, PIN_OUTPUT | MUX_MODE0) /* (A13) mii1_tx_en.gmii1_txen */
    			AM4372_IOPAD(0x918, PIN_INPUT | MUX_MODE0) /* (A15) mii1_rx_dv.gmii1_rxdv */
    			AM4372_IOPAD(0x92c, PIN_INPUT | MUX_MODE0) /* (D14) mii1_tx_clk.gmii1_txclk */
    			AM4372_IOPAD(0x930, PIN_INPUT | MUX_MODE0) /* (D13) mii1_rx_clk.gmii1_rxclk */
    			AM4372_IOPAD(0x928, PIN_OUTPUT | MUX_MODE0) /* (B15) mii1_txd0.gmii1_txd0 */
    			AM4372_IOPAD(0x924, PIN_OUTPUT | MUX_MODE0) /* (A14) mii1_txd1.gmii1_txd1 */
    			AM4372_IOPAD(0x920, PIN_OUTPUT | MUX_MODE0) /* (C13) mii1_txd2.gmii1_txd2 */
    			AM4372_IOPAD(0x91c, PIN_OUTPUT | MUX_MODE0) /* (C16) mii1_txd3.gmii1_txd3 */
    			AM4372_IOPAD(0x940, PIN_INPUT | MUX_MODE0) /* (F17) mii1_rxd0.gmii1_rxd0 */
    			AM4372_IOPAD(0x93c, PIN_INPUT | MUX_MODE0) /* (B16) mii1_rxd1.gmii1_rxd1 */
    			AM4372_IOPAD(0x938, PIN_INPUT | MUX_MODE0) /* (E16) mii1_rxd2.gmii1_rxd2 */
    			AM4372_IOPAD(0x934, PIN_INPUT | MUX_MODE0) /* (C14) mii1_rxd3.gmii1_rxd3 */
    	mymmc1_pins_default: mymmc1_pins_default {
    			AM4372_IOPAD(0x900, PIN_INPUT | MUX_MODE0) /* (D1) mmc0_clk.mmc0_clk */
    			AM4372_IOPAD(0x904, PIN_INPUT | MUX_MODE0) /* (D2) mmc0_cmd.mmc0_cmd */
    			AM4372_IOPAD(0x8fc, PIN_INPUT | MUX_MODE0) /* (C1) mmc0_dat0.mmc0_dat0 */
    			AM4372_IOPAD(0x8f8, PIN_INPUT | MUX_MODE0) /* (C2) mmc0_dat1.mmc0_dat1 */
    			AM4372_IOPAD(0x8f4, PIN_INPUT | MUX_MODE0) /* (B2) mmc0_dat2.mmc0_dat2 */
    			AM4372_IOPAD(0x8f0, PIN_INPUT | MUX_MODE0) /* (B1) mmc0_dat3.mmc0_dat3 */
    			AM4372_IOPAD(0x960, PIN_INPUT | MUX_MODE5) /* (R25) spi0_cs1.mmc0_sdcd */
    			AM4372_IOPAD(0x9a0, PIN_INPUT | MUX_MODE4) /* (L23) mcasp0_aclkr.mmc0_sdwp */
    	mymmc2_pins_default: mymmc2_pins_default {
    			AM4372_IOPAD(0x880, PIN_INPUT | MUX_MODE2) /* (B9) gpmc_csn1.mmc1_clk */
    			AM4372_IOPAD(0x884, PIN_INPUT | MUX_MODE2) /* (F10) gpmc_csn2.mmc1_cmd */
    			AM4372_IOPAD(0x800, PIN_INPUT | MUX_MODE1) /* (B5) gpmc_ad0.mmc1_dat0 */
    			AM4372_IOPAD(0x804, PIN_INPUT | MUX_MODE1) /* (A5) gpmc_ad1.mmc1_dat1 */
    			AM4372_IOPAD(0x808, PIN_INPUT | MUX_MODE1) /* (B6) gpmc_ad2.mmc1_dat2 */
    			AM4372_IOPAD(0x80c, PIN_INPUT | MUX_MODE1) /* (A6) gpmc_ad3.mmc1_dat3 */
    			AM4372_IOPAD(0x810, PIN_INPUT | MUX_MODE1) /* (B7) gpmc_ad4.mmc1_dat4 */
    			AM4372_IOPAD(0x814, PIN_INPUT | MUX_MODE1) /* (A7) gpmc_ad5.mmc1_dat5 */
    			AM4372_IOPAD(0x818, PIN_INPUT | MUX_MODE1) /* (C8) gpmc_ad6.mmc1_dat6 */
    			AM4372_IOPAD(0x81c, PIN_INPUT | MUX_MODE1) /* (B8) gpmc_ad7.mmc1_dat7 */
    	myosc1_pins_default: myosc1_pins_default {
    			AM4372_IOPAD(0xaac, PIN_INPUT | MUX_MODE0) /* (AE5) RTC_XTALIN.OSC1_IN */
    			AM4372_IOPAD(0xab0, PIN_OUTPUT | MUX_MODE0) /* (AE4) RTC_XTALOUT.OSC1_OUT */
    	myosc2_pins_default: myosc2_pins_default {
    			AM4372_IOPAD(0xa88, PIN_INPUT | MUX_MODE0) /* (C25) XTALIN.OSC0_IN */
    			AM4372_IOPAD(0xa8c, PIN_OUTPUT | MUX_MODE0) /* (B25) XTALOUT.OSC0_OUT */
    	myrtc1_pins_default: myrtc1_pins_default {
    			AM4372_IOPAD(0xab4, PIN_INPUT | MUX_MODE0) /* (AE6) RTC_PWRONRSTn.RTC_PORz */
    			AM4372_IOPAD(0xab8, PIN_OUTPUT | MUX_MODE0) /* (AE3) RTC_WAKEUP.RTC_WAKEUP */
    			AM4372_IOPAD(0xabc, PIN_INPUT | MUX_MODE0) /* (AD6) RTC_PMIC_EN.RTC_PMIC_EN */
    	myspi1_pins_default: myspi1_pins_default {
    			AM4372_IOPAD(0x950, PIN_INPUT | MUX_MODE0) /* (P23) spi0_sclk.spi0_sclk */
    			AM4372_IOPAD(0x954, PIN_INPUT | MUX_MODE0) /* (T22) spi0_d0.spi0_d0 */
    			AM4372_IOPAD(0x958, PIN_INPUT | MUX_MODE0) /* (T21) spi0_d1.spi0_d1 */
    			AM4372_IOPAD(0x95c, PIN_OUTPUT | MUX_MODE0) /* (T20) spi0_cs0.spi0_cs0 */
    	myspi2_pins_default: myspi2_pins_default {
    			AM4372_IOPAD(0x964, PIN_INPUT | MUX_MODE4) /* (G24) eCAP0_in_PWM0_out.spi1_sclk */
    			AM4372_IOPAD(0x968, PIN_INPUT | MUX_MODE4) /* (L25) uart0_ctsn.spi1_d0 */
    			AM4372_IOPAD(0x96c, PIN_INPUT | MUX_MODE4) /* (J25) uart0_rtsn.spi1_d1 */
    			AM4372_IOPAD(0x944, PIN_OUTPUT | MUX_MODE2) /* (A16) rmii1_ref_clk.spi1_cs0 */
    	myuart1_pins_default: myuart1_pins_default {
    			AM4372_IOPAD(0xa28, PIN_INPUT | MUX_MODE0) /* (H25) uart3_rxd.uart3_rxd */
    			AM4372_IOPAD(0xa2c, PIN_OUTPUT | MUX_MODE0) /* (H24) uart3_txd.uart3_txd */
    	myuart2_pins_default: myuart2_pins_default {
    			AM4372_IOPAD(0x980, PIN_INPUT | MUX_MODE0) /* (K21) uart1_rxd.uart1_rxd */
    			AM4372_IOPAD(0x984, PIN_OUTPUT | MUX_MODE0) /* (L21) uart1_txd.uart1_txd */
    	myuart3_pins_default: myuart3_pins_default {
    			AM4372_IOPAD(0x970, PIN_INPUT | MUX_MODE0) /* (K25) uart0_rxd.uart0_rxd */
    			AM4372_IOPAD(0x974, PIN_OUTPUT | MUX_MODE0) /* (J24) uart0_txd.uart0_txd */
    	myusb1_pins_default: myusb1_pins_default {
    			AM4372_IOPAD(0xac0, PIN_OUTPUT | MUX_MODE0) /* (G21) USB0_DRVVBUS.USB0_DRVVBUS */
    	myusb2_pins_default: myusb2_pins_default {
    			AM4372_IOPAD(0xac4, PIN_OUTPUT | MUX_MODE0) /* (F25) USB1_DRVVBUS.USB1_DRVVBUS */
    &i2c0 {
    	status = "okay";
    	pinctrl-names = "default";
    	pinctrl-0 = <&myi2c1_pins_default>;
    	clock-frequency = <100000>;
    	tps@24 {
    		compatible = "ti,tps65218";
    		reg = <0x24>;
    		interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>;
    		interrupt-controller;
    		#interrupt-cells = <2>;
    		dcdc1: regulator-dcdc1 {
    			/* VDD_CORE limits min of OPP50 and max of OPP100 */
    			regulator-name = "vdd_core";
    			regulator-min-microvolt = <912000>;
    			regulator-max-microvolt = <1144000>;
    			regulator-boot-on;
    		dcdc2: regulator-dcdc2 {
    			/* VDD_MPU limits min of OPP50 and max of OPP_NITRO */
    			regulator-name = "vdd_mpu";
    			regulator-max-microvolt = <1378000>;
    			regulator-boot-on;
    		dcdc3: regulator-dcdc3 {
    			regulator-name = "vdds_ddr";
    			regulator-boot-on;
    			regulator-state-mem {
    				regulator-on-in-suspend;
    			regulator-state-disk {
    				regulator-off-in-suspend;
    		dcdc4: regulator-dcdc4 {
    			regulator-name = "v3_3d";
    			regulator-boot-on;
    		dcdc5: regulator-dcdc5 {
    			compatible = "ti,tps65218-dcdc5";
    			regulator-name = "v1_0bat";
    			regulator-min-microvolt = <1000000>;
    			regulator-max-microvolt = <1000000>;
    			regulator-boot-on;
    		dcdc6: regulator-dcdc6 {
    			compatible = "ti,tps65218-dcdc6";
    			regulator-name = "v1_8bat";
    			regulator-min-microvolt = <1800000>;
    			regulator-max-microvolt = <1800000>;
    			regulator-boot-on;
    		ldo1: regulator-ldo1 {
    			regulator-name = "v1_8d";
    			regulator-boot-on;
    		power-button {
    			compatible = "ti,tps65218-pwrbutton";
    			status = "okay";
    			interrupts = <3 IRQ_TYPE_EDGE_BOTH>;
    	at24@50 {
    		compatible = "atmel,24c256";
    		pagesize = <64>;
    		reg = <0x50>;
    &epwmss0 {
    	status = "okay";
    &gpio1 {
    	status = "okay";
    &gpio4 {
    	status = "okay";
    &mmc1 {
    	status = "okay";
    	pinctrl-0 = <&mymmc1_pins_default>;
    	vmmc-supply = <&evm_v3_3d>;//<&dcdc4>;
    	bus-width = <4>;
    	cd-gpios = <&gpio0 6 GPIO_ACTIVE_LOW>;
    &mmc2 {
    	status = "okay";
    	pinctrl-0 = <&mymmc2_pins_default>;
    	bus-width = <8>;
    	ti,non-removable;
    &uart1 {
    	status = "okay";
    	pinctrl-names = "default", "sleep";
    	pinctrl-0 = <&myuart1_pins_default>;
    &uart2 {
    	status = "okay";
    	pinctrl-0 = <&myuart2_pins_default>;
    &uart3 {
    	status = "okay";
    	pinctrl-0 = <&myuart3_pins_default>;
    &usb1 {
    	dr_mode = "host";
    	status = "okay";
    	pinctrl-0 = <&myusb1_pins_default>;
    &usb2 {
    	dr_mode = "host";
    	status = "okay";
    	pinctrl-0 = <&myusb2_pins_default>;
    &mac {
        pinctrl-0 = <&cpsw_default>;
        dual_emac = <2>;
        status = "okay";
    &cpsw_emac0 {
            phy-handle = <&dp83867_0>;
            phy_id = <&davinci_mdio>, <4>;
            phy-mode = "mii";
            ti,dual-emac-pvid = <1>;
    	fixed-link {
    	speed = <100>;
    	full-duplex;
    &cpsw_emac1 {
            phy-handle = <&dp83867_1>;
            phy_id = <&davinci_mdio>, <5>;
            phy-mode = "mii";
            ti,dual-emac-pvid = <2>;
    	fixed-link {
    	speed = <100>;
    	full-duplex;
    &davinci_mdio {
        pinctrl-0 = <&mymdio1_pins_default>;
        status = "okay";
        dp83867_0: ethernet-phy@4 {
            reg = <4>;
            ti,min-output-impedance;
            ti,dp83867-rxctrl-strap-quirk;
        dp83867_1: ethernet-phy@5 {
            reg = <5>;
    &phy_sel {
    	rmii-clock-ext;
    &elm {
    	status = "okay";
    &wdt {
    	status = "okay";
    &cpu {
    	cpu0-supply = <&dcdc2>;
    &sgx {
    	status = "okay";
    &wkup_m3_ipc {
    	ti,scale-data-fw = "am43x-evm-scale-data.bin";
    &pruss_soc_bus {
    	status = "okay";
    	pruss1: pruss@54400000 {
    		status = "okay";
    	pruss0: pruss@54440000 {
    		status = "okay";
    and mux.c is.
    // SPDX-License-Identifier: GPL-2.0+
     * mux.c
     * Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/
    #include <common.h>
    #include <asm/arch/sys_proto.h>
    #include <asm/arch/mux.h>
    #include "../common/board_detect.h"
    #include "board.h"
    static struct module_pin_mux rmii1_pin_mux[] = {
    	{OFFSET(mii1_txen), MODE(1)},			/* RMII1_TXEN */
    	{OFFSET(mii1_txd1), MODE(1)},			/* RMII1_TD1 */
    	{OFFSET(mii1_txd0), MODE(1)},			/* RMII1_TD0 */
    	{OFFSET(mii1_rxd1), MODE(1) | RXACTIVE},	/* RMII1_RD1 */
    	{OFFSET(mii1_rxd0), MODE(1) | RXACTIVE},	/* RMII1_RD0 */
    	{OFFSET(mii1_rxdv), MODE(1) | RXACTIVE},	/* RMII1_RXDV */
    	{OFFSET(mii1_crs), MODE(1) | RXACTIVE},		/* RMII1_CRS_DV */
    	{OFFSET(mii1_rxerr), MODE(1) | RXACTIVE},	/* RMII1_RXERR */
    	{OFFSET(rmii1_refclk), MODE(0) | RXACTIVE},	/* RMII1_refclk */
    	{-1},
    static struct module_pin_mux rgmii1_pin_mux[] = {
    	{OFFSET(mii1_txen), MODE(2)},			/* RGMII1_TCTL */
    	{OFFSET(mii1_rxdv), MODE(2) | RXACTIVE},	/* RGMII1_RCTL */
    	{OFFSET(mii1_txd3), MODE(2)},			/* RGMII1_TD3 */
    	{OFFSET(mii1_txd2), MODE(2)},			/* RGMII1_TD2 */
    	{OFFSET(mii1_txd1), MODE(2)},			/* RGMII1_TD1 */
    	{OFFSET(mii1_txd0), MODE(2)},			/* RGMII1_TD0 */
    	{OFFSET(mii1_txclk), MODE(2)},			/* RGMII1_TCLK */
    	{OFFSET(mii1_rxclk), MODE(2) | RXACTIVE},	/* RGMII1_RCLK */
    	{OFFSET(mii1_rxd3), MODE(2) | RXACTIVE},	/* RGMII1_RD3 */
    	{OFFSET(mii1_rxd2), MODE(2) | RXACTIVE},	/* RGMII1_RD2 */
    	{OFFSET(mii1_rxd1), MODE(2) | RXACTIVE},	/* RGMII1_RD1 */
    	{OFFSET(mii1_rxd0), MODE(2) | RXACTIVE},	/* RGMII1_RD0 */
    	{-1},
    static struct module_pin_mux mii1_pin_mux [] = {
            {OFFSET (mii1_crs), MODE (0) | RXACTIVE},
            {OFFSET (mii1_col), MODE (0) | RXACTIVE},
            {OFFSET (mii1_rxerr), MODE (0) | RXACTIVE},
            {OFFSET (mii1_txen), MODE (0)},
            {OFFSET (mii1_rxdv), MODE (0) | RXACTIVE},
            {OFFSET (mii1_txd3), MODE (0)},
            {OFFSET (mii1_txd2), MODE (0)},
            {OFFSET (mii1_txd1), MODE (0)},
            {OFFSET (mii1_txd0), MODE (0)},
            {OFFSET (mii1_txclk), MODE (0) | RXACTIVE},
            {OFFSET (mii1_rxclk), MODE (0) | RXACTIVE},
            {OFFSET (mii1_rxd3), MODE (0) | RXACTIVE},
            {OFFSET (mii1_rxd2), MODE (0) | RXACTIVE},
            {OFFSET (mii1_rxd1), MODE (0) | RXACTIVE},
            {OFFSET (mii1_rxd0), MODE (0) | RXACTIVE},
            {-1},
    static struct module_pin_mux mii2_pin_mux [] = {
    	{OFFSET (gpmc_be1n), MODE (1) | RXACTIVE},
    	{OFFSET (gpmc_csn3), MODE (1) | RXACTIVE},
    	{OFFSET (gpmc_wpn), MODE (1) | RXACTIVE},
    	{OFFSET (gpmc_a0), MODE (1)},
    	{OFFSET (gpmc_a1), MODE (1) | RXACTIVE},
    	{OFFSET (gpmc_a6), MODE (1) | RXACTIVE},
    	{OFFSET (gpmc_a7), MODE (1) | RXACTIVE},
    	{OFFSET (gpmc_a5), MODE (1)},
    	{OFFSET (gpmc_a4), MODE (1)},
    	{OFFSET (gpmc_a3), MODE (1)},
    	{OFFSET (gpmc_a2), MODE (1)},
    	{OFFSET (gpmc_a11), MODE (1) | RXACTIVE},
    	{OFFSET (gpmc_a10), MODE (1) | RXACTIVE},
    	{OFFSET (gpmc_a9), MODE (1) | RXACTIVE},
    	{OFFSET (gpmc_a8), MODE (1) | RXACTIVE},
    	{-1},
    static struct module_pin_mux mdio_pin_mux[] = {
    	{OFFSET(mdio_data), MODE(0) | RXACTIVE | PULLUP_EN},/* MDIO_DATA */
    	{OFFSET(mdio_clk), MODE(0) | PULLUP_EN},	/* MDIO_CLK */
    	{-1},
    static struct module_pin_mux uart0_pin_mux[] = {
    	{OFFSET(uart0_rxd), (MODE(0) | PULLUP_EN | RXACTIVE | SLEWCTRL)},
    	{OFFSET(uart0_txd), (MODE(0) | PULLUDDIS | PULLUP_EN | SLEWCTRL)},
    	{-1},
    static struct module_pin_mux mmc0_pin_mux[] = {
    	{OFFSET(mmc0_clk), (MODE(0) | PULLUDDIS | RXACTIVE)},  /* MMC0_CLK */
    	{OFFSET(mmc0_cmd), (MODE(0) | PULLUP_EN | RXACTIVE)},  /* MMC0_CMD */
    	{OFFSET(mmc0_dat0), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* MMC0_DAT0 */
    	{OFFSET(mmc0_dat1), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* MMC0_DAT1 */
    	{OFFSET(mmc0_dat2), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* MMC0_DAT2 */
    	{OFFSET(mmc0_dat3), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* MMC0_DAT3 */
    	{-1},
    static struct module_pin_mux mmc1_pin_mux[] = {
    	{OFFSET(gpmc_csn1), (MODE(2) | PULLUDDIS | RXACTIVE)},  /* MMC1_CLK */
    	{OFFSET(gpmc_csn2), (MODE(2) | PULLUP_EN | RXACTIVE)},  /* MMC1_CMD */
    	{OFFSET(gpmc_ad0), (MODE(1) | PULLUP_EN | RXACTIVE)}, /* MMC1_DAT0 */
    	{OFFSET(gpmc_ad1), (MODE(1) | PULLUP_EN | RXACTIVE)}, /* MMC1_DAT1 */
    	{OFFSET(gpmc_ad2), (MODE(1) | PULLUP_EN | RXACTIVE)}, /* MMC1_DAT2 */
    	{OFFSET(gpmc_ad3), (MODE(1) | PULLUP_EN | RXACTIVE)}, /* MMC1_DAT3 */
    	{OFFSET(gpmc_ad4), (MODE(1) | PULLUP_EN | RXACTIVE)}, /* MMC1_DAT4 */
    	{OFFSET(gpmc_ad5), (MODE(1) | PULLUP_EN | RXACTIVE)}, /* MMC1_DAT5 */
    	{OFFSET(gpmc_ad6), (MODE(1) | PULLUP_EN | RXACTIVE)}, /* MMC1_DAT6 */
    	{OFFSET(gpmc_ad7), (MODE(1) | PULLUP_EN | RXACTIVE)}, /* MMC1_DAT7 */
    	{-1},
    static struct module_pin_mux i2c0_pin_mux[] = {
    	{OFFSET(i2c0_sda), (MODE(0) | PULLUP_EN | RXACTIVE | SLEWCTRL)},
    	{OFFSET(i2c0_scl), (MODE(0) | PULLUP_EN | RXACTIVE | SLEWCTRL)},
    	{-1},
    void enable_uart0_pin_mux(void)
    	configure_module_pin_mux(uart0_pin_mux);
    void enable_board_pin_mux(void)
    	configure_module_pin_mux(mmc0_pin_mux);
    	configure_module_pin_mux(i2c0_pin_mux);
    	configure_module_pin_mux(mdio_pin_mux);
    	configure_module_pin_mux(mii1_pin_mux);
    	configure_module_pin_mux(mii2_pin_mux);
    	configure_module_pin_mux(mmc1_pin_mux);
    	if (board_is_evm()) {
    		configure_module_pin_mux(gpio5_7_pin_mux);
    		configure_module_pin_mux(rgmii1_pin_mux);
    #if defined(CONFIG_NAND)
    		configure_module_pin_mux(nand_pin_mux);
    #endif
    	} else if (board_is_sk() || board_is_idk()) {
    		printf("Error: NAND flash not present on this board\n");
    #endif
    		configure_module_pin_mux(qspi_pin_mux);
    	} else if (board_is_eposevm()) {
    		configure_module_pin_mux(rmii1_pin_mux);
    #else
    #endif
    void enable_i2c0_pin_mux(void)
    Please can tell me the problem or any idea to solve it?
    I`ll try to refer to the document as you say.
    Thank you.
  • Hello Han,
    To confirm: You have EMMC connected on your board, but you are not able to see it from Linux?
    Did you also add the EMMC to the Linux device tree file?
    Nick
  • To confirm: You have EMMC connected on your board, but you are not able to see it from Linux?
    --> Exactly. I hope to see it.
    --> See below
    &am43xx_pinmux {
    &mmc2 {
    	status = "okay";
    	vmmc-supply = <&dcdc4>;
    	bus-width = <8>;
    	ti,non-removable;
  • Hello Han,
    Apologies for the delayed response. Let us know if you need additional assistance with this.
    Nick
  • Yes. Please guide me on using eMMC .
