DRA821U: spi-nor flash mt35xu512aba erase & write timeout
Part Number: DRA821U
Hi Expert.
We met a problem when erase & wirte nor flash using the tool flashcp, its errors are as:
root@j7200-evm:/mnt# cat /proc/mtd
dev: size erasesize name
mtd0: 00080000 00020000 "ospi.tiboot3"
mtd1: 00200000 00020000 "ospi.tispl"
mtd2: 00400000 00020000 "ospi.u-boot"
mtd3: 00020000 00020000 "ospi.env"
mtd4: 00020000 00020000 "ospi.env.backup"
mtd5: 00100000 00020000 "ospi.sysfw"
mtd6: 037e0000 00020000 "ospi.rootfs"
mtd7: 00020000 00020000 "ospi.phypattern"
root@j7200-evm:/mnt# flashcp tiboot3.bin /dev/mtd0
[ 4469.944809] cadence-qspi 47040000.spi: Flash command execution timed out.
[ 4469.951593] spi-nor spi0.0: operation failed with -110
[ 4509.955200] spi-nor spi0.0: flash operation timed out
could you give us some suggestion how to research this problem?
 I am looking forward to your reply, Thanks.
kernel boot logs:
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 5.4.106-g023faefa70 (a0224068local@a0224068local-Latitude-E7440) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #12 SMP PREEMPT M1
[ 0.000000] Machine model: Texas Instruments K3 J7200 SoC
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000090000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@90000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000090100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@90100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000091000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@91000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000091100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@91100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000092000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@92000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000092100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@92100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000093000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@93000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000093100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@93100000, compatible id shared-dma-pool
[ 0.000000] cma: Failed to reserve 512 MiB
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 2 pages/cpu s48472 r8192 d74408 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] Built 1 zonelists, mobility grouping off. Total pages: 760
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk1p2 rw rootfstype=ext4 rootwait mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 406912K/49152K available (9662K kernel code, 854K rwdata, 3840K rodata, 1664K init, 681K bss, 18446744073709193856K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: no VLPI support, no direct LPI support
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @94800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000081160000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000081170000
[ 0.000000] random: get_random_bytes called from start_kernel+0x2c8/0x43c with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008282] Console: colour dummy device 80x25
[ 0.012838] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023506] pid_max: default: 32768 minimum: 301
[ 0.028254] LSM: Security Framework initializing
[ 0.032998] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[ 0.040566] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[ 0.049569] ASID allocator initialised with 32768 entries
[ 0.055164] rcu: Hierarchical SRCU implementation.
[ 0.060202] Platform MSI: msi-controller@1820000 domain created
[ 0.066322] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.075729] smp: Bringing up secondary CPUs ...
ERROR: GTC_CNTFID0 is 0! Assuming 200000000 Hz. Fix Bootloader
[ 0.086667] Detected PIPT I-cache on CPU1
[ 0.086687] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.086700] GICv3: CPU1: using allocated LPI pending table @0x0000000082080000
[ 0.086724] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.086769] smp: Brought up 1 node, 2 CPUs
[ 0.116118] SMP: Total of 2 processors activated.
[ 0.120922] CPU features: detected: 32-bit EL0 Support
[ 0.126175] CPU features: detected: CRC32 instructions
[ 0.137704] CPU: All CPU(s) started at EL2
[ 0.141898] alternatives: patching kernel code
[ 0.146968] devtmpfs: initialized
[ 0.152747] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.162713] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[ 0.169977] pinctrl core: initialized pinctrl subsystem
[ 0.175743] NET: Registered protocol family 16
[ 0.180480] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.187001] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.200186] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[ 0.207043] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[ 0.213801] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.221420] cryptd: max_cpu_qlen set to 1000
[ 0.227747] iommu: Default domain type: Translated
[ 0.232878] SCSI subsystem initialized
[ 0.236979] mc: Linux media interface: v0.10
[ 0.241352] videodev: Linux video capture interface: v2.00
[ 0.246964] pps_core: LinuxPPS API ver. 1 registered
[ 0.252033] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.261370] PTP clock support registered
[ 0.265381] EDAC MC: Ver: 3.0.0
[ 0.269038] FPGA manager framework
[ 0.272552] Advanced Linux Sound Architecture Driver Initialized.
[ 0.279157] clocksource: Switched to clocksource arch_sys_counter
[ 0.285447] VFS: Disk quotas dquot_6.6.0
[ 0.289506] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[ 0.298803] thermal_sys: Registered thermal governor 'step_wise'
[ 0.298805] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.305122] NET: Registered protocol family 2
[ 0.316522] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[ 0.325286] TCP established hash table entries: 8192 (order: 0, 65536 bytes, linear)
[ 0.333239] TCP bind hash table entries: 8192 (order: 1, 131072 bytes, linear)
[ 0.340700] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.347254] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[ 0.354144] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[ 0.361534] NET: Registered protocol family 1
[ 0.366268] RPC: Registered named UNIX socket transport module.
[ 0.372322] RPC: Registered udp transport module.
[ 0.377128] RPC: Registered tcp transport module.
[ 0.381931] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.388514] PCI: CLS 0 bytes, default 64
[ 0.392808] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.402819] Initialise system trusted keyrings
[ 0.407452] workingset: timestamp_bits=46 max_order=13 bucket_order=0
[ 0.416083] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.422341] NFS: Registering the id_resolver key type
[ 0.427514] Key type id_resolver registered
[ 0.431785] Key type id_legacy registered
[ 0.435882] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.442810] 9p: Installing v9fs 9p2000 file system support
[ 0.455477] Key type asymmetric registered
[ 0.459664] Asymmetric key parser 'x509' registered
[ 0.464662] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.472221] io scheduler mq-deadline registered
[ 0.476845] io scheduler kyber registered
[ 0.481800] pinctrl-single 4301c000.pinmux: 94 pins, size 376
[ 0.487879] pinctrl-single 11c000.pinmux: 173 pins, size 692
[ 0.494024] pinctrl-single a40000.timesync_router: 512 pins, size 2048
[ 0.502573] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.508854] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.516446] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.528762] brd: module loaded
[ 0.535203] loop: module loaded
[ 0.539652] libphy: Fixed MDIO Bus: probed
[ 0.544020] tun: Universal TUN/TAP device driver, 1.6
[ 0.549383] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 0.557392] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.563467] sky2: driver version 1.30
[ 0.567563] VFIO - User Level meta-driver version: 0.3
[ 0.573140] i2c /dev entries driver
[ 0.577075] sdhci: Secure Digital Host Controller Interface driver
[ 0.583391] sdhci: Copyright(c) Pierre Ossman
[ 0.588018] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.594125] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.600803] optee: probing for conduit method from DT.
[ 0.606063] optee: api uid mismatch
[ 0.610345] NET: Registered protocol family 17
[ 0.614965] 9pnet: Installing 9P2000 support
[ 0.619353] Key type dns_resolver registered
[ 0.623853] registered taskstats version 1
[ 0.628041] Loading compiled-in X.509 certificates
[ 0.633931] add by yong, drvdata->desc.name: vdd_sd_dv
[ 0.641075] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.647399] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.654622] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.1.1--v2021.01a (Terrific Lla')
[ 0.671780] add by yong, drvdata->desc.name: vdd_sd_dv
[ 0.677515] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[ 0.683500] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.689455] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[ 0.695499] pca953x 3-0020: 3-0020 supply vcc not found, using dummy regulator
[ 0.702916] pca953x 3-0020: using no AI
[ 0.727200] pca953x 3-0020: failed writing register
[ 0.732238] pca953x: probe of 3-0020 failed with error -121
[ 0.738036] pca953x 3-0022: 3-0022 supply vcc not found, using dummy regulator
[ 0.745441] pca953x 3-0022: using AI
[ 0.749139] pca953x 3-0022: failed writing register
[ 0.754147] pca953x: probe of 3-0022 failed with error -121
[ 0.759879] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[ 0.765767] omap_i2c 2010000.i2c: bus 4 rev0.12 at 100 kHz
[ 0.771630] omap_i2c 2020000.i2c: bus 5 rev0.12 at 100 kHz
[ 0.777483] omap_i2c 2030000.i2c: bus 6 rev0.12 at 100 kHz
[ 0.783339] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
[ 0.789179] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
[ 0.795027] omap_i2c 2060000.i2c: bus 9 rev0.12 at 100 kHz
[ 0.800990] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[ 0.810929] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[ 0.819705] ti-sci-intr bus@100000:navss@30000000:interrupt-controller1: Interrupt Router 213 domain created
[ 0.829873] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain -1 created
[ 0.839235] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,32] sci-dev-id:235
[ 0.849107] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 0.855866] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[ 0.865226] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[120,200] sci-dev-id:211
[ 0.875384] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 0.882143] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[ 0.890010] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 7, base_baud = 6000000) is a 8250
[ 0.899199] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 14, base_baud = 3000000) is a 8250
[ 0.907939] printk: console [ttyS2] enabled
[ 0.916375] printk: bootconsole [ns16550a0] disabled
[ 0.926756] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 15, base_baud = 3000000) is a 8250
[ 0.936636] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[ 0.945138] mmc0: CQHCI version 5.10
[ 0.985748] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit
[ 0.996681] add by yong, drvdata->desc.name: vdd_sd_dv
[ 1.002248] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc8900
[ 1.009073] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc8900
[ 1.016094] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 1.025324] random: fast init done
[ 1.029271] ti-udma 31150000.dma-controller: Channels: 50 (tchan: 25, rchan: 25, gp-rflow: 8)
[ 1.040699] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
[ 1.045929] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
[ 1.052540] Creating 8 MTD partitions on "47040000.spi.0":
[ 1.058023] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 1.064075] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 1.069937] 0x000000280000-0x000000680000 : "ospi.u-boot"
[ 1.075786] 0x000000680000-0x0000006a0000 : "ospi.env"
[ 1.081456] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[ 1.087656] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[ 1.093464] 0x000000800000-0x000003fe0000 : "ospi.rootfs"
[ 1.099292] 0x000003fe0000-0x000004000000 : "ospi.phypattern"
[ 1.106077] mmc1: CQHCI version 5.10
[ 1.133055] mmc0: Command Queue Engine enabled
[ 1.137504] mmc0: new HS200 MMC card at address 0001
[ 1.142731] mmcblk0: mmc0:0001 DA6032 29.1 GiB
[ 1.147389] mmcblk0boot0: mmc0:0001 DA6032 partition 1 4.00 MiB
[ 1.153504] mmcblk0boot1: mmc0:0001 DA6032 partition 2 4.00 MiB
[ 1.159508] mmcblk0rpmb: mmc0:0001 DA6032 partition 3 4.00 MiB, chardev (240:0)
[ 1.166813] mmc1: SDHCI controller on 4fb0000.sdhci [4fb0000.sdhci] using ADMA 64-bit
[ 1.175093] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[ 1.183325] hctosys: unable to open rtc device (rtc0)
[ 1.190581] ALSA device list:
[ 1.193557] No soundcards found.
[ 1.197369] Waiting for root device /dev/mmcblk1p2...
[ 1.231436] mmc1: new high speed SDHC card at address e624
[ 1.237282] mmcblk1: mmc1:e624 SD32G 29.7 GiB
[ 1.245713] mmcblk1: p1 p2
[ 1.275226] EXT4-fs (mmcblk1p2): recovery complete
[ 1.280015] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.288117] VFS: Mounted root (ext4 filesystem) on device 179:98.
[ 1.296856] devtmpfs: mounted
[ 1.300191] Freeing unused kernel memory: 1664K
[ 1.304732] Run /sbin/init as init process
[ 1.603529] systemd[1]: System time before build time, advancing clock.
[ 1.681618] NET: Registered protocol family 10
[ 1.686449] Segment Routing with IPv6
[ 1.720687] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -)
[ 1.742429] systemd[1]: Detected architecture arm64.
Welcome to Arago 2020.09!
[ 1.788103] systemd[1]: Set hostname to <j7200-evm>.
[ 2.062915] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock ??→ /run/docker.sock; please update the unit file .
[ 2.161242] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.167961] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 2.180290] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 2.190221] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 2.211284] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.218540] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 2.235223] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.242453] systemd[1]: Created slice system-syslog\x2dng.slice.
[ OK ] Created slice system-syslog\x2dng.slice.
[ 2.259965] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 2.279363] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password ??…ts to Console Directory Watch.
[ 2.303277] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R??…uests to Wall Directory Watch.
[ 2.327283] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 2.343217] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 2.359215] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 2.375218] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 2.392912] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 2.411259] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 2.429804] systemd[1]: Listening on Process Core Dump Socket.
[ OK ] Listening on Process Core Dump Socket.
[ 2.447348] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 2.481308] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 2.489631] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 2.507443] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 2.523481] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 2.543409] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 2.559321] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 2.577536] systemd[1]: Mounting Huge Pages File System...
[ 2.602071] systemd[1]: Mounting POSIX Message Queue File System...
[ 2.626187] systemd[1]: Mounting Kernel Debug File System...
[ 2.650796] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 2.674111] systemd[1]: Starting Create list of static device nodes for the current kernel...
Starting Create list of st??…odes for the current kernel...
[ 2.703922] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
[ OK ] Started Hardware RNG Entropy Gatherer Daemon.
[ 2.731249] systemd[1]: Starting RPC Bind...
[ 2.751368] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 2.774879] systemd[1]: Starting Journal Service...
[ 2.799290] systemd[1]: Starting Load Kernel Modules...
[ 2.818513] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 2.825524] cryptodev: loading out-of-tree module taints kernel.
[ 2.843361] cryptodev: driver 1.10 loaded.
[ 2.850018] systemd[1]: Starting udev Coldplug all Devices...
[ 2.859078] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ 2.870846] systemd[1]: Started RPC Bind.
[ OK ] Started RPC Bind.
[ 2.892379] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Mounted Huge Pages File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Create list of sta??… nodes for the current kernel.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Remount Root and Kernel File Systems.
Mounting Kernel Configuration File System...
Starting Flush Journal to Persistent Storage...
[ 3.061987] systemd-journald[150]: Received client request to flush runtime journal.
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev...
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
Starting udev Kernel Device Manager...
[ OK ] Started udev Coldplug all Devices.
[ OK ] Mounted /media/ram.
[ OK ] Mounted /var/volatile.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Started Create Volatile Files and Directories.
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target System Time Set.
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Daily rotation of log files.
[ OK ] Reached target Timers.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
Starting Docker Socket for the API.
[ OK ] Listening on dropbear.socket.
Starting Reboot and dump vmcore via kexec...
[ OK ] Listening on Docker Socket for the API.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started Job spooling tools.
[ OK ] Started Periodic Command Scheduler.
[ OK ] Started D-Bus System Message Bus.
Starting Ethernet Bridge Filtering Tables...
Starting Print notice about GPLv3 packages...
Starting IPv6 Packet Filtering Framework...
Starting IPv4 Packet Filtering Framework...
[ OK ] Started irqbalance daemon.
Starting System Logger Daemon "default" instance...
Starting Login Service...
Starting telnetd.service...
[ OK ] Started Reboot and dump vmcore via kexec.
[ OK ] Started Ethernet Bridge Filtering Tables.
[ OK ] Started IPv6 Packet Filtering Framework.
[ 3.950749] rti-wdt 2200000.watchdog: heartbeat 60 sec
[ 3.997706] rti-wdt 2210000.watchdog: heartbeat 60 sec
[ OK ] Started IPv4 Packet Filtering Framework.
[ OK ] Smtelnetd.service.
[ OK ] Reached target Network (Pre).
Starting syslog.service...
Starting Network Service...
[ OK ] Started Login Service.
[ OK ] Started Network Service.
Starting Wait for Network to be Configured...
Starting Network Name Resolution...
[ OK ] Started Network Name Resolution.
[ OK ] Reached target Network.
[ OK ] Reached target Host and Network Name Lookups.
Starting Avahi mDNS/DNS-SD Stack...
Starting Enable and configure wl18xx bluetooth stack...
[ OK ] Started NFS status monitor for NFSv2/3 locking..
Starting Simple Network Ma??…ent Protocol (SNMP) Daemon....
Starting Permit User Sessions...
[ OK ] Started Vsftpd ftp daemon.
[ OK ] Started Enable and configure wl18xx bluetooth stack.
[ OK ] Started Permit User Sessions.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Started Serial Getty on ttyS3.
[ OK ] Reached target Login Prompts.
Starting Synchronize System and HW clocks...
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[ 4.647128] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 4.884824] platform 41000000.r5f: configured R5F for IPC-only mode
[ 4.912695] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@90000000
[ 5.059378] remoteproc remoteproc0: 41000000.r5f is available
[ 5.262012] platform 41400000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 5.273992] remoteproc remoteproc0: powering up 41000000.r5f
[ 5.275190] random: crng init done
[ 5.279666] remoteproc remoteproc0: Booting fw image j7200-mcu-r5f0_0-fw, size 163752
[ 5.283033] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.292327] platform 41000000.r5f: R5F core initialized in IPC-only mode
[ 5.311193] remoteproc0#vdev0buffer: assigned reserved memory node r5f-dma-memory@90000000
[ 5.323506] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 5.334216] remoteproc0#vdev0buffer: registered virtio0 (type 7)
[ 5.347193] remoteproc remoteproc0: remote processor 41000000.r5f is now up
[ 5.359670] platform 41400000.r5f: configured R5F for IPC-only mode
[ OK ] Started Load/Save Random Seed.
[ 5.449927] platform 41400000.r5f: assigned reserved memory node r5f-dma-memory@91000000
[ OK ] Started System Logger Daemon "default" instance.
[ 5.576930] remoteproc remoteproc1: 41400000.r5f is available
[ OK ] Started syslog.service.
[ 5.639032] remoteproc remoteproc1: powering up 41400000.r5f
[ 5.644892] remoteproc remoteproc1: Booting fw image j7200-mcu-r5f0_1-fw, size 85428
[ 5.654565] platform 5c00000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 5.666429] platform 41400000.r5f: R5F core initialized in IPC-only mode
[ 5.673195] remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@91000000
[ 5.673845] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 5.673880] remoteproc1#vdev0buffer: registered virtio1 (type 7)
[ 5.673884] remoteproc remoteproc1: remote processor 41400000.r5f is now up
[ 5.699317] platform 5c00000.r5f: configured R5F for IPC-only mode
[ 5.808868] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@92000000
[ OK ] Started Simple Network Man??…ement Protocol (SNMP) Daemon..
[ 5.851737] remoteproc remoteproc2: 5c00000.r5f is available
[ 5.907276] platform 5d00000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 5.933464] remoteproc remoteproc2: powering up 5c00000.r5f
[ 5.939087] remoteproc remoteproc2: Booting fw image j7200-main-r5f0_0-fw, size 691128
[ 5.952242] platform 5c00000.r5f: Allocated carveout doesn't fit device address request
[ 5.965542] platform 5c00000.r5f: Allocated carveout doesn't fit device address request
[ 5.978490] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[ 5.987036] platform 5d00000.r5f: configured R5F for IPC-only mode
[ 5.991170] remoteproc2#vdev0buffer: assigned reserved memory node r5f-dma-memory@92000000
[ 6.007340] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 6.016429] remoteproc2#vdev0buffer: registered virtio2 (type 7)
[ 6.019287] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@93000000
[ 6.027183] remoteproc remoteproc2: remote processor 5c00000.r5f is now up
[ 6.069305] remoteproc remoteproc3: 5d00000.r5f is available
[ 6.096866] remoteproc remoteproc3: powering up 5d00000.r5f
[ 6.102577] remoteproc remoteproc3: Booting fw image j7200-main-r5f0_1-fw, size 85428
[ 6.115350] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[ 6.131202] remoteproc3#vdev0buffer: assigned reserved memory node r5f-dma-memory@93000000
[ 6.145103] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 6.154042] remoteproc3#vdev0buffer: registered virtio3 (type 7)
[ 6.163554] remoteproc remoteproc3: remote processor 5d00000.r5f is now up
[ OK ] Created slice system-systemd\x2dfsck.slice.
NOTICE: This file system contains the following GPLv3 packages:
autoconf
bash-dev
bash
bc
binutils
cifs-utils
coreutils-stdbuf
coreutils
cpio
cpp-symlinks
cpp
dosfstools
elfutils
g++-symlinks
g++
gawk
gcc-symlinks
gcc
gdb
gdbserver
gettext
gstreamer1.0-libav
gzip
less
libasm1
libbfd
libdw1
libelf1
libgdbm-compat4
libgdbm-dev
libgdbm6
libgettextlib
libgettextsrc
libgmp10
libidn2-0
libmpc3
libmpfr6
libreadline-dev
libreadline8
libunistring2
m4-dev
m4
make
nettle
parted
tar
which
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ OK ] Started Print notice about GPLv3 packages.
[ OK ] Found device /dev/mmcblk1p1.
Starting File System Check on /dev/mmcblk1p1...
[ 7.686106] cdns-usb3 6000000.usb: DRD version v1 (ID: 0004024e, rev: 00000200)
[ OK ] Started File System Check on /dev/mmcblk1p1.
Mounting /run/media/mmcblk1p1...
[ 7.720292] omap_rng 40910000.rng: Random Number Generator ver. 241b34c
[ OK ] Mounted /run/media/mmcblk1p1.
[ 7.851220] cdns-usb3 6000000.usb: Initialized ep0 support:
[ 7.863499] cdns-usb3 6000000.usb: Initialized ep1out support: BULK, INT ISO
[ 7.883506] cdns-usb3 6000000.usb: Initialized ep2out support: BULK, INT ISO
[ 7.892484] cdns-usb3 6000000.usb: Initialized ep3out support: BULK, INT ISO
[ 7.911526] cdns-usb3 6000000.usb: Initialized ep4out support: BULK, INT ISO
[ 7.932725] cdns-usb3 6000000.usb: Initialized ep5out support: BULK, INT ISO
[ 7.947176] cdns-usb3 6000000.usb: Initialized ep6out support: BULK, INT ISO
[ 7.955201] cdns-usb3 6000000.usb: Initialized ep7out support: BULK, INT ISO
[ 7.971164] cdns-usb3 6000000.usb: Initialized ep8out support: BULK, INT ISO
[ 7.978612] cdns-usb3 6000000.usb: Initialized ep9out support: BULK, INT ISO
[ 7.991180] cdns-usb3 6000000.usb: Initialized ep10out support: BULK, INT ISO
[ 8.003163] cdns-usb3 6000000.usb: Initialized ep11out support: BULK, INT ISO
[ 8.015167] cdns-usb3 6000000.usb: Initialized ep12out support: BULK, INT ISO
[ 8.027167] cdns-usb3 6000000.usb: Initialized ep13out support: BULK, INT ISO
[ 8.034794] cdns-usb3 6000000.usb: Initialized ep14out support: BULK, INT ISO
[ 8.047168] cdns-usb3 6000000.usb: Initialized ep15out support: BULK, INT ISO
[ 8.059168] cdns-usb3 6000000.usb: Initialized ep1in support: BULK, INT ISO
[ 8.071176] cdns-usb3 6000000.usb: Initialized ep2in support: BULK, INT ISO
[ 8.083166] cdns-usb3 6000000.usb: Initialized ep3in support: BULK, INT ISO
[ 8.095179] cdns-usb3 6000000.usb: Initialized ep4in support: BULK, INT ISO
[ 8.102643] cdns-usb3 6000000.usb: Initialized ep5in support: BULK, INT ISO
[ 8.115163] cdns-usb3 6000000.usb: Initialized ep6in support: BULK, INT ISO
[ 8.127165] cdns-usb3 6000000.usb: Initialized ep7in support: BULK, INT ISO
[ 8.139177] cdns-usb3 6000000.usb: Initialized ep8in support: BULK, INT ISO
[ 8.146638] cdns-usb3 6000000.usb: Initialized ep9in support: BULK, INT ISO
[ 8.159164] cdns-usb3 6000000.usb: Initialized ep10in support: BULK, INT ISO
[ 8.171166] cdns-usb3 6000000.usb: Initialized ep11in support: BULK, INT ISO
[ 8.187175] cdns-usb3 6000000.usb: Initialized ep12in support: BULK, INT ISO
[ 8.194833] cdns-usb3 6000000.usb: Initialized ep13in support: BULK, INT ISO
[ 8.207164] cdns-usb3 6000000.usb: Initialized ep14in support: BULK, INT ISO
[ 8.214599] cdns-usb3 6000000.usb: Initialized ep15in support: BULK, INT ISO
[ OK ] Reached target Hardware activated USB gadget.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org j7200-evm ttyS2
Arago 2020.09 j7200-evm ttyS2
j7200-evm login: root
