PROCESSOR-SDK-AM64X: oe-layersetup.sh
Part Number: PROCESSOR-SDK-AM64X
Good Day. I have a customer who is working with PROCESSOR-SDK-AM64X. Please see below for his query. Thank you very much.
I want to use yocto in the processor_sdk_linux_am64x_07_03_01_006-linux-x64-installer.run sdk. However after the installation , i didn't found the script "oe-layersetup.sh
www.ti.com/.../PROCESSOR-SDK-LINUX-AM64X
However I found it here : git clone git://arago-project.org/git/projects/oe-layersetup.git tisdk
This it is not included in the installation (I founded in the google search).
However, when I install processor_sdk_linux_am64x_07_03_01_006-linux-x64-installer.run , there is no a script named "oe-layersetup.sh
I want to use it for yocto to build different images
Ray Vincent
  • Hi Ray,
    Script oe-layersetup.sh should be obtained from arago-project.org. Please refer to documentation on building the SDK.
    Jianzhong
  • Hi Jianzhong,
    Good Day. I already inform our customer to your suggestion. Please see below his response to your suggestion. Thank you very much.
    Hi , I run all the commands described in section 3.1.4.2.2 ( I have used the configs coresdk/coresdk-07.03.00.005-config.txt and MACHINE=am64x-evm ), however I had the following errors :
    ERROR: Unable to start bitbake server (None)
    ERROR: Server log for this session (/home/bouchebaba/tisdk/build/bitbake-cookerdaemon.log):
    --- Starting bitbake server pid 515 at 2021-06-01 20:04:22.628876 ---
    ERROR: Failed to obtain external Arm toolchain version: Execution of '${DEF_TOOLCHAIN_PATH}/bin/INVALID-linux-gcc -v' failed: command not found
    Ray Vincent
  • Hi Ray,
    This problem was likely caused by ARM toolchain. Please use newer version as documented in latest SDK release: https://software-dl.ti.com/processor-sdk-linux/esd/AM64X/07_03_01_006/exports/docs/linux/Overview_Building_the_SDK.html. Please note that the ARM tool chain versions are wrong in section 3.1.4.2.2 (Build Steps).
    Below is what I validated on my Ubuntu 18.04 PC:
    wget https://developer.arm.com/-/media/Files/downloads/gnu-a/9.2-2019.12/binrel/gcc-arm-9.2-2019.12-x86_64-arm-none-linux-gnueabihf.tar.xz
    tar -Jxvf gcc-arm-9.2-2019.12-x86_64-arm-none-linux-gnueabihf.tar.xz -C $HOME
    wget https://developer.arm.com/-/media/Files/downloads/gnu-a/9.2-2019.12/binrel/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu.tar.xz
    tar -Jxvf gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu.tar.xz -C $HOME
    cd tisdk
    ./oe-layertool-setup.sh -f configs/coresdk/coresdk-07.03.00.005-config.txt
    export TOOLCHAIN_PATH_ARMV7=$HOME/gcc-arm-9.2-2019.12-x86_64-arm-none-linux-gnueabihf
    export TOOLCHAIN_PATH_ARMV8=$HOME/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu
    cd build
    . conf/setenv
    MACHINE=am64xx-evm bitbake -k tisdk-base-image
    Jianzhong
  • Hi Jianzhong:
     I followed your solution, and it gives me this error:
  • Gives error because I change it to package_deb
  • Hi Zehua,
    Can you please share the commands that you used to build?
    Jianzhong
  • Hi Jianzhong:
    I was using the exact code you shared. And environment is ubuntu18.04
    cd tisdk
    cd build
    . conf/setenv
    After built, I found "arago-tmp-external-arm-glibc/deploy/images/am64xx-evm/tisdk-base-image-am64xx-evm-20210618134424.rootfs.wic.xz", is this the right file since tisdk-base-image-am64xx-evm.wic.xz point to tisdk-base-image-am64xx-evm-20210618134424.rootfs.wic.xz?
  • Yes, it is the correct WIC file.
  • That is great! But with this image, the console show error message:
  • Are you booting from SD card? If that's the case, how did you create the SD card?
  • I follow this AM64X SDK Docs
    # I copy the image to a new folder: myfilesystem
    cd <PSDK_PATH>/myfilesystem
    unxz tisdk-default-image-am64xx-evm.wic.xz
    lsblk
    # NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
    # sdb      8:32   1    15G  0 disk
    # ├─sdb1   8:33   1 131.8M  0 part /media/localUser/boot
    # └─sdb2   8:34   1 765.9M  0 part /media/localUser/root
    sudo umount /media/localUser/boot
    sudo umount /media/localUser/root
    sudo dd bs=4M if=./tisdk-default-image-am64xx-evm.wic of=/dev/sdc status=progress && sync
  • I used balenaEtcher to create the SD card and it worked fine. It's very simple and I'd recommend you to try it. You can download it from here: https://www.balena.io/etcher/.
    I tried "unxz" but didn't succeed:
    $ unxz tisdk-base-image-am64xx-evm-20210601203520.rootfs.wic.xz
    unxz: tisdk-base-image-am64xx-evm-20210601203520.rootfs.wic.xz: Input file has more than one hard link, skipping
    The "unxz" command works fine with the pre-built images in the SDK release. I'm not sure why it doesn't work for the image I built on my Ubuntu. I'll try to investigate this. Meanwhile, please try to use balenaEtcher to create your SD card.
    Jianzhong
  • Hi Jianzhong:
    I tried balenaEtcher, but it still gives the same error.  Do you have any idea what the error means?
    I used balenEthcher to create SD card with tisdk-default, it is working. But with the image I built, it doesn't. I assume something was wrong when I create the image. The thing is when I create it, there was no errors, and it takes a while to build the image, which seems fine. And the operation is above.
    I sincerely appreciate your help!
  • That wasn't an error. Did the boot get stuck there? Below is my boot log:
    U-Boot SPL 2020.01-g2781231a33 (Jun 01 2021 - 20:50:28 +0000)
    SYSFW ABI: 3.1 (firmware rev 0x0015 '21.1.1--v2021.01a (Terrific Lla')
    Trying to boot from MMC2
    Loading Environment from MMC... *** Warning - No MMC card found, using default environment
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.4(release):2021.00.003-dirty
    NOTICE:  BL31: Built : 20:50:00, Jun  1 2021
    U-Boot SPL 2020.01-g2781231a33 (Jun 01 2021 - 20:50:42 +0000)
    U-Boot 2020.01-g2781231a33 (Jun 01 2021 - 20:50:42 +0000)
  • Yes, booting is stuck here, even I reboot
  • Looks like the U-Boot on your SD card had problems. What's in the boot partition of your SD card? It should have the following:
    tiboot3.bin  tispl.bin  u-boot.img  uEnv.txt
    Can you do a fresh build? The changes you made to do package_deb may have affected the build.
    Jianzhong
  • I agree with the booting issue. But I did use a new ubuntu18.04 server to rebuild the image, and this time, I didn't change any files (Exactly the operation above).
  • This is my boot folder
  • Your boot folder looks good. What's the size of the wic.xz file for base image?
    I assume that your board's boot switches are set for SD card boot, since you said the prebuilt default image worked fine. Is that right?
  • This is the size:
    Yes, the prebuilt default image works!
  • The sizes of the wic.xz files look good. I'm not sure what is the problem in your build.
    Can you share the boot log of booting with prebuilt default image?
  • U-Boot SPL 2020.01-ge995ed0ec1 (May 28 2021 - 16:20:13 +0000)
    EEPROM not available at 80, trying to read at 81
    SPL initial stack usage: 13396 bytes
    NOTICE:  BL31: Built : 14:41:43, May 28 2021
    U-Boot SPL 2020.01-ge995ed0ec1 (May 28 2021 - 14:48:57 +0000)
    U-Boot 2020.01-ge995ed0ec1 (May 28 2021 - 14:48:57 +0000)
    SoC:   AM64X SR1.0
    Model: Texas Instruments AM642 SK
    Board: AM64-SKEVM rev E2
    DRAM:  2 GiB
    MMC:   sdhci@fa00000: 1
    Loading Environment from FAT... In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Net:
    Warning: ethernet@8000000 using MAC address from ROM
    eth0: ethernet@8000000
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    574 bytes read in 2 ms (280.3 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    SoC:   AM64X SR1.0
    DRAM:  2 GiB
    Out:   serial@2800000
    Err:   serial@2800000
    Net:
    16799752 bytes read in 650 ms (24.6 MiB/s)
    35511 bytes read in 5 ms (6.8 MiB/s)
       Loading Device Tree to 000000008fff4000, end 000000008ffffab6 ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 5.4.106-g023faefa70 (oe-user@oe-host) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 SMP PREEMPT Fri May 28 14:38:23 UTC 2021
    [    0.000000] Machine model: Texas Instruments AM642 SK
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.0
    [    0.000000] percpu: Embedded 2 pages/cpu s48472 r8192 d74408 u131072
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] Built 1 zonelists, mobility grouping off.  Total pages: 3296
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=fc40000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern) root=PARTUUID=3c261301-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 32768 (order: 2, 262144 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 16384 (order: 1, 131072 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0xbbff0000-0xbfff0000] (64MB)
    [    0.000000] Memory: 1388096K/212992K available (9662K kernel code, 854K rwdata, 3840K rodata, 1664K init, 681K bss, 18446744073707852224K reserved, 524288K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000]  Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: no VLPI support, no direct LPI support
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001840000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @df000000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000000df870000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000df880000
    [    0.000000] random: get_random_bytes called from start_kernel+0x2b8/0x42c with crng_init=0
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000005] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008449] Console: colour dummy device 80x25
    [    0.013042] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023712] pid_max: default: 32768 minimum: 301
    [    0.028529] LSM: Security Framework initializing
    [    0.033341] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.040936] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.051520] ASID allocator initialised with 32768 entries
    [    0.057216] rcu: Hierarchical SRCU implementation.
    [    0.062391] Platform MSI: msi-controller@1820000 domain created
    [    0.068673] PCI/MSI: /bus@f4000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.078258] smp: Bringing up secondary CPUs ...
    [    0.083678] Detected VIPT I-cache on CPU1
    [    0.083716] GICv3: CPU1: found redistributor 1 region 0:0x0000000001860000
    [    0.083731] GICv3: CPU1: using allocated LPI pending table @0x00000000df890000
    [    0.083786] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.083910] smp: Brought up 1 node, 2 CPUs
    [    0.113291] SMP: Total of 2 processors activated.
    [    0.118102] CPU features: detected: 32-bit EL0 Support
    [    0.123369] CPU features: detected: CRC32 instructions
    [    0.134833] CPU: All CPU(s) started at EL2
    [    0.139035] alternatives: patching kernel code
    [    0.145134] devtmpfs: initialized
    [    0.154440] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.164431] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
    [    0.174264] pinctrl core: initialized pinctrl subsystem
    [    0.180696] NET: Registered protocol family 16
    [    0.192631] DMA: preallocated 256 KiB pool for atomic allocations
    [    0.199789] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.220526] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    [    0.227409] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    [    0.234177] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.242802] cryptd: max_cpu_qlen set to 1000
    [    0.251149] vcc_3v3_sys: supplied by vusb_main5v0
    [    0.256893] iommu: Default domain type: Translated
    [    0.262390] SCSI subsystem initialized
    [    0.266763] mc: Linux media interface: v0.10
    [    0.271158] videodev: Linux video capture interface: v2.00
    [    0.276788] pps_core: LinuxPPS API ver. 1 registered
    [    0.281860] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.291203] PTP clock support registered
    [    0.295231] EDAC MC: Ver: 3.0.0
    [    0.299187] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fc9100
    [    0.306248] omap-mailbox 29040000.mailbox: omap mailbox rev 0x66fc9100
    [    0.313046] omap-mailbox 29060000.mailbox: omap mailbox rev 0x66fc9100
    [    0.320397] FPGA manager framework
    [    0.323998] Advanced Linux Sound Architecture Driver Initialized.
    [    0.331330] clocksource: Switched to clocksource arch_sys_counter
    [    0.337816] VFS: Disk quotas dquot_6.6.0
    [    0.341963] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
    [    0.354906] thermal_sys: Registered thermal governor 'step_wise'
    [    0.354913] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.361534] NET: Registered protocol family 2
    [    0.373398] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
    [    0.382260] TCP established hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.390241] TCP bind hash table entries: 8192 (order: 1, 131072 bytes, linear)
    [    0.397749] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.404404] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.411351] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.418910] NET: Registered protocol family 1
    [    0.424029] RPC: Registered named UNIX socket transport module.
    [    0.430131] RPC: Registered udp transport module.
    [    0.434942] RPC: Registered tcp transport module.
    [    0.439749] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.446342] PCI: CLS 0 bytes, default 64
    [    0.451128] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
    [    0.463682] Initialise system trusted keyrings
    [    0.468513] workingset: timestamp_bits=46 max_order=15 bucket_order=0
    [    0.481080] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.487867] NFS: Registering the id_resolver key type
    [    0.493078] Key type id_resolver registered
    [    0.497368] Key type id_legacy registered
    [    0.501477] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.508561] 9p: Installing v9fs 9p2000 file system support
    [    0.529628] Key type asymmetric registered
    [    0.533833] Asymmetric key parser 'x509' registered
    [    0.538874] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.546433] io scheduler mq-deadline registered
    [    0.551062] io scheduler kyber registered
    [    0.557244] pinctrl-single f4000.pinctrl: 185 pins, size 740
    [    0.564215] pinctrl-single a40000.timesync-router: 512 pins, size 2048
    [    0.578173] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.599891] brd: module loaded
    [    0.611684] loop: module loaded
    [    0.618019] libphy: Fixed MDIO Bus: probed
    [    0.622870] tun: Universal TUN/TAP device driver, 1.6
    [    0.628690] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
    [    0.636712] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.642811] sky2: driver version 1.30
    [    0.647627] VFIO - User Level meta-driver version: 0.3
    [    0.653779] i2c /dev entries driver
    [    0.658159] sdhci: Secure Digital Host Controller Interface driver
    [    0.664483] sdhci: Copyright(c) Pierre Ossman
    [    0.669376] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.675876] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.682140] ti-sci bus@f4000:dmsc: invalid resource
    [    0.688358] optee: probing for conduit method from DT.
    [    0.693684] optee: revision 3.11 (c4def2a8)
    [    0.694530] optee: initialized driver
    [    0.704422] NET: Registered protocol family 17
    [    0.709223] 9pnet: Installing 9P2000 support
    [    0.713691] Key type dns_resolver registered
    [    0.718509] registered taskstats version 1
    [    0.722708] Loading compiled-in X.509 certificates
    [    0.736625] ti-sci bus@f4000:dmsc: invalid resource
    [    0.741828] ti-sci bus@f4000:dmsc: ABI: 3.1 (firmware rev 0x0015 '21.1.1--v2021.01a (Terrific Lla')
    [    0.766898] omap_i2c 20000000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.773827] pca953x 1-0070: 1-0070 supply vcc not found, using dummy regulator
    [    0.781319] pca953x 1-0070: using no AI
    [    0.807909] omap_i2c 20010000.i2c: bus 1 rev0.12 at 400 kHz
    [    0.814589] omap_i2c 20020000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.820568] ti-sci-intr bus@f4000:interrupt-controller0: Interrupt Router 3 domain created
    [    0.829251] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain -1 created
    [    0.841976] ti-bcdma 485c0100.dma-controller: Number of rings: 68
    [    0.849419] ti-bcdma 485c0100.dma-controller: Channels: 24 (bchan: 12, tchan: 6, rchan: 6)
    [    0.859720] ti-pktdma 485c0000.dma-controller: Number of rings: 288
    [    0.871457] ti-pktdma 485c0000.dma-controller: Channels: 32 (tchan: 21, rchan: 11)
    [    0.881878] printk: console [ttyS2] disabled
    [    0.886317] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 8, base_baud = 3000000) is a 8250
    [    0.894985] printk: console [ttyS2] enabled
    [    0.903427] printk: bootconsole [ns16550a0] disabled
    [    0.917586] random: fast init done
    [    0.924735] cadence-qspi fc40000.spi: PHY calibration failed: -2. Falling back to slow read speeds.
    [    0.933790] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    0.938773] 7 cmdlinepart partitions found on MTD device fc40000.spi.0
    [    0.945294] Creating 7 MTD partitions on "fc40000.spi.0":
    [    0.950692] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    0.957622] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    0.964231] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    0.970905] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    0.977342] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [    0.984406] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    0.991036] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.043398] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.050994] libphy: 8000f00.mdio: probed
    [    1.057726] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.065835] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
    [    1.073954] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA00903, cpsw version 0x6BA80903 Ports: 3 quirks:00000002
    [    1.087183] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 16
    [    1.093731] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.4
    [    1.100871] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    1.107577] pps pps0: new PPS source ptp0
    [    1.112056] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
    [    1.124431] am65-cpts 39000000.cpts: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
    [    1.138836] davinci_gpio 601000.gpio: IRQ index 2 not found
    [    1.144471] davinci_gpio 601000.gpio: IRQ not populated, err = -6
    [    1.152064] vdd_mmc1: supplied by vcc_3v3_sys
    [    1.156809] fixed-regulator-com8 GPIO handle specifies active low - ignored
    [    1.164202] wlan_en: supplied by com8_ls_en
    [    1.169529] mmc0: CQHCI version 5.10
    [    1.206719] mmc0: SDHCI controller on fa10000.sdhci [fa10000.sdhci] using ADMA 64-bit
    [    1.215865] mmc1: CQHCI version 5.10
    [    1.224225] sdhci-am654 fa10000.sdhci: card claims to support voltages below defined range
    [    1.243695] mmc0: new SDIO card at address 0001
    [    1.260819] mmc1: SDHCI controller on fa00000.sdhci [fa00000.sdhci] using ADMA 64-bit
    [    1.268879] debugfs: Directory 'pd:114' with parent 'pm_genpd' already present!
    [    1.278325] hctosys: unable to open rtc device (rtc0)
    [    1.286024] ALSA device list:
    [    1.289014]   No soundcards found.
    [    1.293111] Waiting for root device PARTUUID=3c261301-02...
    [    1.332460] mmc1: new ultra high speed SDR104 SDXC card at address aaaa
    [    1.339974] mmcblk1: mmc1:aaaa SC64G 59.5 GiB
    [    1.349850]  mmcblk1: p1 p2
    [    1.472436] EXT4-fs (mmcblk1p2): recovery complete
    [    1.478307] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    1.486494] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    1.497483] devtmpfs: mounted
    [    1.501587] Freeing unused kernel memory: 1664K
    [    1.506144] Run /sbin/init as init process
    [    1.629660] systemd[1]: System time before build time, advancing clock.
    [    1.689829] NET: Registered protocol family 10
    [    1.695672] Segment Routing with IPv6
    [    1.726954] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    1.749153] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2020.09!
    [    1.810200] systemd[1]: Set hostname to <am64xx-evm>.
    [    2.151677] systemd[1]: /lib/systemd/system/startwlan.service:7: Unknown key name 'After' in section 'Service', ignoring.
    [    2.352955] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.360018] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    2.372387] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    2.384642] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    2.407593] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.415789] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    2.435618] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.443939] systemd[1]: Created slice system-syslog\x2dng.slice.
    [  OK  ] Created slice system-syslog\x2dng.slice.
    [    2.465283] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    2.484024] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [    2.511900] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [    2.535859] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    2.551642] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    2.567624] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    2.583655] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    2.600738] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    2.619707] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    2.647482] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    2.664015] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    2.694443] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    2.703522] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    2.724359] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    2.744598] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    2.764389] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    2.784106] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    2.810234] systemd[1]: Mounting Huge Pages File System...
    [    2.834117] systemd[1]: Mounting POSIX Message Queue File System...
    [    2.862357] systemd[1]: Mounting Kernel Debug File System...
    [    2.888205] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    2.910778] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st…odes for the current kernel...
    [    2.945860] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [    2.970432] systemd[1]: Starting RPC Bind...
    [    2.994437] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    3.029637] systemd[1]: Starting Journal Service...
    [    3.067071] systemd[1]: Starting Load Kernel Modules...
    [    3.106311] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    3.122112] cryptodev: loading out-of-tree module taints kernel.
    [    3.134910] cryptodev: driver 1.10 loaded.
    [    3.152606] systemd[1]: Starting udev Coldplug all Devices...
    [    3.202629] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    3.234946] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [    3.244378] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Started Create list of sta… nodes for the current kernel.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
             Starting Apply Kernel Variables...
    [    3.500288] systemd-journald[150]: Received client request to flush runtime journal.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Kernel Device Manager...
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target System Time Synchronized.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Ethernet Bridge Filtering Tables...
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Reboot and dump vmcore via kexec...
             Starting Matrix GUI...
             Starting startwlan...
             Starting System Logger Daemon "default" instance...
             Starting Login Service...
             Starting telnetd.service...
    [  OK  ] Started Ethernet Bridge Filtering Tables.
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [    5.214521] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [  OK  ] Started Matrix GUI.
    [  OK  ] Started telnetd.service.
    [  OK  ] Started startwlan.
    [  OK  ] Reached target Network (Pre).
             Starting syslog.service...
             Starting Network Service...
    [    5.324278] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    5.622484] wl18xx_driver wl18xx.0.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...
    [    5.992175] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
    [    6.007811] wlcore: loaded
    [    6.143436] random: crng init done
    [    6.143447] random: 7 urandom warning(s) missed due to ratelimiting
    [  OK  ] Started Load/Save Random Seed.
    [  OK  ] Started Login Service.
    [  OK  ] Started System Logger Daemon "default" instance.
    [  OK  ] Started syslog.service.
    [    6.585252] startwlan.sh[260]: adding wlan1 interface
    [    6.715875] startwlan.sh[263]: Configuration file: /usr/share/wl18xx/hostapd.conf
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Started Vsftpd ftp daemon.
    [    7.239684] wlcore: using inverted interrupt logic: 2
    [  OK  ] Started Enable and configure wl18xx bluetooth stack.
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [    7.342354] wlcore: PHY firmware version: Rev 8.2.0.0.245
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
    [    7.459148] wlcore: firmware booted (Rev 8.9.0.0.86)
             Starting Synchronize System and HW clocks...
    [    7.412493] startwlan.sh[263]: wlan1: interface state UNINITIALIZED->COUNTRY_UPDATE
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [    7.492754] startwlan.sh[263]: Using interface wlan1 with hwaddr 90:e2:02:a2:bc:9a and ssid "AM64xSK-AP"
    [    7.534522] startwlan.sh[263]: random: Cannot read from /dev/random: Resource temporarily unavailable
    [    7.535352] startwlan.sh[263]: random: Only 0/20 bytes of strong random data available
    [    7.536371] startwlan.sh[2[    7.632401] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
    63]: random: Not enough entropy pool available for secure operations
    [    7.537093] startwlan.sh[263]: WPA: Not enough entropy in random pool for secure operations - update keys later when the first station connects
    [    7.621921] startwlan.sh[263]: wlan1: interface state COUNTRY_UPDATE->ENABLED
    [    7.622444] startwlan.sh[263]: wlan1: AP-ENABLED
    [  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
    [    8.372721] platform 78000000.r5f: configured R5F for remoteproc mode
    [    8.525152] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [    8.645026] remoteproc remoteproc0: 78000000.r5f is available
    [    8.794705] remoteproc remoteproc0: powering up 78000000.r5f
    [    8.800523] remoteproc remoteproc0: Booting fw image am64-main-r5f0_0-fw, size 86732
    [    8.834581] platform 78200000.r5f: configured R5F for remoteproc mode
    [    8.841979] platform 78000000.r5f: booting R5F core using boot addr = 0x0
    [    8.855591]  remoteproc0#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
    [    8.876417] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    8.877111] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    8.895885]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [    8.911754] remoteproc remoteproc0: remote processor 78000000.r5f is now up
    [    8.983864] TI DP83867 8000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=8000f00.mdio:00, irq=POLL)
    [    9.008035] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
    [    9.048575] platform 78200000.r5f: assigned reserved memory node r5f-dma-memory@a1000000
    [    9.110504] TI DP83867 8000f00.mdio:01: attached PHY driver [TI DP83867] (mii_bus:phy_addr=8000f00.mdio:01, irq=POLL)
    [    9.134830] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down
    [    9.275231] remoteproc remoteproc1: 78200000.r5f is available
    [    9.321798] remoteproc remoteproc1: powering up 78200000.r5f
    [    9.335504] remoteproc remoteproc1: Booting fw image am64-main-r5f0_1-fw, size 117792
    [    9.366293] platform 78200000.r5f: booting R5F core using boot addr = 0x0
    [    9.391713]  remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@a1000000
    [    9.412287] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    9.437298]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [    9.451389] remoteproc remoteproc1: remote processor 78200000.r5f is now up
    [    9.460958] platform 78400000.r5f: configured R5F for remoteproc mode
    [    9.471538] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    9.580475] platform 78400000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    NOTICE: This file system contains the following GPLv3 packages:
            autoconf
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            gstreamer1.0-libav
            gzip
            less
            libasm1
            libbfd
            libdw1
            libelf1
            libgdbm-compat4
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp10
            libidn2-0
            libmpc3
            libmpfr6
            libreadline8
            libunistring2
            m4
            make
            nettle
            parted
            tar
            which
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  Thi[    9.663621] remoteproc remoteproc2: 78400000.r5f is available
    s can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
    [    9.765895] remoteproc remoteproc2: powering up 78400000.r5f
    [    9.775443] remoteproc remoteproc2: Booting fw image am64-main-r5f1_0-fw, size 90696
    [    9.790579] platform 78600000.r5f: configured R5F for remoteproc mode
    [    9.802420] platform 78400000.r5f: booting R5F core using boot addr = 0x0
    [    9.812686]  remoteproc2#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
    [    9.828308] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    9.843594]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [    9.855440] remoteproc remoteproc2: remote processor 78400000.r5f is now up
    [    9.871425] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [    9.925308] platform 78600000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [   10.023478] remoteproc remoteproc3: 78600000.r5f is available
    [   10.096950] remoteproc remoteproc3: powering up 78600000.r5f
    [   10.105086] remoteproc remoteproc3: Booting fw image am64-main-r5f1_1-fw, size 89596
    [   10.131911] platform 78600000.r5f: booting R5F core using boot addr = 0x0
    [   10.147238]  remoteproc3#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
    [   10.164307] virtio_rpmsg_bus virtio3: rpmsg host is online
    [   10.175513]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
    [   10.190726] remoteproc remoteproc3: remote processor 78600000.r5f is now up
    [   10.203521] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org am64xx-evm ttyS2
    Arago 2020.09 am64xx-evm ttyS2
    am64xx-evm login: [   13.850050] cdns-usb3 f400000.usb: DRD version v1 (ID: 0004024e, rev: 00000200)
    [   14.152600] usbcore: registered new interface driver usbfs
    [   14.176663] usbcore: registered new interface driver hub
    [   14.224214] usbcore: registered new device driver usb
    [   14.285516] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [   14.313661] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
    [   14.333200] xhci-hcd xhci-hcd.1.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000000000010010
    [   14.351956] xhci-hcd xhci-hcd.1.auto: irq 335, io mem 0x0f410000
    [   14.371930] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
    [   14.388552] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   14.403404] usb usb1: Product: xHCI Host Controller
    [   14.423554] usb usb1: Manufacturer: Linux 5.4.106-g023faefa70 xhci-hcd
    [   14.436928] usb usb1: SerialNumber: xhci-hcd.1.auto
    [   14.455622] hub 1-0:1.0: USB hub found
    [   14.463571] hub 1-0:1.0: 1 port detected
    [   14.476125] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [   14.483055] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
    [   14.511396] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
    [   14.527530] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   14.543597] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
    [   14.560717] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   14.575450] usb usb2: Product: xHCI Host Controller
    [   14.581705] usb usb2: Manufacturer: Linux 5.4.106-g023faefa70 xhci-hcd
    [   14.595571] usb usb2: SerialNumber: xhci-hcd.1.auto
    [   14.609483] hub 2-0:1.0: USB hub found
    [   14.614726] hub 2-0:1.0: 1 port detected
  • Hi Zehua,
    Did you post anything here? I don't see anything.
    Jianzhong
  • A Message from the TI E2ETm design support forums
    Texas Instruments
    Zehua Zhou
    SoC: AM64X SR1.0
    DRAM: 2 GiB
    Out: serial@2800000
    Err: serial@2800000
    Net:
    SoC: AM64X SR1.0
    DRAM: 2 GiB
    Out: serial@2800000
    Err: serial@2800000
    Net:
    Starting kernel ...
    autoconf
    bash
    bc
    binutils
    cifs-utils
    coreutils-stdbuf
    coreutils
    cpio
    cpp-symlinks
    cpp
    dosfstools
    elfutils
    g++-symlinks
    g++
    gawk
    gcc-symlinks
    gcc
    gdb
    gdbserver
    gettext
    gstreamer1.0-libav
    gzip
    less
    libasm1
    libbfd
    libdw1
    libelf1
    libgdbm-compat4
    libgdbm6
    libgettextlib
    libgettextsrc
    libgmp10
    libidn2-0
    libmpc3
    libmpfr6
    libreadline8
    libunistring2
    m4
    make
    nettle
    parted
    tar
    which
    s can be done using
    _____ _____ _ _
    |___| |___|
  • Hi Zehua,
    Thanks for the boot log. I saw that you have an AM64x Starter Kit (SK) EVM, while I used the GP EVM for my testing. I then tried to boot my SK EVM with the base image and I had the same problem.
    I think the reason is that the AM64x SK EVM was not supported until Processor-SDK release 7.3.1, while the upstreamed config is for release 7.3.0:
    I built the default SDK image with the same config and it works fine on SK EVM:
    MACHINE=am64xx-evm bitbake -k tisdk-default-image
    I will ask the core SDK team to upstream latest config to support the SK EVM. Meanwhile, maybe you can try to build the default image.
    Thanks for your patience.
    Jianzhong
