Part Number: AM6548
Our customer wants to build the latest Linux processor SDK 7.3 by following the link below.
software-dl.ti.com/.../Overview_Building_the_SDK.html
It is required to download the toolchain, but the source of the toolchain is not clear.
Download the toolchain compilers from the links provided in the SDK release page. Keep the extracted toolchains in the $HOME directory of host Linux machine. Use $HOME directory as the PATH_TO_TOOLCHAIN in following command.
software-dl.ti.com/.../Release_Specific_Release_Notes.html
Compiler Information: arm-none-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025
software-dl.ti.com/.../GCC_ToolChain.html
The name of the toolchain binaries have also been updated from older versions of the SDK. Current SDK ARMv8 toolchains use a prefix of “aarch64-linux-gnu-” For example, the new toolchain’s gcc compiler is named aarch64-linux-gnu-gcc.
Are the links for the required toolchains below?
AArch32 target with hard float (arm-linux-none-gnueabihf)
gcc-arm-9.2-2019.12-x86_64-arm-none-linux-gnueabihf.tar.xz
developer.arm.com/.../gcc-arm-9.2-2019.12-x86_64-arm-none-linux-gnueabihf.tar.xz
AArch64 GNU/Linux target (aarch64-none-linux-gnu)
gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu.tar.xz
developer.arm.com/.../gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu.tar.xz
The links can be found below.
Version 9.2-2019.12
developer.arm.com/.../9-2-2019-12
Daisuke
