DRA821U: How to debug with CCS after booting
Part Number: DRA821U
Our customer wants to debug using CCS after booting from SD card. They used the customized GEL files to read the PLL registers, but the read failed. The GEL files were set up by following the procedure linked below, and ran by connecting DMSC_Cortex_M3_0. The launch.js script was unused because the DMSC firmware has already been executed by booting.
software-dl.ti.com/.../ccs_setup_j7200.html
Attach the customized GEL files here:
J7VCL_SI.gel
J7VCL_PLL.gel
Attach the GEL output log here:
DMSC_Cortex_M3_0: GEL Output: Debugging disabled.
DMSC_Cortex_M3_0: GEL Output: Reading off all PLLs configuration.
DMSC_Cortex_M3_0: GEL Output: Read off Main PLL 0 (Main PLL)
DMSC_Cortex_M3_0: GEL Output: Base address: 0x00680000
DMSC_Cortex_M3_0: GEL Output: PLL index: 0x00000000
DMSC_Cortex_M3_0: GEL Output: PLL index register base: 0x00000000
DMSC_Cortex_M3_0: GEL Output: Register: 0x00000020
DMSC_Cortex_M3_0: GEL Output: Reference Divider is:     0
DMSC_Cortex_M3_0: GEL Output: Feedback Divider is:      0
DMSC_Cortex_M3_0: GEL Output: Fractional Multiplier is: 0
DMSC_Cortex_M3_0: GEL Output: Output Divider #1 is:     0
DMSC_Cortex_M3_0: GEL Output: Output Divider #2 is:     0
DMSC_Cortex_M3_0: GEL Output: Number of hsidvs: 0
DMSC_Cortex_M3_0: GEL Output: Parsed PLL configuration information.
DMSC_Cortex_M3_0: GEL Output: Read off Main PLL 1 (Peripheral 0 PLL)
DMSC_Cortex_M3_0: GEL Output: PLL index: 0x00000001
DMSC_Cortex_M3_0: GEL Output: PLL index register base: 0x00001000
DMSC_Cortex_M3_0: GEL Output: Read off Main PLL 2 (Peripheral 1 PLL)
DMSC_Cortex_M3_0: GEL Output: PLL index: 0x00000002
DMSC_Cortex_M3_0: GEL Output: PLL index register base: 0x00002000
DMSC_Cortex_M3_0: GEL Output: Read off Main PLL 3 (CPSW5X PLL)
DMSC_Cortex_M3_0: GEL Output: PLL index: 0x00000003
DMSC_Cortex_M3_0: GEL Output: PLL index register base: 0x00003000
DMSC_Cortex_M3_0: GEL Output: Read off Main PLL 4 (Audio 0 PLL)
DMSC_Cortex_M3_0: GEL Output: PLL index: 0x00000004
DMSC_Cortex_M3_0: GEL Output: PLL index register base: 0x00004000
DMSC_Cortex_M3_0: GEL Output: Read off Main PLL 7 (MSMC PLL)
DMSC_Cortex_M3_0: GEL Output: PLL index: 0x00000007
DMSC_Cortex_M3_0: GEL Output: PLL index register base: 0x00007000
DMSC_Cortex_M3_0: GEL Output: Read off Main PLL 8 (ARM0 PLL)
DMSC_Cortex_M3_0: GEL Output: PLL index: 0x00000008
DMSC_Cortex_M3_0: GEL Output: PLL index register base: 0x00008000
DMSC_Cortex_M3_0: GEL Output: Read off Main PLL 12 (DDR PLL)
DMSC_Cortex_M3_0: GEL Output: PLL index: 0x0000000C
DMSC_Cortex_M3_0: GEL Output: PLL index register base: 0x0000C000
DMSC_Cortex_M3_0: GEL Output: Read off Main PLL 14 (Main Domain Pulsar) PLL)
DMSC_Cortex_M3_0: GEL Output: PLL index: 0x0000000E
DMSC_Cortex_M3_0: GEL Output: PLL index register base: 0x0000E000
DMSC_Cortex_M3_0: GEL Output: Read off MCU PLL 0 (MCU PLL)
DMSC_Cortex_M3_0: GEL Output: Base address: 0x40D00000
DMSC_Cortex_M3_0: GEL Output: Read off MCU PLL 1 (MCU Peripheral PLL)
DMSC_Cortex_M3_0: GEL Output: Read off MCU PLL 2 (MCU CPSW PLL)
DMSC_Cortex_M3_0: GEL Output: Reading off all PLLs configuration ...done.
By the way, the SBL test application (sbl_baremetal_boot_test_j7200_evm_mpu1_0TestApp_release) is used as the MPU application.
software-dl.ti.com/.../boot_k3.html
The thread related to this post is here: e2e.ti.com/.../dra821u-how-to-change-the-initial-mpu-a72-clock-frequency-in-sbl
Daisuke
    Our customer tried to debug by connecting DMSC_Cortex_M3_0 after launching the CCS debugger.
    Are their steps correct for debugging the target after booting?
    If not, does the launch.js script need to be used?
    The customized GEL file was run by connecting DMSC_Cortex_M3_0 and read the PLL registers, but the values of all fields showed 0. Please check OnTargetConnect() in J7VCL_SI.gel and Get_All_PLL () in J7VCL_PLL.gel for reading the PLL registers.
    Are there any failures in the customized GEL file?
    Is any other step required to read the PLL register?
    Please give me an answer as soon as possible. Your prompt reply would be appreciated.
    Daisuke
  • Hi Daisuke,
    If you have booted the board using some bootloader (SPL or SBL) then there is no need to run the launch.js or the GEL files to debug.
    Are you trying to read some MMR registers which could be protected by a lock?
    Karan
  • Hi Karan-san,
    Thank you for your reply.
    Is it required to be unlocked by the Kick Protection Registers before the PLL registers are read?
    I understand that the protection mechanism for registers only prevents writes.
    Daisuke
  • Hi Karan-san,
    We added an unlock by the Kick Protection Registers before reading the PLL registers in the GEL file, but all read values still show 0.
    0741.J7VCL_SI.gel
    8203.J7VCL_PLL.gel
    DMSC_Cortex_M3_0: GEL Output: PLL_CONFIG register address: 0x0x80680008
    DMSC_Cortex_M3_0: GEL Output: OUTPUT_DIV_CONTROL register address: 0x0x80680038
    DMSC_Cortex_M3_0: GEL Output: FREQ_CONTROL_0 register address: 0x0x80680030
    DMSC_Cortex_M3_0: GEL Output: FREQ_CONTROL_1 register address: 0x0x80680034
    DMSC_Cortex_M3_0: GEL Output: PLL_CONFIG register address: 0x0x80681008
    DMSC_Cortex_M3_0: GEL Output: OUTPUT_DIV_CONTROL register address: 0x0x80681038
    DMSC_Cortex_M3_0: GEL Output: FREQ_CONTROL_0 register address: 0x0x80681030
    DMSC_Cortex_M3_0: GEL Output: FREQ_CONTROL_1 register address: 0x0x80681034
    DMSC_Cortex_M3_0: GEL Output: PLL_CONFIG register address: 0x0x80682008
    DMSC_Cortex_M3_0: GEL Output: OUTPUT_DIV_CONTROL register address: 0x0x80682038
    DMSC_Cortex_M3_0: GEL Output: FREQ_CONTROL_0 register address: 0x0x80682030
    DMSC_Cortex_M3_0: GEL Output: FREQ_CONTROL_1 register address: 0x0x80682034
    DMSC_Cortex_M3_0: GEL Output: PLL_CONFIG register address: 0x0x80683008
    DMSC_Cortex_M3_0: GEL Output: OUTPUT_DIV_CONTROL register address: 0x0x80683038
    DMSC_Cortex_M3_0: GEL Output: FREQ_CONTROL_0 register address: 0x0x80683030
    DMSC_Cortex_M3_0: GEL Output: FREQ_CONTROL_1 register address: 0x0x80683034
    DMSC_Cortex_M3_0: GEL Output: PLL_CONFIG register address: 0x0x80684008
    DMSC_Cortex_M3_0: GEL Output: OUTPUT_DIV_CONTROL register address: 0x0x80684038
    DMSC_Cortex_M3_0: GEL Output: FREQ_CONTROL_0 register address: 0x0x80684030
    DMSC_Cortex_M3_0: GEL Output: FREQ_CONTROL_1 register address: 0x0x80684034
    DMSC_Cortex_M3_0: GEL Output: PLL_CONFIG register address: 0x0x80687008
    DMSC_Cortex_M3_0: GEL Output: OUTPUT_DIV_CONTROL register address: 0x0x80687038
    DMSC_Cortex_M3_0: GEL Output: FREQ_CONTROL_0 register address: 0x0x80687030
    DMSC_Cortex_M3_0: GEL Output: FREQ_CONTROL_1 register address: 0x0x80687034
    DMSC_Cortex_M3_0: GEL Output: PLL_CONFIG register address: 0x0x80688008
    DMSC_Cortex_M3_0: GEL Output: OUTPUT_DIV_CONTROL register address: 0x0x80688038
    DMSC_Cortex_M3_0: GEL Output: FREQ_CONTROL_0 register address: 0x0x80688030
    DMSC_Cortex_M3_0: GEL Output: FREQ_CONTROL_1 register address: 0x0x80688034
    DMSC_Cortex_M3_0: GEL Output: PLL_CONFIG register address: 0x0x8068C008
    DMSC_Cortex_M3_0: GEL Output: OUTPUT_DIV_CONTROL register address: 0x0x8068C038
    DMSC_Cortex_M3_0: GEL Output: FREQ_CONTROL_0 register address: 0x0x8068C030
    DMSC_Cortex_M3_0: GEL Output: FREQ_CONTROL_1 register address: 0x0x8068C034
    DMSC_Cortex_M3_0: GEL Output: PLL_CONFIG register address: 0x0x8068E008
    DMSC_Cortex_M3_0: GEL Output: OUTPUT_DIV_CONTROL register address: 0x0x8068E038
    DMSC_Cortex_M3_0: GEL Output: FREQ_CONTROL_0 register address: 0x0x8068E030
    DMSC_Cortex_M3_0: GEL Output: FREQ_CONTROL_1 register address: 0x0x8068E034
    DMSC_Cortex_M3_0: GEL Output: PLL_CONFIG register address: 0x0x60D00008
    DMSC_Cortex_M3_0: GEL Output: OUTPUT_DIV_CONTROL register address: 0x0x60D00038
    DMSC_Cortex_M3_0: GEL Output: FREQ_CONTROL_0 register address: 0x0x60D00030
    DMSC_Cortex_M3_0: GEL Output: FREQ_CONTROL_1 register address: 0x0x60D00034
    DMSC_Cortex_M3_0: GEL Output: PLL_CONFIG register address: 0x0x60D01008
    DMSC_Cortex_M3_0: GEL Output: OUTPUT_DIV_CONTROL register address: 0x0x60D01038
    DMSC_Cortex_M3_0: GEL Output: FREQ_CONTROL_0 register address: 0x0x60D01030
    DMSC_Cortex_M3_0: GEL Output: FREQ_CONTROL_1 register address: 0x0x60D01034
    DMSC_Cortex_M3_0: GEL Output: PLL_CONFIG register address: 0x0x60D02008
    DMSC_Cortex_M3_0: GEL Output: OUTPUT_DIV_CONTROL register address: 0x0x60D02038
    DMSC_Cortex_M3_0: GEL Output: FREQ_CONTROL_0 register address: 0x0x60D02030
    DMSC_Cortex_M3_0: GEL Output: FREQ_CONTROL_1 register address: 0x0x60D02034
    Daisuke
  • Hi Karan-san,
    Post additional information.
    Our customer used the memory browser view on CCS to check the PLL registers.
    The values read by DMSC_Cortex_M3_0 showed 0.
    CortexA72_0_0 or MCU_Cortex_R5_0 succeeded in reading the values.
    Daisuke
  • Hi Daisuke-san,
    Let me try to replicate this and get back to you.
    Karan
  • Hi Daisuke-san,
    I see the address 0x688030 for PLL0_CFG_PLL8_FREQ_CTRL0 in TRM, how do you get the address 0x80688030 which you are checking from M3? I have also notified the HW team on this question.
    Karan
  • Hi Karan-san,
    I referenced the default GEL file for the address 0x80688030. The default GEL file (J7VCL_PLL.gel) uses the address offset 0x80000000 in Set_All_PLL().
    The values read by DMSC_Cortex_M3_0 with the address 0x688030 also showed 0.
    Daisuke
  • Hi Daisuke-san,
    I tried to replicate the issue on my setup. I booted the board with SD card and connected to DMSC_Cortex_M3_0 with the default gel files. I am able to read the PLL registers from the memory browser. Looks like there is some issue with the customized gel files that you are using. Could you please try with the default gel files and see if you are still facing the issue.
    Also, is there a specific reason to use M3 for debugging and not the R5 or A72 directly?
  • Hi Parth Nagpal-san,
    Our customer has achieved their goal by reading the PLL registers with R5 or A72 after booting.
    The thread related is here: e2e.ti.com/.../dra821u-how-to-change-the-initial-mpu-a72-clock-frequency-in-sbl
    Initially, we tried to use the script "Get_PLL_Configuration()" for reading the PLL registers that is provided in the default GEL file "J7VCL_PLL.gel".
    I am wondering why DMSC_Cortex_M3_0 cannot read the PLL registers, but I understand that DMSC_Cortex_M3_0 cannot be used to debug using CCS.
    Daisuke
  • Hi Daisuke-san,
    We are glad to hear that your customer has achieved their goal. DMSC_Cortex_M3_0 can be used to read the registers but it is not ideal for debugging as it restricts access to some memory space.
    If you have no further questions, please click on verify answer.
    Parth Nagpal
    Daisuke
