Part Number: PROCESSOR-SDK-AM335X
Other Parts Discussed in Thread: AM3352, TPS65217
I am trying to interface 7inch capacitive touch display(Model no:AFK800480A0-7.0N12NTM- C) with Beagle bone black. LCD is up and running and i am not able to configure touch panel. I am getting
below errors in the log.
ti_am3359-tscadc 44e0d000.tscadc: Need atleast one channel.
ti_am3359-tscadc: probe of 44e0d000.tscadc failed with error -22
I am attaching DT related files.
* Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
#include <dt-bindings/display/tda998x.h>
#include <dt-bindings/interrupt-controller/irq.h>
&ldo3_reg {
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
regulator-always-on;
&mmc1 {
vmmc-supply = <&vmmcsd_fixed>;
&mmc2 {
pinctrl-names = "default";
pinctrl-0 = <&emmc_pins>;
bus-width = <8>;
status = "okay";
&am33xx_pinmux {
nxp_hdmi_bonelt_pins: lcd_pins_default {
pinctrl-single,pins = <
AM33XX_IOPAD(0x8a0, PIN_OUTPUT | MUX_MODE0) /* lcd_data0.lcd_data0 */
AM33XX_IOPAD(0x8a4, PIN_OUTPUT | MUX_MODE0) /* lcd_data1.lcd_data1 */
AM33XX_IOPAD(0x8a8, PIN_OUTPUT | MUX_MODE0) /* lcd_data2.lcd_data2 */
AM33XX_IOPAD(0x8ac, PIN_OUTPUT | MUX_MODE0) /* lcd_data3.lcd_data3 */
AM33XX_IOPAD(0x8b0, PIN_OUTPUT | MUX_MODE0) /* lcd_data4.lcd_data4 */
AM33XX_IOPAD(0x8b4, PIN_OUTPUT | MUX_MODE0) /* lcd_data5.lcd_data5 */
AM33XX_IOPAD(0x8b8, PIN_OUTPUT | MUX_MODE0) /* lcd_data6.lcd_data6 */
AM33XX_IOPAD(0x8bc, PIN_OUTPUT | MUX_MODE0) /* lcd_data7.lcd_data7 */
AM33XX_IOPAD(0x8c0, PIN_OUTPUT | MUX_MODE0) /* lcd_data8.lcd_data8 */
AM33XX_IOPAD(0x8c4, PIN_OUTPUT | MUX_MODE0) /* lcd_data9.lcd_data9 */
AM33XX_IOPAD(0x8c8, PIN_OUTPUT | MUX_MODE0) /* lcd_data10.lcd_data10 */
AM33XX_IOPAD(0x8cc, PIN_OUTPUT | MUX_MODE0) /* lcd_data11.lcd_data11 */
AM33XX_IOPAD(0x8d0, PIN_OUTPUT | MUX_MODE0) /* lcd_data12.lcd_data12 */
AM33XX_IOPAD(0x8d4, PIN_OUTPUT | MUX_MODE0) /* lcd_data13.lcd_data13 */
AM33XX_IOPAD(0x8d8, PIN_OUTPUT | MUX_MODE0) /* lcd_data14.lcd_data14 */
AM33XX_IOPAD(0x8dc, PIN_OUTPUT | MUX_MODE0) /* lcd_data15.lcd_data15 */
AM33XX_IOPAD(0x8e0, PIN_OUTPUT | MUX_MODE0) /* lcd_vsync.lcd_vsync */
AM33XX_IOPAD(0x8e4, PIN_OUTPUT | MUX_MODE0) /* lcd_hsync.lcd_hsync */
AM33XX_IOPAD(0x8e8, PIN_OUTPUT | MUX_MODE0) /* lcd_pclk.lcd_pclk */
AM33XX_IOPAD(0x8ec, PIN_OUTPUT | MUX_MODE0) /* lcd_ac_bias_en.lcd_ac_bias_en */
AM33XX_IOPAD(0x850, PIN_OUTPUT_PULLUP | MUX_MODE7)/*
gpmc_a4.gpio1[20] LCD_EN*/
i2c0_pins:pinmux_i2c0_pins {
AM33XX_IOPAD(0x95c, PIN_INPUT_PULLUP | MUX_MODE2) /*i2c0_SCL*/
AM33XX_IOPAD(0x958, PIN_INPUT_PULLUP | MUX_MODE2) /*i2c0_SDA*/
ts_irq_pin:pinmux_ts_irq_pin {
AM33XX_IOPAD(0x878, PIN_INPUT_PULLDOWN | MUX_MODE7) /*touch_irq*/
&i2c0 {
pinctrl-0 = <&i2c0_pins>;
status = "okay";
clock-frequency = <400000>;
tsc{
status = "okay";
comaptible = "ti,am3359-tsc";
pinctrl-0 = <&ts_irq_pin>;
reg = <0x38>;
interrupt-parent = <&gpio1>;
interrupts-extended = <&gpio1 28 IRQ_TYPE_EDGE_FALLING>;
touchscreen-size-x= <800>;
touchscreen-size-y= <480>;
&lcdc {
status = "okay";
/* If you want to get 24 bit RGB a nd 16 BGR mode instead of
* current 16 bit RGB and 24 BGR modes, set the propety
* below to "crossed" and uncomment the video-ports -property
* in tda19988 node.
//blue-and-red-wiring = "crossed";
video-ports = <0x234501>;
blue-and-red-wiring = "straight";
/dts-v1/;
#include "am33xx.dtsi"
#include "am335x-bone-common.dtsi"
#include "am335x-boneblack-common.dtsi"
&sgx {
status = "okay";
model = "TI AM335x BeagleBone Black";
compatible = "ti,am335x-bone-black", "ti,am335x-bone", "ti,am33xx";
#if 0
backlight {
compatible = "pwm-backlight";
pwms = <&ehrpwm1 0 500000 0>;
brightness-levels = <0 58 61 66 75 90 125 170 255>;
default-brightness-level = <8>;
#endif
lcd0:panel{
compatible = "ti,tilcdc,panel";
pinctrl-0 = <&nxp_hdmi_bonelt_pins>;
enable-gpios = <&gpio1 20 0>;
status = "okay";
panel-info {
ac-bias = <255>; /*AC Bias pin frequency*/
ac-bias-intrpt = <0>;/* AC Bias Pin transition per Interrupt*/
dma-burst-sz = <16>; /* DMA burst size*/
bpp = <16>; /* bits per pixel*/
fdd = <0x80>; /* FIFO DMA request delay*/
sync-edge = <0>; /*Horzontal & vertical sync edge*/
sync-ctrl = <1>; /* H & V sync control */
raster-order = <1>; /* Raster data order select*/
fifo-th = <0>; /*DMS FIFO threshold*/
invert-pxl-clk = <1>;
tft-alt-mode = <0>;
stn-565-mode = <0>;
mono-8bit-mode = <0>;
display-timings {
native-mode = <&timing0>;
timing0:800x480
clock-frequency = <33300000>;
hactive = <800>;
vactive = <480>;
hfront-porch = <55>;
hback-porch = <46>;
hsync-len = <20>;
vsync-len = <10>;
vback-porch = <23>;
vfront-porch = <22>;
hsync-active = <1>;
vsync-active = <1>;
de-active = <1>;
pixelclk-active = <1>;
&cpu0_opp_table {
* All PG 2.0 silicon may not support 1GHz but some of the early
* BeagleBone Blacks have PG 2.0 silicon which is guaranteed
* to support 1GHz OPP so enable it for PG 2.0 on this board.
oppnitro-1000000000 {
opp-supported-hw = <0x06 0x0100>;
* Device Tree Source for AM33XX SoC
* This file is licensed under the terms of the GNU General Public License
* version 2. This program is licensed "as is" without any warranty of any
* kind, whether express or implied.
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/pinctrl/am33xx.h>
#include <dt-bindings/clock/am3.h>
compatible = "ti,am33xx";
interrupt-parent = <&intc>;
#address-cells = <1>;
#size-cells = <1>;
chosen { };
aliases {
i2c0 = &i2c0;
i2c1 = &i2c1;
i2c2 = &i2c2;
serial0 = &uart0;
serial1 = &uart1;
serial2 = &uart2;
serial3 = &uart3;
serial4 = &uart4;
serial5 = &uart5;
d-can0 = &dcan0;
d-can1 = &dcan1;
usb0 = &usb0;
usb1 = &usb1;
phy0 = &usb0_phy;
phy1 = &usb1_phy;
ethernet0 = &cpsw_emac0;
ethernet1 = &cpsw_emac1;
spi0 = &spi0;
spi1 = &spi1;
cpus {
#size-cells = <0>;
cpu@0 {
compatible = "arm,cortex-a8";
enable-method = "ti,am3352";
device_type = "cpu";
reg = <0>;
operating-points-v2 = <&cpu0_opp_table>;
clocks = <&dpll_mpu_ck>;
clock-names = "cpu";
clock-latency = <300000>; /* From omap-cpufreq driver */
cpu-idle-states = <&mpu_gate>;
idle-states {
mpu_gate: mpu_gate {
compatible = "arm,idle-state";
entry-latency-us = <40>;
exit-latency-us = <90>;
min-residency-us = <300>;
ti,idle-wkup-m3;
cpu0_opp_table: opp-table {
compatible = "operating-points-v2-ti-cpu";
syscon = <&scm_conf>;
* The three following nodes are marked with opp-suspend
* because the can not be enabled simultaneously on a
* single SoC.
opp50-300000000 {
opp-hz = /bits/ 64 <300000000>;
opp-microvolt = <950000 931000 969000>;
opp-supported-hw = <0x06 0x0010>;
opp-suspend;
opp100-275000000 {
opp-hz = /bits/ 64 <275000000>;
opp-microvolt = <1100000 1078000 1122000>;
opp-supported-hw = <0x01 0x00FF>;
opp-suspend;
opp100-300000000 {
opp-supported-hw = <0x06 0x0020>;
opp-suspend;
opp100-500000000 {
opp-hz = /bits/ 64 <500000000>;
opp-supported-hw = <0x01 0xFFFF>;
opp100-600000000 {
opp-hz = /bits/ 64 <600000000>;
opp-supported-hw = <0x06 0x0040>;
opp120-600000000 {
opp-microvolt = <1200000 1176000 1224000>;
opp120-720000000 {
opp-hz = /bits/ 64 <720000000>;
opp-supported-hw = <0x06 0x0080>;
oppturbo-720000000 {
opp-microvolt = <1260000 1234800 1285200>;
oppturbo-800000000 {
opp-hz = /bits/ 64 <800000000>;
opp-hz = /bits/ 64 <1000000000>;
opp-microvolt = <1325000 1298500 1351500>;
opp-supported-hw = <0x04 0x0200>;
pmu@4b000000 {
compatible = "arm,cortex-a8-pmu";
interrupts = <3>;
reg = <0x4b000000 0x1000000>;
ti,hwmods = "debugss";
* The soc node represents the soc top level view. It is used for IPs
* that are not memory mapped in the MPU view or for the MPU itself.
soc {
compatible = "ti,omap-infra";
mpu {
compatible = "ti,omap3-mpu";
ti,hwmods = "mpu";
pm-sram = <&pm_sram_code
&pm_sram_data>;
* XXX: Use a flat representation of the AM33XX interconnect.
* The real AM33XX interconnect network is quite complex. Since
* it will not bring real advantage to represent that in DT
* for the moment, just use a fake OCP bus entry to represent
* the whole bus hierarchy.
ocp {
compatible = "simple-bus";
#size-cells = <1>;
ranges;
ti,hwmods = "l3_main";
l4_wkup: l4_wkup@44c00000 {
compatible = "ti,am3-l4-wkup", "simple-bus";
#size-cells = <1>;
ranges = <0 0x44c00000 0x280000>;
wkup_m3: wkup_m3@100000 {
compatible = "ti,am3352-wkup-m3";
reg = <0x100000 0x4000>,
<0x180000 0x2000>;
reg-names = "umem", "dmem";
ti,hwmods = "wkup_m3";
ti,pm-firmware = "am335x-pm-firmware.elf";
prcm: prcm@200000 {
compatible = "ti,am3-prcm", "simple-bus";
reg = <0x200000 0x4000>;
#size-cells = <1>;
ranges = <0 0x200000 0x4000>;
prcm_clocks: clocks {
#size-cells = <0>;
prcm_clockdomains: clockdomains {
scm: scm@210000 {
compatible = "ti,am3-scm", "simple-bus";
reg = <0x210000 0x2000>;
#size-cells = <1>;
#pinctrl-cells = <1>;
ranges = <0 0x210000 0x2000>;
am33xx_pinmux: pinmux@800 {
compatible = "pinctrl-single";
reg = <0x800 0x238>;
#size-cells = <0>;
pinctrl-single,register-width = <32>;
pinctrl-single,function-mask = <0x7f>;
scm_conf: scm_conf@0 {
compatible = "syscon", "simple-bus";
reg = <0x0 0x800>;
#size-cells = <1>;
ranges = <0 0 0x800>;
scm_clocks: clocks {
#size-cells = <0>;
wkup_m3_ipc: wkup_m3_ipc@1324 {
compatible = "ti,am3352-wkup-m3-ipc";
reg = <0x1324 0x24>;
interrupts = <78>;
ti,rproc = <&wkup_m3>;
mboxes = <&mailbox &mbox_wkupm3>;
edma_xbar: dma-router@f90 {
compatible = "ti,am335x-edma-crossbar";
reg = <0xf90 0x40>;
#dma-cells = <3>;
dma-requests = <32>;
dma-masters = <&edma>;
scm_clockdomains: clockdomains {
intc: interrupt-controller@48200000 {
compatible = "ti,am33xx-intc";
interrupt-controller;
#interrupt-cells = <1>;
reg = <0x48200000 0x1000>;
edma: edma@49000000 {
compatible = "ti,edma3-tpcc";
ti,hwmods = "tpcc";
reg = <0x49000000 0x10000>;
reg-names = "edma3_cc";
interrupts = <12 13 14>;
interrupt-names = "edma3_ccint", "edma3_mperr",
"edma3_ccerrint";
dma-requests = <64>;
#dma-cells = <2>;
ti,tptcs = <&edma_tptc0 7>, <&edma_tptc1 5>,
<&edma_tptc2 0>;
ti,edma-memcpy-channels = <20 21>;
edma_tptc0: tptc@49800000 {
compatible = "ti,edma3-tptc";
ti,hwmods = "tptc0";
reg = <0x49800000 0x100000>;
interrupts = <112>;
interrupt-names = "edma3_tcerrint";
edma_tptc1: tptc@49900000 {
ti,hwmods = "tptc1";
reg = <0x49900000 0x100000>;
interrupts = <113>;
edma_tptc2: tptc@49a00000 {
ti,hwmods = "tptc2";
reg = <0x49a00000 0x100000>;
interrupts = <114>;
gpio0: gpio@44e07000 {
compatible = "ti,omap4-gpio";
ti,hwmods = "gpio1";
gpio-controller;
#gpio-cells = <2>;
#interrupt-cells = <2>;
reg = <0x44e07000 0x1000>;
interrupts = <96>;
gpio1: gpio@4804c000 {
ti,hwmods = "gpio2";
gpio-controller;
#gpio-cells = <2>;
reg = <0x4804c000 0x1000>;
interrupts = <98>;
gpio2: gpio@481ac000 {
ti,hwmods = "gpio3";
gpio-controller;
#gpio-cells = <2>;
reg = <0x481ac000 0x1000>;
interrupts = <32>;
gpio3: gpio@481ae000 {
ti,hwmods = "gpio4";
gpio-controller;
#gpio-cells = <2>;
reg = <0x481ae000 0x1000>;
interrupts = <62>;
uart0: serial@44e09000 {
compatible = "ti,am3352-uart", "ti,omap3-uart";
ti,hwmods = "uart1";
clock-frequency = <48000000>;
reg = <0x44e09000 0x2000>;
interrupts = <72>;
status = "disabled";
dmas = <&edma 26 0>, <&edma 27 0>;
dma-names = "tx", "rx";
uart1: serial@48022000 {
ti,hwmods = "uart2";
reg = <0x48022000 0x2000>;
interrupts = <73>;
dmas = <&edma 28 0>, <&edma 29 0>;
uart2: serial@48024000 {
ti,hwmods = "uart3";
reg = <0x48024000 0x2000>;
interrupts = <74>;
dmas = <&edma 30 0>, <&edma 31 0>;
uart3: serial@481a6000 {
ti,hwmods = "uart4";
reg = <0x481a6000 0x2000>;
interrupts = <44>;
uart4: serial@481a8000 {
ti,hwmods = "uart5";
reg = <0x481a8000 0x2000>;
interrupts = <45>;
uart5: serial@481aa000 {
ti,hwmods = "uart6";
reg = <0x481aa000 0x2000>;
interrupts = <46>;
i2c0: i2c@44e0b000 {
compatible = "ti,am335x-i2c,omap4-i2c";
#size-cells = <0>;
ti,hwmods = "i2c1";
reg = <0x44e0b000 0x1000>;
interrupts = <70>;
status = "okay";
i2c1: i2c@4802a000 {
compatible = "ti,omap4-i2c";
#size-cells = <0>;
ti,hwmods = "i2c2";
reg = <0x4802a000 0x1000>;
interrupts = <71>;
status = "okay";
i2c2: i2c@4819c000 {
#size-cells = <0>;
ti,hwmods = "i2c3";
reg = <0x4819c000 0x1000>;
interrupts = <30>;
mmc1: mmc@48060000 {
compatible = "ti,omap4-hsmmc";
ti,hwmods = "mmc1";
ti,dual-volt;
ti,needs-special-reset;
ti,needs-special-hs-handling;
dmas = <&edma_xbar 24 0 0
&edma_xbar 25 0 0>;
interrupts = <64>;
reg = <0x48060000 0x1000>;
mmc2: mmc@481d8000 {
ti,hwmods = "mmc2";
dmas = <&edma 2 0
&edma 3 0>;
interrupts = <28>;
reg = <0x481d8000 0x1000>;
mmc3: mmc@47810000 {
ti,hwmods = "mmc3";
interrupts = <29>;
reg = <0x47810000 0x1000>;
hwspinlock: spinlock@480ca000 {
compatible = "ti,omap4-hwspinlock";
reg = <0x480ca000 0x1000>;
ti,hwmods = "spinlock";
#hwlock-cells = <1>;
wdt2: wdt@44e35000 {
compatible = "ti,omap3-wdt";
ti,hwmods = "wd_timer2";
reg = <0x44e35000 0x1000>;
interrupts = <91>;
dcan0: can@481cc000 {
compatible = "ti,am3352-d_can";
ti,hwmods = "d_can0";
reg = <0x481cc000 0x2000>;
clocks = <&dcan0_fck>;
clock-names = "fck";
syscon-raminit = <&scm_conf 0x644 0>;
interrupts = <52>;
dcan1: can@481d0000 {
ti,hwmods = "d_can1";
reg = <0x481d0000 0x2000>;
clocks = <&dcan1_fck>;
syscon-raminit = <&scm_conf 0x644 1>;
interrupts = <55>;
mailbox: mailbox@480c8000 {
compatible = "ti,omap4-mailbox";
reg = <0x480C8000 0x200>;
interrupts = <77>;
ti,hwmods = "mailbox";
#mbox-cells = <1>;
ti,mbox-num-users = <4>;
ti,mbox-num-fifos = <8>;
mbox_wkupm3: wkup_m3 {
ti,mbox-send-noirq;
ti,mbox-tx = <0 0 0>;
ti,mbox-rx = <0 0 3>;
timer1: timer@44e31000 {
compatible = "ti,am335x-timer-1ms";
reg = <0x44e31000 0x400>;
interrupts = <67>;
ti,hwmods = "timer1";
ti,timer-alwon;
clocks = <&timer1_fck>;
timer2: timer@48040000 {
compatible = "ti,am335x-timer";
reg = <0x48040000 0x400>;
interrupts = <68>;
ti,hwmods = "timer2";
clocks = <&timer2_fck>;
timer3: timer@48042000 {
reg = <0x48042000 0x400>;
interrupts = <69>;
ti,hwmods = "timer3";
timer4: timer@48044000 {
reg = <0x48044000 0x400>;
interrupts = <92>;
ti,hwmods = "timer4";
ti,timer-pwm;
timer5: timer@48046000 {
reg = <0x48046000 0x400>;
interrupts = <93>;
ti,hwmods = "timer5";
ti,timer-pwm;
timer6: timer@48048000 {
reg = <0x48048000 0x400>;
interrupts = <94>;
ti,hwmods = "timer6";
ti,timer-pwm;
timer7: timer@4804a000 {
reg = <0x4804a000 0x400>;
interrupts = <95>;
ti,hwmods = "timer7";
ti,timer-pwm;
rtc: rtc@44e3e000 {
compatible = "ti,am3352-rtc", "ti,da830-rtc";
reg = <0x44e3e000 0x1000>;
interrupts = <75
76>;
ti,hwmods = "rtc";
clocks = <&l4_per_clkctrl AM3_CLKDIV32K_CLKCTRL 0>;
clock-names = "int-clk";
spi0: spi@48030000 {
compatible = "ti,omap4-mcspi";
#size-cells = <0>;
reg = <0x48030000 0x400>;
interrupts = <65>;
ti,spi-num-cs = <2>;
ti,hwmods = "spi0";
dmas = <&edma 16 0
&edma 17 0
&edma 18 0
&edma 19 0>;
dma-names = "tx0", "rx0", "tx1", "rx1";
spi1: spi@481a0000 {
#size-cells = <0>;
reg = <0x481a0000 0x400>;
interrupts = <125>;
ti,hwmods = "spi1";
dmas = <&edma 42 0
&edma 43 0
&edma 44 0
&edma 45 0>;
usb: usb@47400000 {
compatible = "ti,am33xx-usb";
reg = <0x47400000 0x1000>;
ranges;
#size-cells = <1>;
ti,hwmods = "usb_otg_hs";
usb_ctrl_mod: control@44e10620 {
compatible = "ti,am335x-usb-ctrl-module";
reg = <0x44e10620 0x10
0x44e10648 0x4>;
reg-names = "phy_ctrl", "wakeup";
usb0_phy: usb-phy@47401300 {
compatible = "ti,am335x-usb-phy";
reg = <0x47401300 0x100>;
reg-names = "phy";
ti,ctrl_mod = <&usb_ctrl_mod>;
#phy-cells = <0>;
usb0: usb@47401000 {
compatible = "ti,musb-am33xx";
reg = <0x47401400 0x400
0x47401000 0x200>;
reg-names = "mc", "control";
interrupts = <18>;
interrupt-names = "mc";
dr_mode = "otg";
mentor,multipoint = <1>;
mentor,num-eps = <16>;
mentor,ram-bits = <12>;
mentor,power = <500>;
phys = <&usb0_phy>;
dmas = <&cppi41dma 0 0 &cppi41dma 1 0
&cppi41dma 2 0 &cppi41dma 3 0
&cppi41dma 4 0 &cppi41dma 5 0
&cppi41dma 6 0 &cppi41dma 7 0
&cppi41dma 8 0 &cppi41dma 9 0
&cppi41dma 10 0 &cppi41dma 11 0
&cppi41dma 12 0 &cppi41dma 13 0
&cppi41dma 14 0 &cppi41dma 0 1
&cppi41dma 1 1 &cppi41dma 2 1
&cppi41dma 3 1 &cppi41dma 4 1
&cppi41dma 5 1 &cppi41dma 6 1
&cppi41dma 7 1 &cppi41dma 8 1
&cppi41dma 9 1 &cppi41dma 10 1
&cppi41dma 11 1 &cppi41dma 12 1
&cppi41dma 13 1 &cppi41dma 14 1>;
dma-names =
"rx1", "rx2", "rx3", "rx4", "rx5", "rx6", "rx7",
"rx8", "rx9", "rx10", "rx11", "rx12", "rx13",
"rx14", "rx15",
"tx1", "tx2", "tx3", "tx4", "tx5", "tx6", "tx7",
"tx8", "tx9", "tx10", "tx11", "tx12", "tx13",
"tx14", "tx15";
usb1_phy: usb-phy@47401b00 {
reg = <0x47401b00 0x100>;
reg-names = "phy";
#phy-cells = <0>;
usb1: usb@47401800 {
reg = <0x47401c00 0x400
0x47401800 0x200>;
interrupts = <19>;
dr_mode = "otg";
phys = <&usb1_phy>;
dmas = <&cppi41dma 15 0 &cppi41dma 16 0
&cppi41dma 17 0 &cppi41dma 18 0
&cppi41dma 19 0 &cppi41dma 20 0
&cppi41dma 21 0 &cppi41dma 22 0
&cppi41dma 23 0 &cppi41dma 24 0
&cppi41dma 25 0 &cppi41dma 26 0
&cppi41dma 27 0 &cppi41dma 28 0
&cppi41dma 29 0 &cppi41dma 15 1
&cppi41dma 16 1 &cppi41dma 17 1
&cppi41dma 18 1 &cppi41dma 19 1
&cppi41dma 20 1 &cppi41dma 21 1
&cppi41dma 22 1 &cppi41dma 23 1
&cppi41dma 24 1 &cppi41dma 25 1
&cppi41dma 26 1 &cppi41dma 27 1
&cppi41dma 28 1 &cppi41dma 29 1>;
dma-names =
"rx14", "rx15",
"tx14", "tx15";
cppi41dma: dma-controller@47402000 {
compatible = "ti,am3359-cppi41";
0x47402000 0x1000
0x47403000 0x1000
0x47404000 0x4000>;
reg-names = "glue", "controller", "scheduler", "queuemgr";
interrupts = <17>;
interrupt-names = "glue";
#dma-cells = <2>;
#dma-channels = <30>;
#dma-requests = <256>;
epwmss0: epwmss@48300000 {
compatible = "ti,am33xx-pwmss";
reg = <0x48300000 0x10>;
ti,hwmods = "epwmss0";
#size-cells = <1>;
ranges = <0x48300100 0x48300100 0x80 /* ECAP */
0x48300180 0x48300180 0x80 /* EQEP */
0x48300200 0x48300200 0x80>; /* EHRPWM */
ecap0: ecap@48300100 {
compatible = "ti,am3352-ecap",
"ti,am33xx-ecap";
#pwm-cells = <3>;
reg = <0x48300100 0x80>;
clocks = <&l4ls_gclk>;
interrupts = <31>;
interrupt-names = "ecap0";
ehrpwm0: pwm@48300200 {
compatible = "ti,am3352-ehrpwm",
"ti,am33xx-ehrpwm";
#pwm-cells = <3>;
reg = <0x48300200 0x80>;
clocks = <&ehrpwm0_tbclk>, <&l4ls_gclk>;
clock-names = "tbclk", "fck";
epwmss1: epwmss@48302000 {
reg = <0x48302000 0x10>;
ti,hwmods = "epwmss1";
#size-cells = <1>;
ranges = <0x48302100 0x48302100 0x80 /* ECAP */
0x48302180 0x48302180 0x80 /* EQEP */
0x48302200 0x48302200 0x80>; /* EHRPWM */
ecap1: ecap@48302100 {
"ti,am33xx-ecap";
#pwm-cells = <3>;
reg = <0x48302100 0x80>;
interrupts = <47>;
interrupt-names = "ecap1";
ehrpwm1: pwm@48302200 {
"ti,am33xx-ehrpwm";
#pwm-cells = <3>;
reg = <0x48302200 0x80>;
clocks = <&ehrpwm1_tbclk>, <&l4ls_gclk>;
epwmss2: epwmss@48304000 {
reg = <0x48304000 0x10>;
ti,hwmods = "epwmss2";
#size-cells = <1>;
ranges = <0x48304100 0x48304100 0x80 /* ECAP */
0x48304180 0x48304180 0x80 /* EQEP */
0x48304200 0x48304200 0x80>; /* EHRPWM */
ecap2: ecap@48304100 {
"ti,am33xx-ecap";
#pwm-cells = <3>;
reg = <0x48304100 0x80>;
interrupts = <61>;
interrupt-names = "ecap2";
ehrpwm2: pwm@48304200 {
"ti,am33xx-ehrpwm";
#pwm-cells = <3>;
reg = <0x48304200 0x80>;
clocks = <&ehrpwm2_tbclk>, <&l4ls_gclk>;
mac: ethernet@4a100000 {
compatible = "ti,am335x-cpsw","ti,cpsw";
ti,hwmods = "cpgmac0";
clocks = <&cpsw_125mhz_gclk>, <&cpsw_cpts_rft_clk>;
clock-names = "fck", "cpts";
cpdma_channels = <8>;
ale_entries = <1024>;
bd_ram_size = <0x2000>;
mac_control = <0x20>;
slaves = <2>;
active_slave = <0>;
cpts_clock_mult = <0x80000000>;
cpts_clock_shift = <29>;
reg = <0x4a100000 0x800
0x4a101200 0x100>;
#size-cells = <1>;
* c0_rx_thresh_pend
* c0_rx_pend
* c0_tx_pend
* c0_misc_pend
interrupts = <40 41 42 43>;
ranges;
davinci_mdio: mdio@4a101000 {
compatible = "ti,cpsw-mdio","ti,davinci_mdio";
#size-cells = <0>;
ti,hwmods = "davinci_mdio";
bus_freq = <1000000>;
reg = <0x4a101000 0x100>;
cpsw_emac0: slave@4a100200 {
/* Filled in by U-Boot */
mac-address = [ 00 00 00 00 00 00 ];
cpsw_emac1: slave@4a100300 {
phy_sel: cpsw-phy-sel@44e10650 {
compatible = "ti,am3352-cpsw-phy-sel";
reg= <0x44e10650 0x4>;
reg-names = "gmii-sel";
ocmcram: ocmcram@40300000 {
compatible = "mmio-sram";
reg = <0x40300000 0x10000>; /* 64k */
ranges = <0x0 0x40300000 0x10000>;
#size-cells = <1>;
pm_sram_code: pm-sram-code@0 {
compatible = "ti,sram";
reg = <0x0 0x1000>;
protect-exec;
pm_sram_data: pm-sram-data@1000 {
reg = <0x1000 0x1000>;
pool;
pruss_soc_bus: pruss-soc-bus@4a326004 {
compatible = "ti,am3356-pruss-soc-bus";
reg = <0x4a326004 0x4>;
ti,hwmods = "pruss";
#size-cells = <1>;
ranges;
pruss: pruss@4a300000 {
compatible = "ti,am3356-pruss";
reg = <0x4a300000 0x80000>;
interrupts = <20 21 22 23 24 25 26 27>;
interrupt-names = "host2", "host3", "host4",
"host5", "host6", "host7",
"host8", "host9";
#size-cells = <1>;
ranges;
pruss_mem: memories@4a300000 {
reg = <0x4a300000 0x2000>,
<0x4a302000 0x2000>,
<0x4a310000 0x3000>,
<0x4a32e000 0x31c>,
<0x4a330000 0x60>;
reg-names = "dram0", "dram1",
"shrdram2", "iep", "ecap";
pruss_cfg: cfg@4a326000 {
compatible = "syscon";
reg = <0x4a326000 0x2000>;
pruss_mii_rt: mii-rt@4a332000 {
reg = <0x4a332000 0x58>;
pruss_intc: interrupt-controller@4a320000 {
compatible = "ti,am3356-pruss-intc";
reg = <0x4a320000 0x2000>;
pru0: pru@4a334000 {
compatible = "ti,am3356-pru";
reg = <0x4a334000 0x2000>,
<0x4a322000 0x400>,
<0x4a322400 0x100>;
reg-names = "iram", "control", "debug";
firmware-name = "am335x-pru0-fw";
interrupt-parent = <&pruss_intc>;
interrupts = <16>, <17>;
interrupt-names = "vring", "kick";
pru1: pru@4a338000 {
reg = <0x4a338000 0x2000>,
<0x4a324000 0x400>,
<0x4a324400 0x100>;
firmware-name = "am335x-pru1-fw";
interrupts = <18>, <19>;
pruss_mdio: mdio@4a332400 {
compatible = "ti,davinci_mdio";
reg = <0x4a332400 0x90>;
clocks = <&dpll_core_m4_ck>;
#size-cells = <0>;
elm: elm@48080000 {
compatible = "ti,am3352-elm";
reg = <0x48080000 0x2000>;
interrupts = <4>;
ti,hwmods = "elm";
lcdc: lcdc@4830e000 {
compatible = "ti,am33xx-tilcdc";
reg = <0x4830e000 0x1000>;
interrupts = <36>;
ti,hwmods = "lcdc";
status = "okay";
tscadc: tscadc@44e0d000 {
compatible = "ti,am3359-tscadc";
reg = <0x44e0d000 0x1000>;
interrupts = <16>;
ti,hwmods = "adc_tsc";
status = "okay";
dmas = <&edma 53 0>, <&edma 57 0>;
dma-names = "fifo0", "fifo1";
tsc {
compatible = "ti,am3359-tsc";
am335x_adc: adc {
#io-channel-cells = <1>;
compatible = "ti,am3359-adc";
emif: emif@4c000000 {
compatible = "ti,emif-am3352";
reg = <0x4c000000 0x1000000>;
ti,hwmods = "emif";
interrupts = <101>;
&pm_sram_data>;
ti,no-idle;
gpmc: gpmc@50000000 {
compatible = "ti,am3352-gpmc";
ti,hwmods = "gpmc";
ti,no-idle-on-init;
reg = <0x50000000 0x2000>;
interrupts = <100>;
dmas = <&edma 52 0>;
dma-names = "rxtx";
gpmc,num-cs = <7>;
gpmc,num-waitpins = <2>;
#address-cells = <2>;
#size-cells = <1>;
gpio-controller;
#gpio-cells = <2>;
sham: sham@53100000 {
compatible = "ti,omap4-sham";
ti,hwmods = "sham";
reg = <0x53100000 0x200>;
interrupts = <109>;
dmas = <&edma 36 0>;
dma-names = "rx";
aes: aes@53500000 {
compatible = "ti,omap4-aes";
ti,hwmods = "aes";
reg = <0x53500000 0xa0>;
interrupts = <103>;
dmas = <&edma 6 0>,
<&edma 5 0>;
mcasp0: mcasp@48038000 {
compatible = "ti,am33xx-mcasp-audio";
ti,hwmods = "mcasp0";
reg = <0x48038000 0x2000>,
<0x46000000 0x400000>;
reg-names = "mpu", "dat";
interrupts = <80>, <81>;
interrupt-names = "tx", "rx";
dmas = <&edma 8 2>,
<&edma 9 2>;
mcasp1: mcasp@4803c000 {
ti,hwmods = "mcasp1";
reg = <0x4803C000 0x2000>,
<0x46400000 0x400000>;
interrupts = <82>, <83>;
dmas = <&edma 10 2>,
<&edma 11 2>;
rng: rng@48310000 {
compatible = "ti,omap4-rng";
ti,hwmods = "rng";
reg = <0x48310000 0x2000>;
interrupts = <111>;
sgx: sgx@56000000 {
compatible = "ti,am3352-sgx530", "img,sgx530";
ti,hwmods = "gfx";
reg = <0x56000000 0x10000>;
interrupts = <37>;
clocks = <&gfx_fck_div_ck>;
clock-names = "fclk";
#include "am33xx-clocks.dtsi"
Please help me to resolve the touch issue.
M.Ramarao.
