SK-AM64: Bootable Linux SD-Card image
Part Number: SK-AM64
When bootable (.win) image of Linux-RT for SK-AM64 board (preconfigured by startup procedure - power, PLL, DDR, memory mapping) is planning to release by time roadmap? I tried standard version from SDK and it doesn't boot properly.
Alexey
  • Hello Alexey,
    We offer both Linux and RT Linux SDKs for AM64x here:
    https://www.ti.com/tool/PROCESSOR-SDK-AM64X
    What version of the SDK are you using? (7.2 or 7.3?) Please post the errors that you see when "it doesn't boot properly".
    Nick
  • Hello Nick,
    After reset this goes to UART (boot mode SD/MMC)
    Images taken from Processor SDK Linux 07_03_00_02: tisdk-base-image-am64xx-evm.wic and tisdk-default-image-am64xx-evm.wic
    And nothing happens.
    Another strange behavior is successful booting from onboard Flash using SPI-boot instead of OSPI.
    Alexey
  • Hello Alexey,
    I am not sure what you are showing with your screenshot. It would probably be more useful for us if you copied the terminal output into a text file and attached it to your post.
    Have you verified that the boot mode switches are set properly as per the EVM User Guide?
    Nick
  • UART output after reset:
    U-Boot SPL 2020.01-g2781231a33 (Apr 12 2021 - 17:25:33 +0000)
    SYSFW ABI: 3.1 (firmware rev 0x0015 '21.1.1--v2021.01a (Terrific Lla')
    Boot setup B15-B0: 00011010 01000011
    Alexey
  • Hello Alexey,
    I have reassigned this to our Linux boot owner. They are on vacation this week, please ping the thread if you have not received a reply by next week.
    Nick
  • Hi Alexey.
    There'll be a up-coming SDK release (07.03.01.006), currently scheduled to be available next week.
    Please stay tuned for the newer SDK for running on AM64x SK board.
    -Hong
  • Hong,
    I tried this new release.
    The resulted boot process:
    U-Boot SPL 2020.01-ge995ed0ec1 (May 28 2021 - 16:20:13 +0000)
    EEPROM not available at 80, trying to read at 81
    SPL initial stack usage: 13396 bytes
    Trying to boot from MMC2
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.4(release):2021.00.003-dirty
    NOTICE:  BL31: Built : 14:41:43, May 28 2021
    U-Boot SPL 2020.01-ge995ed0ec1 (May 28 2021 - 14:48:57 +0000)
    Error reading cluster
    ** Unable to read file u-boot.img **
    SPL: failed to boot from all boot devices
    ### ERROR ### Please RESET the board ###
    The acctual board doesn't have MMC2 peritheral interface, - only MMC0 (WiFi) and MMC1 (SD-card).
    Alexey
  • Nick,
    At least, now I have source code for a bootloader. Probably I need to spend time to study it, make some modifications and recompile it myself.
    I hope EEPROM data is totally valid.
    Alexey
  • Hi Alexey,
    I verified the new SDK release (07.03.01.006) downloadable from
    www.ti.com/.../PROCESSOR-SDK-LINUX-AM64X
    I created the SD card using the WIC image
    software-dl.ti.com/.../tisdk-default-image-am64xx-evm.wic.xz
    by following the SD card creation instruction
    software-dl.ti.com/.../Create_SD_Card.html
    I tested SD booting on AM64x GP EVM (I currently don't have access to AM64x SK board), and uploaded the full boot log for your reference.
    From your log,
    After you created SD card, have you checked the files under the boot partition of the SD card?
    Specifically is "u-boot.img" accessible?
    -Hong
    U-Boot 2020.01-ge995ed0ec1 (May 28 2021 - 14:48:57 +0000)
    SoC:   AM64X SR1.0
    Model: Texas Instruments AM642 EVM
    Board: AM64-GPEVM rev E2
    DRAM:  2 GiB
    not found for dev mux
    MMC:   sdhci@fa10000: 0, sdhci@fa00000: 1
    Loading Environment from FAT... In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Net:
    Warning: ethernet@8000000 using MAC address from ROM
    eth0: ethernet@8000000
    Hit any key to stop autoboot:  2  1  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    574 bytes read in 3 ms (186.5 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    16799752 bytes read in 666 ms (24.1 MiB/s)
    35357 bytes read in 7 ms (4.8 MiB/s)
       Loading Device Tree to 000000008fff4000, end 000000008ffffa1c ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 5.4.106-g023faefa70 (oe-user@oe-host) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 SMP PREEMPT Fri May 28 14:38:23 UTC 2021
    [    0.000000] Machine model: Texas Instruments AM642 EVM
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.0
    [    0.000000] percpu: Embedded 2 pages/cpu s48472 r8192 d74408 u131072
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] Built 1 zonelists, mobility grouping off.  Total pages: 3296
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=fc40000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern) root=PARTUUID=3c261301-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 32768 (order: 2, 262144 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 16384 (order: 1, 131072 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0xbbff0000-0xbfff0000] (64MB)
    [    0.000000] Memory: 1388096K/212992K available (9662K kernel code, 854K rwdata, 3840K rodata, 1664K init, 681K bss, 18446744073707852224K reserved, 524288K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000] 	Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: no VLPI support, no direct LPI support
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001840000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @df000000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000000df870000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000df880000
    [    0.000000] random: get_random_bytes called from start_kernel+0x2b8/0x42c with crng_init=0
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000005] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008436] Console: colour dummy device 80x25
    [    0.013024] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023690] pid_max: default: 32768 minimum: 301
    [    0.028499] LSM: Security Framework initializing
    [    0.033300] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.040892] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.051138] ASID allocator initialised with 32768 entries
    [    0.056818] rcu: Hierarchical SRCU implementation.
    [    0.061970] Platform MSI: msi-controller@1820000 domain created
    [    0.068223] PCI/MSI: /bus@f4000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.077756] smp: Bringing up secondary CPUs ...
    [    0.083117] Detected VIPT I-cache on CPU1
    [    0.083151] GICv3: CPU1: found redistributor 1 region 0:0x0000000001860000
    [    0.083164] GICv3: CPU1: using allocated LPI pending table @0x00000000df890000
    [    0.083216] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.083338] smp: Brought up 1 node, 2 CPUs
    [    0.112714] SMP: Total of 2 processors activated.
    [    0.117523] CPU features: detected: 32-bit EL0 Support
    [    0.122790] CPU features: detected: CRC32 instructions
    [    0.134056] CPU: All CPU(s) started at EL2
    [    0.138258] alternatives: patching kernel code
    [    0.144135] devtmpfs: initialized
    [    0.153114] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.163097] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
    [    0.172475] pinctrl core: initialized pinctrl subsystem
    [    0.178787] NET: Registered protocol family 16
    [    0.190275] DMA: preallocated 256 KiB pool for atomic allocations
    [    0.197366] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.217779] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    [    0.224660] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    [    0.231428] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.239876] cryptd: max_cpu_qlen set to 1000
    [    0.248001] vsys_5v0: supplied by evm_12v0
    [    0.252458] vsys_3v3: supplied by evm_12v0
    [    0.257483] iommu: Default domain type: Translated
    [    0.263052] SCSI subsystem initialized
    [    0.267435] mc: Linux media interface: v0.10
    [    0.271828] videodev: Linux video capture interface: v2.00
    [    0.277456] pps_core: LinuxPPS API ver. 1 registered
    [    0.282528] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.291872] PTP clock support registered
    [    0.295899] EDAC MC: Ver: 3.0.0
    [    0.299801] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fc9100
    [    0.306689] omap-mailbox 29040000.mailbox: omap mailbox rev 0x66fc9100
    [    0.313483] omap-mailbox 29060000.mailbox: omap mailbox rev 0x66fc9100
    [    0.320775] FPGA manager framework
    [    0.324383] Advanced Linux Sound Architecture Driver Initialized.
    [    0.331613] clocksource: Switched to clocksource arch_sys_counter
    [    0.338069] VFS: Disk quotas dquot_6.6.0
    [    0.342178] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
    [    0.354980] thermal_sys: Registered thermal governor 'step_wise'
    [    0.354985] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.361536] NET: Registered protocol family 2
    [    0.373301] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
    [    0.382146] TCP established hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.390126] TCP bind hash table entries: 8192 (order: 1, 131072 bytes, linear)
    [    0.397618] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.404249] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.411187] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.418722] NET: Registered protocol family 1
    [    0.423819] RPC: Registered named UNIX socket transport module.
    [    0.429885] RPC: Registered udp transport module.
    [    0.434697] RPC: Registered tcp transport module.
    [    0.439503] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.446098] PCI: CLS 0 bytes, default 64
    [    0.450819] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
    [    0.462941] Initialise system trusted keyrings
    [    0.467764] workingset: timestamp_bits=46 max_order=15 bucket_order=0
    [    0.480153] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.486776] NFS: Registering the id_resolver key type
    [    0.491990] Key type id_resolver registered
    [    0.496266] Key type id_legacy registered
    [    0.500375] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.507437] 9p: Installing v9fs 9p2000 file system support
    [    0.529001] Key type asymmetric registered
    [    0.533203] Asymmetric key parser 'x509' registered
    [    0.538241] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.545801] io scheduler mq-deadline registered
    [    0.550430] io scheduler kyber registered
    [    0.556583] pinctrl-single f4000.pinctrl: 185 pins, size 740
    [    0.563471] pinctrl-single a40000.timesync-router: 512 pins, size 2048
    [    0.577233] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.597998] brd: module loaded
    [    0.608917] loop: module loaded
    [    0.615227] libphy: Fixed MDIO Bus: probed
    [    0.620001] tun: Universal TUN/TAP device driver, 1.6
    [    0.625761] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
    [    0.633776] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.639874] sky2: driver version 1.30
    [    0.644631] VFIO - User Level meta-driver version: 0.3
    [    0.650725] i2c /dev entries driver
    [    0.655093] sdhci: Secure Digital Host Controller Interface driver
    [    0.661420] sdhci: Copyright(c) Pierre Ossman
    [    0.666310] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.672799] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.679059] ti-sci bus@f4000:dmsc: invalid resource
    [    0.685197] optee: probing for conduit method from DT.
    [    0.690515] optee: revision 3.11 (c4def2a8)
    [    0.691293] optee: initialized driver
    [    0.701159] NET: Registered protocol family 17
    [    0.705961] 9pnet: Installing 9P2000 support
    [    0.710402] Key type dns_resolver registered
    [    0.715180] registered taskstats version 1
    [    0.719378] Loading compiled-in X.509 certificates
    [    0.732826] ti-sci bus@f4000:dmsc: invalid resource
    [    0.738013] ti-sci bus@f4000:dmsc: ABI: 3.1 (firmware rev 0x0015 '21.1.1--v2021.01a (Terrific Lla')
    [    0.762257] omap_i2c 20000000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.769075] pca953x 1-0022: 1-0022 supply vcc not found, using dummy regulator
    [    0.776557] pca953x 1-0022: using AI
    [    0.804492] omap_i2c 20010000.i2c: bus 1 rev0.12 at 400 kHz
    [    0.811074] omap_i2c 20020000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.817636] omap_i2c 20030000.i2c: bus 3 rev0.12 at 100 kHz
    [    0.823612] ti-sci-intr bus@f4000:interrupt-controller0: Interrupt Router 3 domain created
    [    0.832283] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain -1 created
    [    1.857195] j721e-pcie f102000.pcie: host bridge /bus@f4000/pcie@f102000 ranges:
    [    1.864877] j721e-pcie f102000.pcie:    IO 0x68001000..0x68010fff -> 0x68001000
    [    1.872367] j721e-pcie f102000.pcie:   MEM 0x68011000..0x6fffffff -> 0x68011000
    [    1.880039] j721e-pcie f102000.pcie: PCI host bridge to bus 0000:00
    [    1.886453] pci_bus 0000:00: root bus resource [bus 00-0f]
    [    1.892063] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x68001000-0x68010fff])
    [    1.901755] pci_bus 0000:00: root bus resource [mem 0x68011000-0x6fffffff]
    [    1.908813] pci 0000:00:00.0: [104c:b010] type 01 class 0x060400
    [    1.914972] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    1.924844] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    1.934740] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits
    [    1.944699] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    1.954670] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
    [    1.964635] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
    [    1.974631] pci 0000:00:00.0: supports D1
    [    1.978730] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    1.984608] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
    [    1.996289] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.004479] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.014443] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.024405] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    2.035839] pci_bus 0000:01: busn_res: [bus 01-0f] end is updated to 01
    [    2.042620] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    2.048192] pcieport 0000:00:00.0: PME: Signaling with IRQ 29
    [    2.054453] pcieport 0000:00:00.0: AER: enabled with IRQ 29
    [    2.060744] ti-bcdma 485c0100.dma-controller: Number of rings: 68
    [    2.068021] ti-bcdma 485c0100.dma-controller: Channels: 24 (bchan: 12, tchan: 6, rchan: 6)
    [    2.078206] ti-pktdma 485c0000.dma-controller: Number of rings: 288
    [    2.089803] ti-pktdma 485c0000.dma-controller: Channels: 32 (tchan: 21, rchan: 11)
    [    2.100137] printk: console [ttyS2] disabled
    [    2.104561] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 8, base_baud = 3000000) is a 8250
    [    2.113224] printk: console [ttyS2] enabled
    [    2.121665] printk: bootconsole [ns16550a0] disabled
    [    2.134964] random: fast init done
    [    2.143202] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    2.148197] 7 cmdlinepart partitions found on MTD device fc40000.spi.0
    [    2.154719] Creating 7 MTD partitions on "fc40000.spi.0":
    [    2.160120] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    2.166878] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    2.173448] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    2.180042] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    2.186379] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [    2.193312] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    2.199881] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    2.251677] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    2.259272] libphy: 8000f00.mdio: probed
    [    2.264643] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    2.272781] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA00903, cpsw version 0x6BA80903 Ports: 3 quirks:00000002
    [    2.285937] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 16
    [    2.292465] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.4
    [    2.299603] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    2.306110] pps pps0: new PPS source ptp0
    [    2.310501] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
    [    2.322559] am65-cpts 39000000.cpts: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
    [    2.331816] mmc0: CQHCI version 5.10
    [    2.376785] mmc0: SDHCI controller on fa10000.sdhci [fa10000.sdhci] using ADMA 64-bit
    [    2.387066] gpio-mux mux-controller: 2-way mux-controller registered
    [    2.397333] davinci_gpio 601000.gpio: IRQ index 2 not found
    [    2.402973] davinci_gpio 601000.gpio: IRQ not populated, err = -6
    [    2.410413] vdd_mmc1: supplied by vsys_3v3
    [    2.415193] libphy: mdio_mux: probed
    [    2.426100] mmc1: CQHCI version 5.10
    [    2.476195] mmc1: SDHCI controller on fa00000.sdhci [fa00000.sdhci] using ADMA 64-bit
    [    2.484275] debugfs: Directory 'pd:114' with parent 'pm_genpd' already present!
    [    2.493559] hctosys: unable to open rtc device (rtc0)
    [    2.501299] ALSA device list:
    [    2.504314]   No soundcards found.
    [    2.509071] Waiting for root device PARTUUID=3c261301-02...
    [    2.518198] mmc0: Command Queue Engine enabled
    [    2.522666] mmc0: new HS400 MMC card at address 0001
    [    2.528370] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    2.533161] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
    [    2.539311] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
    [    2.545471] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (240:0)
    [    2.590050] mmc1: new ultra high speed SDR104 SDHC card at address 0007
    [    2.597442] mmcblk1: mmc1:0007 SD08G 7.42 GiB
    [    2.605322]  mmcblk1: p1 p2
    [    3.267939] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    3.276119] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    3.286391] devtmpfs: mounted
    [    3.290261] Freeing unused kernel memory: 1664K
    [    3.294812] Run /sbin/init as init process
    [    3.454204] systemd[1]: System time before build time, advancing clock.
    [    3.517173] NET: Registered protocol family 10
    [    3.522764] Segment Routing with IPv6
    [    3.552851] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    3.574998] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2020.09!
    [    3.632859] systemd[1]: Set hostname to <am64xx-evm>.
    [    3.642645] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.649373] systemd[1]: Initializing machine ID from random generator.
    [    4.336714] systemd[1]: /lib/systemd/system/startwlan.service:7: Unknown key name 'After' in section 'Service', ignoring.
    [    4.534265] random: systemd: uninitialized urandom read (16 bytes read)
    [    4.541257] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    4.553616] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    4.565398] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    4.583895] random: systemd: uninitialized urandom read (16 bytes read)
    [    4.592009] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    4.613200] systemd[1]: Created slice system-syslog\x2dng.slice.
    [  OK  ] Created slice system-syslog\x2dng.slice.
    [    4.633376] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    4.651889] urandom_read: 2 callbacks suppressed
    [    4.651899] random: systemd: uninitialized urandom read (16 bytes read)
    [    4.663493] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password �ts to Console Directory Watch.
    [    4.687831] random: systemd: uninitialized urandom read (16 bytes read)
    [    4.694843] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R�uests to Wall Directory Watch.
    [    4.720007] random: systemd: uninitialized urandom read (16 bytes read)
    [    4.726762] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    4.743898] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    4.763878] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    4.779906] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    4.796892] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    4.815922] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    4.842680] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    4.860250] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    4.889716] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    4.898615] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    4.916529] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    4.932762] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    4.952555] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    4.972308] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    4.993563] systemd[1]: Mounting Huge Pages File System...
    [    5.021525] systemd[1]: Mounting POSIX Message Queue File System...
    [    5.045411] systemd[1]: Mounting Kernel Debug File System...
    [    5.069917] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    5.094135] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st�odes for the current kernel...
    [    5.127438] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [    5.154839] systemd[1]: Starting RPC Bind...
    [    5.172210] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    5.193742] systemd[1]: Starting Journal Service...
    [    5.233895] systemd[1]: Starting Load Kernel Modules...
    [    5.265190] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    5.306844] cryptodev: loading out-of-tree module taints kernel.
    [    5.330774] systemd[1]: Starting udev Coldplug all Devices...
    [    5.333400] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [    5.348017] cryptodev: driver 1.10 loaded.
    [    5.390721] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    5.422773] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Started Create list of sta� nodes for the current kernel.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
    [    5.650402] systemd-journald[153]: Received client request to flush runtime journal.
             Starting Apply Kernel Variables...
             Starting Create System Users...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create System Users.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Kernel Device Manager...
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Rebuild Dynamic Linker Cache...
             Starting Create Volatile Files and Directories...
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Run pending postinsts...
             Starting Rebuild Journal Catalog...
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Rebuild Journal Catalog.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target System Time Synchronized.
    [  OK  ] Started Rebuild Dynamic Linker Cache.
             Starting Update is Completed...
    [  OK  ] Started Update is Completed.
    [    8.483713] random: crng init done
    [    8.487139] random: 2 urandom warning(s) missed due to ratelimiting
    [    9.815535] 93xx46 spi1.0: 16-bit eeprom
    [  OK  ] Started Load/Save Random Seed.
    [   10.080534] platform 78000000.r5f: configured R5F for remoteproc mode
    [   10.227886] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [   10.375840] remoteproc remoteproc0: 78000000.r5f is available
    [   10.457545] platform 78200000.r5f: configured R5F for remoteproc mode
    [   10.519736] platform 78200000.r5f: assigned reserved memory node r5f-dma-memory@a1000000
    [   10.567864] remoteproc remoteproc1: 78200000.r5f is available
    [   10.607931] platform 78400000.r5f: configured R5F for remoteproc mode
    [   10.635704] platform 78400000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [   10.651865] remoteproc remoteproc2: 78400000.r5f is available
    [   10.679816] platform 78600000.r5f: configured R5F for remoteproc mode
    [   10.691870] platform 78600000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [   10.707819] remoteproc remoteproc3: 78600000.r5f is available
    [   11.166547] remoteproc remoteproc2: powering up 78400000.r5f
    [   11.166551] remoteproc remoteproc0: powering up 78000000.r5f
    [   11.166570] remoteproc remoteproc0: Booting fw image am64-main-r5f0_0-fw, size 86732
    [   11.172698] remoteproc remoteproc1: powering up 78200000.r5f
    [   11.192021] remoteproc remoteproc3: powering up 78600000.r5f
    [   11.197880] remoteproc remoteproc2: Booting fw image am64-main-r5f1_0-fw, size 90696
    [   11.198307] platform 78000000.r5f: booting R5F core using boot addr = 0x0
    [   11.207629] remoteproc remoteproc3: Booting fw image am64-main-r5f1_1-fw, size 89596
    [   11.228436] platform 78400000.r5f: booting R5F core using boot addr = 0x0
    [   11.236715]  remoteproc0#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
    [   11.239738] remoteproc remoteproc1: Booting fw image am64-main-r5f0_1-fw, size 117792
    [   11.256465] platform 78600000.r5f: booting R5F core using boot addr = 0x0
    [   11.256711] virtio_rpmsg_bus virtio0: rpmsg host is online
    [   11.263559]  remoteproc2#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
    [   11.279746]  remoteproc3#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
    [   11.287487]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [   11.292246] platform 78200000.r5f: booting R5F core using boot addr = 0x0
    [   11.302351] virtio_rpmsg_bus virtio1: rpmsg host is online
    [   11.307678] remoteproc remoteproc0: remote processor 78000000.r5f is now up
    [   11.311355] virtio_rpmsg_bus virtio2: rpmsg host is online
    [   11.323743]  remoteproc2#vdev0buffer: registered virtio1 (type 7)
    [   11.331729]  remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@a1000000
    [   11.340286]  remoteproc3#vdev0buffer: registered virtio2 (type 7)
    [   11.351635] remoteproc remoteproc2: remote processor 78400000.r5f is now up
    [   11.359528] virtio_rpmsg_bus virtio3: rpmsg host is online
    [   11.365118] remoteproc remoteproc3: remote processor 78600000.r5f is now up
    [   11.375795]  remoteproc1#vdev0buffer: registered virtio3 (type 7)
    [   11.382016] remoteproc remoteproc1: remote processor 78200000.r5f is now up
    [   11.389103] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [   11.403891] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [   11.411215] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [   11.427878] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
    [  OK  ] Started Run pending postinsts.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Ethernet Bridge Filtering Tables...
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Reboot and dump vmcore via kexec...
             Starting Matrix GUI...
             Starting startwlan...
             Starting System Logger Daemon "default" instance...
             Starting Login Service...
             Starting telnetd.service...
    [  OK  ] Started Ethernet Bridge Filtering Tables.
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [   12.789747] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Started Matrix GUI.
    [  OK  ] Started telnetd.service.
    [  OK  ] Started startwlan.
    [   12.956838] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [  OK  ] Started System Logger Daemon "default" instance.
    [  OK  ] Reached target Network (Pre).
             Starting syslog.service...
             Starting Network Service...
    [  OK  ] Started Login Service.
    [   14.143322] startwlan.sh[477]: adding wlan1 interface
    [  OK  ] Started syslog.service.
    [   14.174851] startwlan.sh[485]: command failed: No such file or directory (-2)
    [   14.248732] startwlan.sh[487]: Configuration file: /usr/share/wl18xx/hostapd.conf
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
    [   14.361879] startwlan.sh[487]: Could not read interface wlan1 flags: No such device
             Starting Network Name Resolution...
    [   14.472910] TI DP83869 0.1:03: attached PHY driver [TI DP83869] (mii_bus:phy_addr=0.1:03, irq=POLL)
    [   14.518527] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down
    [   14.451460] startwlan.sh[487]: nl80211: Driver does not support authentication/association or connect commands
    [   14.452105] startwlan.sh[487]: nl80211: deinit ifname=wlan1 disabled_11b_rates=0
    [   14.571351] TI DP83867 8000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=8000f00.mdio:00, irq=POLL)
    [   14.509672] startwlan.sh[487]: Could not read interface wlan1 flags: No such device
    [   14.601853] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
    [   14.531487] startwlan.sh[487]: nl80211 driver initialization failed.
    [   14.531963] startwlan.sh[487]: wlan1: interface state UNINITIALIZED->DISABLED
    [   14.532344] startwlan.sh[487]: wlan1: AP-DISABLED
    [   14.532527] startwlan.sh[487]: wlan1: CTRL-EVENT-TERMINATING
    [   14.532674] startwlan.sh[487]: hostapd_free_hapd_data: Interface wlan1 wasn't started
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network Ma�ent Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Started Vsftpd ftp daemon.
    [  OK  ] Started Enable and configure wl18xx bluetooth stack.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [   15.813928] startwlan.sh[555]: ifconfig: SIOCSIFADDR: No such device
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Started Simple Network Man�ement Protocol (SNMP) Daemon..
    [  OK  ] Listening on Load/Save RF �itch Status /dev/rfkill Watch.
    [   18.110531] cdns-usb3 f400000.usb: DRD version v1 (ID: 0004024e, rev: 00000200)
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    NOTICE: This file system contains the following GPLv3 packages:
    	autoconf
    	bash
    	bc
    	binutils
    	cifs-utils
    	coreutils-stdbuf
    	coreutils
    	cpio
    	cpp-symlinks
    	cpp
    	dosfstools
    	elfutils
    	g++-symlinks
    	g++
    	gawk
    	gcc-symlinks
    	gcc
    	gdb
    	gdbserver
    	gettext
    	gstreamer1.0-libav
    	gzip
    	less
    	libasm1
    	libbfd
    	libdw1
    	libelf1
    	libgdbm-compat4
    	libgdbm6
    	libgettextlib
    	libgettextsrc
    	libgmp10
    	libidn2-0
    	libmpc3
    	libmpfr6
    	libreadline8
    	libunistring2
    	m4
    	make
    	nettle
    	parted
    	tar
    	which
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Found device /dev/mmcblk1p1.
    [  OK  ] Started Print notice about GPLv3 packages.
             Starting File System Check on /dev/mmcblk1p1...
    [  OK  ] Started File System Check on /dev/mmcblk1p1.
             Mounting /run/media/mmcblk1p1...
    [  OK  ] Mounted /run/media/mmcblk1p1.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org am64xx-evm ttyS2
    Arago 2020.09 am64xx-evm ttyS2
    am64xx-evm login: root
    root@am64xx-evm:~#
  • Hi Hong,
    You are right, this was a hardware incompatability problem of SD-Cards on different modes.
    I tried the third one and that is what I get:
    U-Boot SPL 2020.01-ge995ed0ec1 (May 28 2021 - 16:17:54 +0000)
    NOTICE:  BL31: Built : 14:41:26, May 28 2021
    U-Boot SPL 2020.01-ge995ed0ec1 (May 28 2021 - 14:47:23 +0000)
    U-Boot 2020.01-ge995ed0ec1 (May 28 2021 - 14:47:23 +0000)
    SoC:   AM64X SR1.0
    Model: Texas Instruments AM642 SK
    Board: AM64-SKEVM rev E2
    DRAM:  2 GiB
    MMC:   sdhci@fa00000: 1
    Out:   serial@2800000
    Err:   serial@2800000
    Net:
    Hit any key to stop autoboot:  0
     ** fs_devread read error - block
    ** No partition table - mmc 1 **
    ERROR: Did not find a cmdline Flattened Device Tree
    Starting kernel ...
    unable to select a mode
    device_remove: Device 'sdhci@fa00000.blk' failed to remove, but children are gone
    "Synchronous Abort" handler, esr 0x02000000
    elr: 0000000003621000 lr : 00000000808024e8 (reloc)
    elr: 0000000082d40000 lr : 00000000fff214e8
    x0 : 0000000000000000 x1 : 0000000000000000
    x2 : 0000000000000000 x3 : 0000000000000000
    x4 : 0000000082080000 x5 : 0000000000000001
    x6 : 0000000000000008 x7 : 0000000000000000
    x8 : 00000000fdef78b8 x9 : 0000000000000002
    x10: 000000000a200023 x11: 0000000000000002
    x12: 0000000000000002 x13: 0000000000000f14
    x14: 0000000000000000 x15: 00000000fff20a1c
    x16: 00000000fff59528 x17: 0000000000000000
    x18: 00000000fdefedd8 x19: 00000000fffe05d0
    x20: 0000000000000000 x21: 0000000000000400
    x22: 0000000000000003 x23: 00000000fdf0bbd8
    x24: 00000000fdf0bbd8 x25: 00000000fffc9c18
    x26: 0000000000000000 x27: 00000000fff21510
    x28: 00000000fdf0bc00 x29: 00000000fdef7020
    Code: 00000000 00000000 00000000 00000000 (00000000)
    Resetting CPU ...
    resetting ...
    Alexey
  • Hong,
    The forth SD card (with latest technologies enabled, V10 certified) actually made this system to work.
     _____                    _____           _         _
                  |___|                    |___|
    am64xx-evm login:
    Thanks and best wishes,
    Alexey
